XS Cooling Briefing
budyerly(at)msn.com
PostPosted: Fri Nov 06, 2009 10:16 am    Post subject: XS Cooling Briefing Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Guys,
I intended to deliver a briefing at Rough River on cooling issues for the Europa XS and lead a discussion but weather and house repairs prevented my being there. I have cleaned up my notes and decided to put my solutions and ideas out there in a document. Many of you have already beaten this dead horse, but I figure it may be a reference, along with other references included, to give those of you something to do when building/modifying over the normally long cold winter, as augmented by global warming/climate change in select areas of course.
The briefing has been attached as a pdf file as it has photos and drawings. I don't have time until XMAS to get this on my website so you can see a larger picture. Too much work and not enough time I'm afraid.
Apologies for the tome.
Bud Yerly
Custom Flight Creations
US Europa Dealer/Builder/Fixer-upper
Aircraft_Cooling_101_for_Tractor_Engine_Installation2.pdf
 Filename:  Aircraft_Cooling_101_for_Tractor_Engine_Installation2.pdf
 Filesize:  1.48 MB
 Downloaded:  1177 Time(s)
