Fuel level sender and tank removal with 7-WTA-1 cover
kmccune
PostPosted: Fri Oct 23, 2009 11:16 am    Post subject: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
What is the reason for moving the fuel sender to the side? It seems at the very least more leak proof on top.
And for those with the optional 7-WTA-1 wing tank cover two questions:
Can you remove the tank easily through the opening?
Can you use two per wing for dual tanks?
I ask because I am thinking of a second set of covers just in case I want to add a second set of tanks later.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
mksoucy(at)yahoo.com
PostPosted: Sat Oct 24, 2009 9:04 am    Post subject: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
What is the wta tank cover. I emailed zenair last week asking about an access panel on the top of the wing because I have serious issues burying the fuel tank. I was told no panel on top but I could make the top skin in two pieces and put an access on bottom between root and no.1 rib. Curious if anyone has seen other options.
Mike
701 scratch
Sent from my iPod
On Oct 23, 2009, at 3:16 PM, "kmccune" <kmccune(at)somtel.net> wrote:
What is the reason for moving the fuel sender to the side? It seams at the very least more leak proof on top.
Kevin
History is a great teacher if you take time to study it.
Steve Bennett
http://forums.matronics.com/viewtopic.php?p 69137#269137
kmccune
PostPosted: Sat Oct 24, 2009 3:53 pm    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
In didn't even check if this is still an option. It was emailed to me. But here is what I have.
Kevin
 Filesize:  34.56 KB
 Viewed:  13819 Time(s)
Dorothy McCune
bryanekholm
PostPosted: Mon Oct 26, 2009 12:52 pm    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
Kevin,
The wing tank access cover shown in the plans is what I am planning on doing with my wings. I see no problem with using a cover as shown. And it beats removing the whole top skin or half of a top skin to get at the tanks if necessary.
Bryan Ekholm
Scratch Builder
Bryan Ekholm
kmccune
PostPosted: Mon Oct 26, 2009 1:40 pm    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
This is not even shown in my plans, someone emailed me the above pic. I guess my question is can it be made for dual tanks too. I did yesterday on the Zenith builder site see that Ken P has dual tanks and a big opening in the skin, so presumably a big single cover.
Kevin
Dorothy McCune
kmccune
PostPosted: Tue Oct 27, 2009 11:32 am    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
Here is a link to Ken Podaimas' tanks
http://www.zenith.aero/photo/wing-tanks-1?context=album&albumId=2606393%3AAlbum%3A27640
Kevin
Dorothy McCune
bryanekholm
PostPosted: Wed Oct 28, 2009 6:57 am    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
Kevin,
Since I'm at my work computer, the zenith.aero website is filtered as a "social networking" site and won't display any of the pictures. I do get the text, but not the pictures. So if you it's possible, could you please attach the photo of Ken's wing tank cover to this topic string. This site is not filtered.
Bryan
Bryan Ekholm
kmccune
PostPosted: Wed Oct 28, 2009 12:44 pm    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
Her it is, my apologies to Ken for posting with out permission.
Kevin
 Filesize:  1.73 MB
 Viewed:  13726 Time(s)
Dorothy McCune
d.shrader
PostPosted: Mon Nov 02, 2009 1:43 am    Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover Reply with quote
Kevin
Just split the skin (lap joint) at the rib outboard of where the aux. tank goes that way you have one section of wing skin that can be removed that will expose both tanks and pluming behind the tank support and the plumbing at the main tank..... fuel leaks are a pita and there is no better insurance than easy access in my opinion
lap joint at last row of clecos
 Filesize:  857.92 KB
 Viewed:  13673 Time(s)
