jareds(at)verizon.net Guest
Posted: Sun Nov 01, 2009 10:50 am Post subject: Ducatti 582 Ignition needed |
Wierd thing going on. Both Rear plugs have hot spark but front plugs
have weak spark. Engine seems to try to run on one cylinder when i try
to start it. I know that each cylinders plugs are fired by each coil so
does this mean that one top or bottom side of each ignition module is bad?
There is some heat damage to the front ignition. I can see on the wires
where it may have gotten warm enough to melt wiring etc... but the rear
one looks fine.
Does someone have one or two ignition modules laying around that are new
or used but that are working?
Thanks.
