Question about AN Fittings
kearney
PostPosted: Mon Nov 09, 2009 5:17 pm    Post subject: Question about AN Fittings Reply with quote
Hi
I have some AN nipples that I want to install on a Matco parking brake. As these connections are not compression fittings, should I be using anything like Teflon tape on the joints?
Inquiring minds need to know
Les
#40643 still in fibreglass hell but out on a day pass
ricksked(at)embarqmail.co
PostPosted: Mon Nov 09, 2009 5:23 pm    Post subject: Question about AN Fittings Reply with quote
Ooooooh. I wish I had AN nipples!!! Smile
Sent via BlackBerry by AT&TFrom: "Les Kearney" <kearney(at)shaw.ca>
Date: Mon, 9 Nov 2009 18:16:08 -0700
Subject: RV10-List: Question about AN Fittings
Hi
I have some AN nipples that I want to install on a = Matco parking brake. As these connections are not compression fittings, should = I be using anything like Teflon tape on the = joints?
Inquiring minds need to = know
Les
#40643 still in fibreglass hell but out on a day = pass
msausen
PostPosted: Mon Nov 09, 2009 6:05 pm    Post subject: Question about AN Fittings Reply with quote
I always knew Rick had some Freudian issues…..
Anyway, no Teflon tape.  Tapes are bad.  Use a good quality pipe dope (aka pipe thread sealant) that is fuel resistant.  You should be able to find something from your local NAPA type place.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com
Sent: Monday, November 09, 2009 7:22 PM
Subject: Re: RV10-List: Question about AN Fittings
Hi
Les
  _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D_-=3D_-=3D       -- Please Support Your Lists This Month --_-=3D           (And Get Some AWESOME FREE Gifts!)_-=3D_-=3D   November is the Annual List Fund Raiser.  Click on_-=3D   the Contribution link below to find out more about_-=3D   this year's Terrific Free Incentive Gifts provided
5
6
7
8
9
_-=3D
_-=3D
_-=3D
_-=3D
_-=3D
_-=3D
5
_-=3D
6
_-=3D
7
_-=3D
8
_-=3D
9
ky·èžÛ"Í휢Z+ÓM4ÓGÚqç(º¸ž®w°r‹«‰êÏ•æ¬y+©¦Šíb‹«.+-±8b°Ê'¶'tg­J‰ža8ÁDA‰ûl6‹Þ™·«ŠËax 繩KŠËEºwQj+‑¬)brJ'¶‚¢{k‰»­Š‰åŠyzZ0¶‡âÚ.¶j+y¦èºÛaŠÌžj»zºâ~'­çˆÇ§¶+Þ'í²šè¾'^u¼€zº •ç-®'†·Ÿ†Ûiÿü0Á§«¡é^rÚâqÊ&à zº‑•ç-®'¢oÚNº)]z»¢‰,¶ŠÞjÞ~m§ÿðÃîŠW^®Æè¢K¢l0Á»¢•׫±º(’Ç(›ö‡¢g›º)mBÏjÞ~m§ÿðÃh™æîŠ[azZ\¢l0Â&y»¢–Ø^–—(›ö‹ŠËB¢{k‰»­Š‰Öy´¢µæ¡­çá¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨žm§ÿðà š¶º'‰Ë¢oÜ¢{k‰»­Š‰ÿi8ZžL¨¹ú+Ê‹«éÞ®‹¬²êi¢»LjÛC­©ex¸¬´fŠtáyuи¬´IšŠQh®é”±ëaxÆ­®‰ârÂâ²Ñ^jÛ«zÃZ¾(¶Ší¡ºèÂÇ­…隟"â²Û­ŠX­‰ë,¹ÈZ°¸¬µIÿJæìr¸©¶*'[1]·!Š÷’yªÜ„:0žZw°ÚÈèÂÇ‚…«E á¢Ú,…ªÞjwf¹Èf¹Èf¢·š†·Ÿ†Ûiÿü0Âf­®‰ârÇ(›óZ¾(¶ŠÑW]
ŠËa¶Úÿ 0™«k¢xœ±Ê&ü֝Э¢´U×Bâ²ßÚ0 Ñ8Ò[1]IaäT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›Šî寃çá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿köÿ~‰íþšÞýºËømš
rleffler
No, don’t use Teflon. Use fuel lube on the threads.
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Monday, November 09, 2009 8:16 PM
Subject: Question about AN Fittings
Hi
Les
www.aeroelectric.com
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
dlm46007(at)cox.net
PostPosted: Mon Nov 09, 2009 6:13 pm    Post subject: Question about AN Fittings Reply with quote
I have used either Teflon tape or fuel lube on the pipe threads. On the flared fittings nothing required. B nut compression of the flare is sufficient
Sent: Monday, November 09, 2009 6:16 PM
Hi
Les
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
n8zg(at)mchsi.com
PostPosted: Mon Nov 09, 2009 6:58 pm    Post subject: Question about AN Fittings Reply with quote
Now THERE’S a mental picture I didn’t need…
Phil.Perry(at)netapp.com
PostPosted: Mon Nov 09, 2009 7:13 pm    Post subject: Question about AN Fittings Reply with quote
I’ve seen hardware attached to nipples before, but I can’t say I’ve ever seen AN fittings.
From: ricksked(at)embarqmail.com [mailto:ricksked(at)embarqmail.com]
Hi
Les
5
6
7
8
9
_-=3D
_-=3D
_-=3D
_-=3D
_-=3D
_-=3D
5
_-=3D
6
_-=3D
7
_-=3D
8
_-=3D
9
¦~² NW]ŠË™¨Š˜z1¢°´¶°Š¢n öÿ~‰íþšÞýºËøm
n223rv(at)wolflakeairport
PostPosted: Mon Nov 09, 2009 8:04 pm    Post subject: Question about AN Fittings Reply with quote
He said AN nipples, not MAN nipples Smile
On Nov 9, 2009, at 8:21 PM, ricksked(at)embarqmail.com (ricksked(at)embarqmail.com) wrote:
[quote]Ooooooh. I wish I had AN nipples!!! Smile
Sent via BlackBerry by AT&TFrom: "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
To: <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Hi
Les
carl.froehlich(at)verizon
PostPosted: Mon Nov 09, 2009 9:51 pm    Post subject: Question about AN Fittings Reply with quote
I found the Tite Seal product to be excellent for pipe threads and for gaskets.  Here is the Aircraft Spruce link for the product: http://www.aircraftspruce.com/catalog/eppages/titesealit.php
Carl Froehlich
RV-8A (500 hrs)
RV-10 (putting stuff in the fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Monday, November 09, 2009 9:04 PM
Subject: RE: Question about AN Fittings
Michael
Subject: Re: Question about AN Fittings
Hi
Les
~, gӓ
