N443DM 1st Flight photos
DanM
PostPosted: Thu Nov 05, 2009 9:36 am    Post subject: N443DM 1st Flight photos Reply with quote
Here's a few photos taken at Hanford,Ca. airport of the 1st flight on 11/1/09
Climb Out
 Filesize:  1.85 MB
 Viewed:  6310 Time(s)
 Filesize:  2.87 MB
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
akflyer
PostPosted: Thu Nov 05, 2009 11:00 am    Post subject: Re: N443DM 1st Flight photos Reply with quote
Good looking bird! I envy the windsock hanging straight down. Winds here have been 30+ knots for a week. Had one day that the winds were gusting over 65 knts.. was lifting one float out of the water about 2'. Was darn lucky my buddy was keeping an eye on my plane for me and moved some pallets of brick down to the edge of the lake and tied my plane down good... except he got out of the bob cat he was using to move the pallets and she took a swim LOL. he tied the plane down, heard a wierd burble burble glug glug and looked around... no bobcat... then he saw about 3" if the top rack sticking out of the water.... I told him he shoulda left it there, it would have made a good tie down LOL
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
PostPosted: Thu Nov 05, 2009 12:07 pm    Post subject: N443DM 1st Flight photos Reply with quote
Dan-
It looks (from the picture) like your exhaust pipes protrude through
the lower cowl...it this correct? You might not be aware, but if you
flip flop the muffler, the exhaust pipes will exit right through the
lower cowl rear opening without making nary a cut into the cowl. When
I got my engine, I cut two big holes in the cowl for the pipes then
somebody let me know about the flip flop capability of the muffler.
It sure makes taking the lower cowl off a lot easier.
Lynn Matteson
Jabiru 2200, #2062, 807.7 hrs
Countdown to 1000 hrs~193 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Nov 5, 2009, at 12:36 PM, DanM wrote:
<danm(at)powerdesignelectric.com>
on 11/1/09
Dan Mc Intyre
Kitfox IV , Phase 1
Jabiru 2200 , 4.0 hours
Sensenich 62x46
N443DM
Lynn
Kitfox IV-Jabiru 2200
N369LM
DanM
PostPosted: Thu Nov 05, 2009 2:21 pm    Post subject: Re: N443DM 1st Flight photos Reply with quote
Lynn, they do go out through the cowl! I wasn't aware that the muffler could be reversed- bummer- cut two big holes in the cowl, thanks for the info.
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
Lynn Matteson
PostPosted: Thu Nov 05, 2009 6:48 pm    Post subject: N443DM 1st Flight photos Reply with quote
If you look inside my lower cowl there are two oblong patches in it
from my repair job. Making mine worse was the fact that the pipes out
of the Jabiru muffler were splayed at an angle, requiring that the
holes be even larger than necessary just to make it through the cowl.
All you have to do is turn the muffler end-for-end, and the pipes
will go "back and down" instead of "down and back". Easier to do than
to explain why. But be sure to support the pipes with a flexible
hanger like an automotive tail pipe hanger, or a stainless steel
cable up to the lower firewall. The unsupported length of those pipes
will vibrate and break off and you don't want that...neither did I,
but it happened to me and I could have had a bad fie as a result, but
I got lucky. So please support those pipes.
Lynn Matteson
Dan Mc Intyre
Kitfox IV , Phase 1
Sensenich 62x46
N443DM
http://forums.matronics.com/viewtopic.php?p 71259#271259
Lynn
N369LM
