Mike Whisky
Posted: Sun Nov 01, 2009 1:32 pm Post subject: First successful test of windscreen antenna |
I just wanted to share my first positive experience with the windscreen antenna taped to the center bar. I tested it by holding the center bar at the right angle and attached my handheld radio to it. I had no problems listening to Zurich tower although being inside a concrete building.
I glued the strip to the bar and covered it with black tape (see attached photos)
Cheers
Michael
911.32 KB |
19217 Time(s) |
590.35 KB |
19217 Time(s) |
883.45 KB |
19217 Time(s) |
_________________ RV-10 builder (flying)
#511 |
Posted: Sun Nov 01, 2009 2:32 pm Post subject: First successful test of windscreen antenna |
I will have two radios, and I plan on putting the antennas in each side
windshield post in the fiberglass top. Not the most ideal place
....no good ground plane right there ..... but it's better than letting
them hang outside, or horizontal as in the wingtips. I have a friend
with an RV-6 that removed his antenna that was stuck to the center bar.
Linn
Michael Wellenzohn wrote:
Posted: Sun Nov 01, 2009 6:37 pm Post subject: First successful test of windscreen antenna |
Help me with this please - I had one similar - on the windscreen. Had it
tested by a bunch of HAM radio guys - they said it was too short causing the
SWR to be bad. I had made it longer in hopes of cutting it doen during
testing. It seemed to receive OK but couldn't get anyone to hear me.....
How long is yours?
Have you tried it in flight?
What led you to taping it to the center post?
Is it insulated from the center post only by the paint?
Ralph Capen
RV6A N822AR (at) N06 39hrs
Collecting a bunch of -10 parts already......
jdalmas(at)yahoo.com Guest
Posted: Mon Nov 02, 2009 6:01 am Post subject: First successful test of windscreen antenna |
The antenna should be 1/2 wavelength long.
So, at 122.7 MHz, and with a speed of light at 3 x 10**8 m/sec, 1/2 of the wavelength is 1.22m or about 48inches.
Check out this website for way more info....
http://k9erg.tripod.com/theory.htm
John Dalmas
RV10 397
working on instrument panel
--- On Sun, 11/1/09, Ralph E. Capen <recapen(at)earthlink.net> wrote:
[quote] From: Ralph E. Capen <recapen(at)earthlink.net>
Subject: Re: First successful test of windscreen antenna
Date: Sunday, November 1, 2009, 9:30 PM
"Ralph E. Capen" <recapen(at)earthlink.net>
windscreen. Had it
short causing the
How long is yours?
Ralph Capen
Kellym
Posted: Mon Nov 02, 2009 6:42 am Post subject: First successful test of windscreen antenna |
Most aircraft antennas start with 1/4 wavelength, not 1/2. So 24" is
more likely to fit the space available.
John Dalmas
RV10 397
> To: rv10-list(at)matronics.com
> windscreen. Had it
> short causing the
> How long is yours?
> Thanks,
> Ralph Capen
KCHD |
AirMike
Posted: Mon Nov 02, 2009 7:58 am Post subject: First successful test of windscreen antenna |
I was advised by Aerotronics in Billings Mt and at least one other avionics shop to just use a regular external antenna (which I did) for the COM. I was able to buy a used Cessna Commant antenna at OSH two years ago for about $30-$35. It works flawlessly. I did however use the same installation as Michael for the NAV antenna. As I recall it is 24 or 25 inches long. I bought the Van's product which is essentially a piece of copper foil glued to the headliner just behind the windshield. Connect it with a piece of coax cable run thru the steel cabin support strut I tested it's reception yesterday over the Fallon, NV - Hazen VOR. I got good reception on all points of the compass. I was worried about the reception driving away from the VOR when the tail cone blankets the signal, but it worked fine.
_________________ See you OSH '18
Q/B - sold. |
Bob Turner
Posted: Mon Nov 02, 2009 11:25 am Post subject: Re: First successful test of windscreen antenna |
Use a half wavelength if you cut the wire in the middle, and feed each side with the coax (center to one side, braid to the other).
Use a quarter wave length if you mount the feed end over a "ground plane" (a large conducting surface - maybe the glare shield is large enough). Attache the center conductor to the wire, the braid to the ground plane.
Either of these gives a reasonable match to 50 ohm coax. But nearby metal may change the match by quite a bit, so don't be surprised if taping to the cabin support bar doesn't match all that great. Or maybe it will, all depends on the details. The fact that the cabin support bar is not perpendicular to the glare shield will change things, too.
Modern receivers are very sensitive and will work with lousy antennas. The real test is if the tower can hear you when you transmit (especially with a low powered hand held). I can receive quite well on my handheld inside the cabin of a 182 with just the little rubber duckie antenna; but only transmit about 3 miles with this arrangement.
_________________ Bob Turner
RV-10 QB |
Mike Whisky
Posted: Mon Nov 02, 2009 1:37 pm Post subject: Re: First successful test of windscreen antenna |
My antenna strip is about 23 inches long but plus the cable its more like 24
reception is good but I didn't try to transmit yet.
The center bar is powder coated in flat black on top of the original gray.
Mike
#511 |
Phil White
Joined: 10 Jan 2006 Posts: 45 Location: Downers Grove, IL
Posted: Mon Nov 02, 2009 6:43 pm Post subject: Re: First successful test of windscreen antenna |
Because the center post is attached to the airframe, it is grounded. Having your antenna tightly attached to a grounded piece will probably de-tune it significantly, or at the least cause an odd radiation pattern on transmit.
I expect you will not find this antenna to work at all well.
It is recommended that you install the foil strip type on the inside of the fiberglass roof, where it is away from the metal of the airframe. Comm antennas need to be vertically polarized, so the best location is on the door post immediately behind the door. I have such a foil antenna for my handheld installed there, and it works well. (But for the main Comm, I rely on an external Comant on the belly, cause I know it will work well.)
Phil in IL, finishing at rotary engine install
Posted: Mon Nov 02, 2009 7:07 pm Post subject: First successful test of windscreen antenna |
Phil White wrote:
radiation pattern on transmit. I expect you will not find this
Or in front of the door. I'm going to try that place first.
Linn
I have
| Quote: | such a foil antenna for my handheld installed there, and it works
belly, cause I know it will work well.) Phil in IL, finishing at
http://forums.matronics.com/viewtopic.php?p 70659#270659
Phil.Perry(at)netapp.com Guest
Posted: Tue Nov 03, 2009 9:00 am Post subject: First successful test of windscreen antenna |
I'm glad someone finally said something. Every time I typed a response,
I sounded like a jack ass so I just deleted my message. But I'll just
come right out and say it. That's a lousy lousy choice for an antenna
location. Listening and transmitting are two separate things. To prove
my point, try attaching a coat hanger as an antenna and see how well it
will work to listen on - you'll be surprised at how well it works.
Shoot, even aluminum foil works for rabbit ears to receive television
stations.
I've designed and built several antennas over the years and can speak
from many years of experience and personal mistakes. So of those were
pretty creative like loading up a metal rain gutter as an antenna, a
flagpole, even an entire building.
There's absolutely no chance of that antenna ever tuning because of the
antennas position relative to the metal bar. But that did give me an
idea that'll probably still not work - but it's might be worth a shot.
That is to swap the steel bar out with a composite one. That might get
it, but you're still going to have some significant metal that could
interfere.
Another concern is with all that RF literally right on top of your
panel. EFIS, GPS, Engine Sensors (electronic) are all running right
there. Not to mention the RF will light up everything "inside" the
cockpit too. I've experienced my share of RF burns from touching metal
nearby a transmitting antenna - they're painful.
I apologize for sounding really negative, but I've been down this path
before. There are many better places to put an antenna but none any
worse.
Phil
AV8ORJWC
Posted: Tue Nov 03, 2009 10:51 am Post subject: First successful test of windscreen antenna |
Phil, don't feel like that.
Few of us builders have considered timely issues on RF signal
propagation and effective communication/navigation for future flight,
when building the RV-10 early in the process. The correct time to
identify components, select the correctly effective antenna and place it
on the airframe in the right location is early in the planning. Far
earlier than most have admitted. A wise builder does not need to spend
the money on the avionics but should have a solid idea of manufacturer,
model and placement of antennas.
Horizontal/Vertical polarity, proper ground plane installation, doubler
plates to accept the load and a solid transmitting radiation pattern
just might be beyond the casual builder. Before those who like to
criticize pipe in, I will offer a solution. Talk to Stein. Visit your
favorite avionics shop that will repair your components and plan for the
build rather than learning late in the completion.
Most of the time the components are selected far too late, mounted
structurally unwisely and fail to radiate a safe and effective signal
when needed most.
Skin mapping is a foreign word to most RV-10 builders. Few understand
the bio-physics of being a rear seat navigator in a Navy EA-6B.
Antennae arrays, mega wattage and lots of RF can fry valued private
parts. Anyone remember the cellphone scare of brain tumors years ago
from having the working end of the antenna so close to gray matter?
Any ham should have access to an SWR meter and the correct pigtail to
test your transmitted Wave. Some will even be able to plot the
effectiveness during broadcast. Others might get the antenna tuned at
one end of the spectrum and loose the opposite. Tuning can be an art
form. Aviation is about tradeoffs. Others will opt for a Garmin 530
which doubles the watts being shoved out the tuned end of the final
installation. When the pipe is the wrong length, when the ground plane
is ineffective, when the RF signal is masked externally by other
materials such as Plexiglas, fiberglass, carbon or aluminum the output
circuitry on the transmitter can take an expensive dump at the worst
time. Chasing kinked coax or improper crimped connections can be even
more challenging.
Get on board early in the build - learn from others. And thanks for
your perspective.
Don't forget to support Matt during the month of November!
John
W7COX
rv10builder(at)verizon.ne Guest
Posted: Tue Nov 03, 2009 1:17 pm Post subject: First successful test of windscreen antenna |
Phil;
Somehow I missed the reason for your apology. You used your experience to
relay to people that the idea is not a good one, there are many on this
forum who have no clue if it will work until it's tested, specifically me..
that is why I hold the feedback from all those builders who relay what has
worked for them. You have opened the dialog to have others give their
perspective, you have basically serve the group well in doing so.. so no
idea why the apology.
If you're apologizing for stating a fact based on experience, which it
sounds you're doing, keep it coming, not apologizing, but giving your
feedback so we don't follow in something that wont work..
Thanks!
Pascal
Sent: Tuesday, November 03, 2009 8:47 AM
Subject: RE: Re: First successful test of windscreen antenna
stations.
interfere.
worse.
Phil
Posted: Tue Nov 03, 2009 1:38 pm Post subject: First successful test of windscreen antenna |
Hi Pascal,
I never sent my original e-mail because I couldn't figure out how to
communicate the issue without sounding really really rude or offensive
and that's not my goal. So those messages got typed and then I deleted
them.
But Phil White cracked the door enough for me to open up for a few
seconds.
As John Cox mentioned, go find a ham who has been around for awhile and
ask them to visit your project for a few hours. If they're the
old-school type who built their own antennas and transceivers (AKA:
home-brew type), they'll jump right on the project and be able to
provide very valuable experience, tools, and measuring equipment.
I've heard that antennas operate on FM. That's not really true, there's
a science to it.
I'll let you figure out what FM is.
Phil
deej(at)deej.net Guest
Posted: Tue Nov 03, 2009 1:51 pm Post subject: First successful test of windscreen antenna |
On 11/03/2009 04:38 PM, Perry, Phil wrote:
| Quote: | I've heard that antennas operate on FM. That's not really true, there's
a science to it.
Another hint - our aviation COM radios work on AM frequencies
(Amplitude Modulation). You can find info on AM at
<http://en.wikipedia.org/wiki/Amplitude_modulation> and FM at
<http://en.wikipedia.org/wiki/Frequency_modulation> if you are
interested in learning more.
<http://www.arrl.org/> is a good place to start if you want to learn
about antenna construction.
fyi
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
MauleDriver(at)nc.rr.com Guest
Mike Whisky
Posted: Tue Nov 03, 2009 2:40 pm Post subject: Re: First successful test of windscreen antenna |
Hi Phil,
since I am the one who started the topic I thank you for sharing your insides here. I couldn't find any "real" answer before in the forum. My COM 1 is an external antenna and I thought that the com 2 would be fine on the center bar. Having read your statements above will change my installation.
Cheers
Mike
#511 |
Posted: Tue Nov 03, 2009 3:44 pm Post subject: First successful test of windscreen antenna |
Hey Mike,
I really didn't want to come across negatively.
Just looking at the airplane and thinking of creative places to install
a copper tape antenna, I'd suggest running a tape (or even wire) in the
vertical section aft of the main doors. This is the vertical area
(inside the cabin top) that is between the aft windows and the main
door. You'll be able to maintain vertical polarization by installing
here. Measuring my cabin top, I have around 30 inches vertical area for
the antenna to run inside at this location. About 22 inches of space
above the aluminum airframe - a key number as you'll see in the next
paragraph.
Just doing some quick math, you'll only need an antenna length of 22.11
inches to tune the antenna to 127mhz. (Middle of 118mhz - 136mhz
range). You can ground the braid to the fuselage (There's a really nice
longeron right there) and attach the center conductor to the copper
tape/wire. The base of the tape should be above the aluminum airframe,
so braid goes to the frame and the center conductor goes directly into
the vertical tape. (Does any of that make sense?)
You'll stand a better chance of getting a resonant antenna in this
location. I'm still a little concerned with that much RF being radiated
inside the cockpit, but it may not matter. Only testing the transmitter
with the avionics up and running will really tell the truth.
For your benefit, when calculating the antenna length you can use this
simple formula to get the quarter wavelength of the antenna. Quarter
wavelength = 234/(frequency in mhz)
The antenna I described is essentially a 1/2 wavelength antenna being
composed of a 1/4 wavelength radiating element (copper tape). The other
1/4 wavelength of the antenna is being made up from the aluminum
structure of the fuselage.
Let me know if I can help.
Phil
