does rotax need egt?
Rowland_Carson
PostPosted: Wed Nov 11, 2009 5:18 am    Post subject: does rotax need egt? Reply with quote
Subject line nearly says it all.
I'm considering my panel layout and wondering if there's any point in
including an instrument to show EGT for the intended Rotax 912S
installation.
My initial reaction is that as there's no mixture control, EGT
indication does not add much to the CHT/coolant indication that comes
as standard. But I'm open to other opinions.
Has anyone found EGT indicators really important or useful in a Rotax
912S installation?
regards
Rowland
| Rowland Carson LAA #16532 http://home.clara.net/rowil/aviation/
| 1300 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
davidjoyce(at)doctors.org
PostPosted: Wed Nov 11, 2009 6:04 am    Post subject: does rotax need egt? Reply with quote
Rowland, I would strongly recommend fitting a Rotax Flydat or one of the
more modern engine monitoring systems that will monitor EGTs, oil T & P RPM
coolant temp and will flash a bright light at you if any of them depart
marginally from the norm. You can then spend much more time looking out and
making sure you don't ram something! And you save a lot of panel space.
Regards, David Joyce, G-XSDJ
Rowland_Carson
PostPosted: Wed Nov 11, 2009 9:25 am    Post subject: does rotax need egt? Reply with quote
At 2009-11-11 14:04 +0000 David Joyce wrote:
I would strongly recommend fitting a Rotax Flydat or one of the more
RPM coolant temp and will flash a bright light at you if any of them
depart marginally from the norm
David - thanks, I have already purchased a MGL box that does that
sort of stuff (but in a lot less space than a Flydat). I guess I
should have made that clear.
My query should therefore be re-stated as:
Should I bother to buy EGT probes for a 912S installation to use with
my engine monitor instrument?
With no mixture control, if I saw abnormal EGT indications, what
actions could I take in response?
regards
Rowland
| <rowil(at)clara.net> http://home.clara.net/rowil/
| Twitter: rowland_carson Facebook: Rowland Carson
PostPosted: Wed Nov 11, 2009 11:54 am    Post subject: does rotax need egt? Reply with quote
Rowland, I suspect you only get real value out of it if you monitor all 4
EGTs, as in the Flydat. I am no expert but I would expect that ignition
problems or compression problems in one cylinder would throw up unequal
temps. so letting you know where to start looking for the problem.There is
also the point that if your mixture control systemdoes go up the creek, then
it might tell you so before the whole thing burns up! I assume that
gubbins in one carburettor can lead to leaning of that bank of cylinders. It
also shows you whether your cylinder/exhaust cooling is even (which is not
the case in mine - the front 2 are significantly cooler than the others),
and presumably would give you warning that a baffle or some other part of
the cooling system had come adrift. Regards, David
air.guerner(at)orange.fr
PostPosted: Thu Nov 12, 2009 4:14 am    Post subject: does rotax need egt? Reply with quote
Hi Rowland and all,
In my opinion, EGT indication on any Rotax engine is useless. EGT indication is extremely sensitive to the position of the probe inside the exhaust stack. This is one of the reasons why, on any piston engine, the EGT indication in itself cannot be used to determine whether a cylinder is running too lean or too rich. The highest EGT cylinder is not necessarily the leanest. The only way to determine the mixture condition is to pull the mixture control progressively and monitor the EGT on all cylinders. The leanest cylinder is the one which will reach peak EGT first. Of course you cannot do that on a Rotax as there is no mixture control. The only thing EGT can do on a Rotax, in case of a big engine problem, is to help diagnose which cylinder is the culprit.
Additional comments:
With the Europa XS cowling, the EGT probes on cylinders 1 and 2 are cooled by direct ram air from the round intakes and this has proved to affect their indication.
The Rotax Flydat has 4 EGT channels but shows EGT on two cylinders at a time and switches automatically back and forth. That makes EGT very uneasy to read. Any other engine monitor on the market is certainly better.
My plane was fitted with a 914 with Flydat and 4 EGTs when I bought it. When I replaced the engine with the 912S five years ago, I kept the Flydat but did not install EGT probes and it works for me.
Remi Guerner
F-PGKL
<<<<<< as there's no mixture control, EGT
as standard. >>>>>>>>
raimo.toivio(at)rwm.fi
PostPosted: Thu Nov 12, 2009 11:05 am    Post subject: does rotax need egt? Reply with quote
Remi,
just curious: why did you replace the engine (914T) and went to 912S ?
Raimo OH-XRT 152 hrs
grahamsingleton(at)btinte
PostPosted: Thu Nov 12, 2009 1:22 pm    Post subject: does rotax need egt? Reply with quote
Remi Guerner wrote:
Hi Rowland and all,
better.
Remi Guerner
F-PGKL
Remi
We had a Classic with a Grand Rapids EIS and 4 EGTs. I soon noticed that
EGT varies in an unusual way with throttle setting. The mixture is
affected by throttle position because of the effect of momentum on the
fuel droplets, which tend to go to the front cylinders at WOT and the
rear at part throttle.
One thing is apparent, the very high EGTs the Rotax has in normal
operation. This means the exhaust system is under considerable thermal
stress.
I tend to the feeling that EGT is worth having for diagnostic reasons
but difficult to understand on the Rotax.
Graham
budyerly(at)msn.com
PostPosted: Thu Nov 12, 2009 1:55 pm    Post subject: does rotax need egt? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Well put Graham.
It is a diagnostic tool of which you have no control over from the cockpit...
Bud Yerly
PostPosted: Fri Nov 13, 2009 4:34 am    Post subject: does rotax need egt? Reply with quote
Raimo,
This is an old story. You can read the article I wrote on this subject in the June 2005 issue of EF.
To make it short: I found the 914 to be very far from satisfying my own standards of reliability and safety for an aircraft engine. I have 430 hours now on the 912S and this replacement is the best decision I have made since I own this aircraft.
Remi
<<<<<just curious: why did you replace the engine (914T) and went to 912S ?>>>>
rampil
PostPosted: Fri Nov 13, 2009 8:18 am    Post subject: Re: does rotax need egt? Reply with quote
Hi All,
I have all four cylinders monitored for the past five years and
have finally found a good use for them!
Based on data from several long cross country trips, I have decided to
add a mixture control!
Take a peak ( sic!) at the table I enclose. If you have different data,
please let me know
Rotax Efficiency.pdf
 Filename:  Rotax Efficiency.pdf
 Filesize:  37.19 KB
 Downloaded:  642 Time(s)
Ira N224XS
jpg12305
PostPosted: Sat Nov 14, 2009 1:23 am    Post subject: Re: does rotax need egt? Reply with quote
please let me know
If I properly understand, this demonstrates that fuel consumption increases very significantly with altitude, right?
I have heard/read a lot of different things about altitude compensation for the Bing carbs. Some say there is compensation by design, some that there is no compensation at all, and some that there is only partial one.
I would think now the second statement is the right one!
My own experience (without having a flowmeter nor CS prop) is that I have never seen an apparent MPG increase by flying high.
I would be interested in seeing some other data confirming yours.
Jean-Paul
Europa 332 - France
hurstkr(at)redzone.com.au
PostPosted: Sat Nov 14, 2009 2:41 am    Post subject: does rotax need egt? Reply with quote
http://forums.matronics.com//files/rotax_efficiency_125.pdf
Hello Ira,
Thank you for posting those figures . . . interesting indeed. 60% increase
in fuel consumption flying at 9,000 ft as opposed to 3,000ft while TAS
increases 33%.
I note the increase in fuel consumption is almost linear from 3K to 7K ft
while the increase between 7K and 9K is double that between 5K & 7K. I
imagine 22.6" MP at 9K would be wide open throttle so I'm wondering if this
kick in the consumption is because of power jets coming into play.
Regardless, there is nothing that can be done about it with things as they
are so I can certainly understand your desire to install a mixture control.
I look forward to hearing how you accomplish this.
Sorry I am unable to supply any comparative data yet.
BTW, your MPG figures appear to actually be NMPG so your actual MPG is still
way ahead of any motor vehicle travelling at 146 MPH. Realizing that may
make you feel better No?
Somewhere I saw once that Rotax actually do have true altitude compensating
carburettors but for the life of me I cannot recall where I saw that.
Cheers
Kingsley
PostPosted: Sat Nov 14, 2009 5:12 am    Post subject: does rotax need egt? Reply with quote
Kingsley, For what it's worth my 914 mono XS + speed kit has given the
following figures in careful trials:
At 2000ft 100 kts TAS 12 litres/hr
110 " " 13 "
120 " " 14 "
130 " " 18 "
140 " " 23 "
At 10,000ft 150 " " 21 "
This suggests that unlike the 912S, the 914 is able to adjust
adequately for altitude, and I suppose that should be no surprise.
frans(at)paardnatuurlijk.
PostPosted: Sat Nov 14, 2009 6:31 am    Post subject: does rotax need egt? Reply with quote
It doesn't adjust, it has a turbo. And the turbo keeps everything
pressurized, including the carbs. The engine, nor the carbs, would
notice the difference between 2.000 and 10.000 feet.
Frans
PostPosted: Sat Nov 14, 2009 4:44 pm    Post subject: does rotax need egt? Reply with quote
Jean-Paul
Europa 332 - France
There is a mod for mixture control, I know the UK agents (Nigel Beale at
SkyDrive) tried it and they may offer a mod. It involves adjusting the
overpressure on the carb float bowl, which has a significant effect on
mixture. Don't try this at home without consulting a Rotax expert.
You definitely need EGT to see what's happening.
Graham
PostPosted: Sun Nov 15, 2009 1:19 am    Post subject: does rotax need egt? Reply with quote
At 2000ft 100 kts TAS 12 litres/hr . . . . . . At 10,000ft 150 "
" 21 "
Hello David,
Thank you for the extra food for thought. As I say, I'm only an observer in
all this but I enjoy trying to understand what is going on and some accurate
figures are interesting to compare.
As a further point of interest, do you have the MP settings and RPM for each
of the figures quoted?
Cheers
Kingsley
ami(at)mcfadyean.freeserv
PostPosted: Sun Nov 15, 2009 3:24 am    Post subject: does rotax need egt? Reply with quote
By way of comparison for a normally aspirated engine (912S), in a full power
climb from 2000' to 6650' (at OAT +5C (at) 2000' and QNH 1005), fuel flow
dropped from 4.0 to 3.7 imp.GPH.
I've not worked out the percentage power loss due to air density, but would
guess that this was more than the % drop in fuel flow. Engine speed was a
constant 4800rpm throughout. No EGT data available, which would have shown
any richening of the mixture with altitude (as I recall, EGT does usually
get less with altitude on this engine, but not greatly).
Duncan McF.
