mullokintyre
Posted: Wed Nov 04, 2009 6:17 pm Post subject: RV-List Digest: 7 Msgs - 11/03/09 |
"Ralph E. Capen" SAID
| Quote: | . I was told that the engine
should not be attached as the road bounces would cause damage.
Ralph
Wow, all that bouncing around taxiing on rough strips, t
hose multiple landings I often do,
the rollouts on gravel strips etc
must be doing a lot of damage is this theory is true!
Sometimes you can't believe everything you are told.
Mick the skeptic
dale1rv6(at)comcast.net Guest
Posted: Fri Nov 06, 2009 3:22 am Post subject: RV-List Digest: 7 Msgs - 11/03/09 |
I think only half the idea was expressed. The real concern would be to mount
the engine on a temp basis, with bolts to the firewall NOT torqued properly.
Then it could bounce around and hammer the mount area. Similar lesson to the
story of the canopy that was not secured. Same could happen if wings were
not properly secured.
Dale
