kearney
Posted: Sat Nov 07, 2009 7:05 pm Post subject: doors & latches |
Dave
I installed Steve Deniri's flush handles along with the flush locks. Go to
http://www.iflyrv10.com to see them. They were installed after the doors
were assembled - easily done. They are a very nice touch!
Don't forget to use the billet door blocks.
Cheers
Les
#40643 - Lost in fibreglass hell
MauleDriver(at)nc.rr.com Guest
Posted: Sun Nov 08, 2009 8:45 am Post subject: doors & latches |
I believe you can go all the way before installing the handle and/or
lock. The installation is an add-on to the base install. A very minor
mod to the main hardware assembly involves replacing the stock handle
and button with big button (don't remember the details since it was a
while ago). The billet flush handle and key lock can go in anytime.
I just finished the billet handle and key lock. They look good but I'm
somewhat sorry I didn't stick with the stock setup. Turning the stock
handle into a nice teardrop would remove a lot of the clunkiness.
Adding just the keylock would proved the added security if desired.
But it took a bit more time than I would have liked and I still have to
create some sore of bubble to contain the keylock and handle mechanism.
Both (either) are thicker than the door by a slight amount - a fact not
covered in the plans. And I worry a bit about the ruggedness of the
whole assembly in actual operations.
I don't recall what vintage billet handle and lock that I have but I did
get it over a year ago.
Bill "mounting the canopy - windows in by Christmas" Watson
rvdave wrote:
I'm at the point of assembling doors and want to change to the flush latches/handles. For those who have installed flush handles, how far can I go with assembly of doors before I need to alter plans for the alternate mechanism? Can I proceed as if I were going ahead with supplied parts and change later? I've seen a couple photos of the flush handles, but not sure how many different types are available or where to obtain them? Thanks in advance,
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p 71631#271631
dmaib(at)mac.com Guest
Posted: Sun Nov 08, 2009 6:59 pm Post subject: doors & latches |
I have been flying with the iflyrv10.com billet handles for about a
year now. They look nice and are working fine. However, if I was
doing it again, I would probably stay with the stock setup. Like
Bill, I worry a bit about the ruggedness of the assembly over the
long haul. It is a fair amount of work/time to install the billet
handles. Steve Dinieri is great to work with and puts out really nice
products. I am not disappointed with the product or the support. This
is just one of those things that seemed important to me a couple of
years ago, but looking at it from this vantage point, I don't think I
needed it. I do remember that at the time I bought the billet
handles, Steve's setup was the only one that preserved the very
important feature of the latching setup for the handle in the closed
position. That is pretty critical in the RV-10. That is the reason
that the stock handle is replaced with the button. I don't know what
the competing products look like now. I also put in Steve's door
locks and really like them. Very nice setup and easy to install.
David Maib
40559
Flying
On Nov 8, 2009, at 11:41 AM, Bill Mauledriver Watson wrote:
<MauleDriver(at)nc.rr.com>
minor mod to the main hardware assembly involves replacing the stock
handle and button with big button (don't remember the details since
it was a while ago). The billet flush handle and key lock can go in
anytime.
I'm somewhat sorry I didn't stick with the stock setup. Turning the
stock handle into a nice teardrop would remove a lot of the
clunkiness. Adding just the keylock would proved the added security
if desired. But it took a bit more time than I would have liked and
I still have to create some sore of bubble to contain the keylock and
handle mechanism. Both (either) are thicker than the door by a
slight amount - a fact not covered in the plans. And I worry a bit
about the ruggedness of the whole assembly in actual operations.
did get it over a year ago.
rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
