adj. hinges
MKIIIX040
PostPosted: Wed Apr 12, 2006 3:19 pm    Post subject: adj. hinges Reply with quote
Howdy all
Someone out ther has pictures of his adjustable stabilizer hinges on a Mk3EX. Could it be the preacher? I don't remember his name or web site.
Mk3EX
Maine
MKIIIX040
912UL
rlaird
PostPosted: Wed Apr 12, 2006 7:28 pm    Post subject: adj. hinges Reply with quote
At 06:18 PM 4/12/2006, you wrote:
Howdy all
This what you mean? (I took it off and painted it right after this photo
was taken.)
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
rlaird
PostPosted: Wed Apr 12, 2006 7:45 pm    Post subject: Re: adj. hinges Reply with quote
Sorry, here's the photo....
English u-joint
 Filesize:  70.63 KB
 Viewed:  609 Time(s)
Robert Laird
Houston, TX area
MKIIIX040
PostPosted: Thu Apr 13, 2006 5:48 am    Post subject: adj. hinges Reply with quote
Thanks Robert that pic may come in handy as I also need to raise the
trailing edge of my right wing. (seems a little too common)
I'm actually looking for adjustable horizontal stabilizer hinges.
Vic MKIIIX 912
Maine
MKIIIX040
912UL
Richard Pike
PostPosted: Thu Apr 13, 2006 7:52 am    Post subject: adj. hinges Reply with quote
Here is how we did it. You could add a couple extra holes to the
brackets and see which worked best.
http://www.bcchapel.org/pages/0003/FSIIelevatorbracket.html
Richard Pike
MKIII N420P (420ldPoops)
Vic MKIIIX 912
Maine
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Thu Apr 13, 2006 8:15 am    Post subject: adj. hinges Reply with quote
Richard P/Gang:
Got a lot riding on that Tractor Supply steel strap. Could be as
strong as 4130. Maybe not.
I would go with 4130 on an airplane, especially in a critical area
like the horizontal stabilizers.
My thoughts for what they are worth. What you paid for them.
"Nothing fancy, got a length of .080 x 3/4" steel strap from Tractor
Supply, cut out four brackets, and drilled three 3/16" holes in each
bracket."
MKIII
Eugene Zimmerman
PostPosted: Thu Apr 13, 2006 9:00 am    Post subject: adj. hinges Reply with quote
John,
Did you see the bracket?
Those original stainless brackets on the horizontal stabilizer will
fail long before preacher Pike's tractor supply straps ever do.
On Apr 13, 2006, at 12:15 PM, John Hauck wrote:
Richard P/Gang:
bracket."
MKIII
PostPosted: Thu Apr 13, 2006 9:43 am    Post subject: adj. hinges Reply with quote
Gene/Gang:
Yes I did see them.
No, I do not have them installed on my MKIII.
Don't think anyone has heard me rave about the durability of the SS
brackets that Old Kolb began using many years ago.
Yes, there have been some failures of the SS brackets, one relatively
recently.
I still stand by my own standards of not using unknown steel on an
airplane, especially on a critical area. That piece of TSC steel
strap my last forever, or maybe a day. I don't know and am not
willing to bet my ass on it.
Take care,
MKIII
PostPosted: Thu Apr 13, 2006 9:52 am    Post subject: adj. hinges Reply with quote
will
I might add, SS is far less fatigue resistant that carbon steel.
MKIII
Eugene Zimmerman
PostPosted: Thu Apr 13, 2006 10:19 am    Post subject: adj. hinges Reply with quote
MKIII
Yup, I'd like to see kolb come up with a better solution for this
vulnerable part.
It may be adequate for flight loads but I know from experience that
that part gets a real workout at times when ground handling the plane.
It is so easy to grab on to the LE of one horizontal stab at that point.
Gene
MKIIIX040
PostPosted: Thu Apr 13, 2006 11:31 am    Post subject: adj. hinges Reply with quote
Thanks Richard ,gives me ideas at the very least.
Maybe I should run a length of cable around the boom tube an through both
stabilizers just incase. lol
Vic
MKIIIEX 040
912 spacerless Damn it $$$$ never ends
MKIIIX040
912UL
Richard Pike
PostPosted: Thu Apr 13, 2006 12:58 pm    Post subject: adj. hinges Reply with quote
No way it is as strong as 4130. That's why it is eighty thousandths. Per
bracket.
Two per side. To hold two 1/16" thick stainless tangs that are stressed
in twist.
The stress point in that whole assembly is where the tangs are riveted
to the stab.
Which is made out of .049 aluminum tubing. Which is stressed in twist
against the rivet.
Yet you are correct, 4130 would have been more "airplaney,"
but with the original Piper J-3's, J-4's, and J-5's being built out of
1020 mild steel,
and still doing fine today, I doubt I'll lose any sleep worrying about a
couple 3"
long mild steel long brackets that are .080 thick, with the load running
favorably to the bracket.
Does that mean that we can use mild steel just anywhere and get away
with it?
Certainly not. And now that this has come up, I will go back and modify
the web page,
deleting the reference to Tractor Supply so as not to encourage bad habits.
No way would I want to encourage anybody to do anything unsafe.
But I don't plan to change out the present brackets...
Richard Pike
John Hauck wrote:
Richard P/Gang:
bracket."
MKIII
Richard Pike
Kingsport, TN 3TN0
