adhesive
ejessee
PostPosted: Thu Oct 22, 2009 12:43 pm    Post subject: adhesive Reply with quote
I'm painting my 701 and putting all new rubber round wing roots, windshield, dash, etc.
What sort of adhesive have you guys used to hold that rubber in place? Especially around the wing roots, it seems that something will be required.
One more thing that is embarressing... Someone with a beautiful polished 701 gave me a McMaster Carr part number for their windshield trim. I have lost the email Embarassed If someone could tell me the part number for that windshield trim I am seeing from McMaster Carr, I would be greatful. I beg pardon for loosing it.
Thanks.
Ernest Jessee
N4931M
Tommy Walker
PostPosted: Thu Oct 22, 2009 6:33 pm    Post subject: Re: adhesive Reply with quote
Do Not Archive...
Was it me? I have a polished 701 and I bought my trim from Lockwood-aviation.com
Tommy Walker in Alabama
Tommy Walker
N25A - Anniston, AL
ejessee
PostPosted: Fri Oct 23, 2009 4:06 am    Post subject: Re: adhesive Reply with quote
Tommy,
It was "Dennis" in Michigan. I did get your reply as well and as always.. thank you. I think I'll go with the slightly larger trim if I can find the number.
I don't feel at liberty to post a full picture of his beautiful plane, but the trim I am looking for is in the attachment.
Are there pictures of your plane on the forum? I don't remember seeing it.
Thanks again.
 Filesize:  14.26 KB
 Viewed:  7669 Time(s)
Ernest Jessee
N4931M
dougsnash
PostPosted: Fri Oct 23, 2009 5:58 am    Post subject: adhesive Reply with quote
I got similar stuff to that from Aircraft Spruce. Don't recall the part number though.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- On Fri, 10/23/09, ejessee <eejessee(at)us.ibm.com> wrote:
Subject: Re: adhesive
Received: Friday, October 23, 2009, 7:06 AM
--> Zenith701801-List message
posted by: "ejessee" <eejessee(at)us.ibm.com>
Tommy,
attachment.
Thanks again.
Ernest Jessee
N4931M
http://forums.matronics.com/viewtopic.php?p 69042#269042
http://forums.matronics.com//files/windowtrim_159.jpg
Zenith701801-List Email Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
__________________________________________________________________
Curt.Thompson(at)verizon.
PostPosted: Fri Oct 23, 2009 6:16 am    Post subject: adhesive Reply with quote
The part I used was ACS 05-01500 ($.97/ft). Pictures is attached.
http://www.aircraftspruce.com/catalog/appages/opencenter.php
I used Permatex #80328 Weatherstrip Cement to glue it in place. It did not
work. I'm looking for something better to glue it. Anyone know of
something that works?
Curt
 Filesize:  43.39 KB
 Viewed:  7656 Time(s)
 Filesize:  32 KB
s.clive.richards(at)homec
PostPosted: Fri Oct 23, 2009 11:09 am    Post subject: adhesive Reply with quote
Hi Ernest
Ray used Poly Zap on his 601as recomended on zenith list
some years ago
Clive
ejessee
PostPosted: Fri Oct 23, 2009 11:17 am    Post subject: Re: adhesive Reply with quote
Thanks.
Do you know if Poly Zap will work for gluing rubber to aluminum on wing roots?
again... thanks for responding.
Ernest Jessee
N4931M
larry(at)macsmachine.com
PostPosted: Fri Oct 23, 2009 12:42 pm    Post subject: adhesive Reply with quote
Curt,
You might look up a product called Poly Zap. That's what I used for my
acrylic to trim rubber and it works well
for 4 years now. Only takes a drop each inch or so to the bottom of the
groove.
Curt
craig(at)craigandjean.com
PostPosted: Fri Oct 23, 2009 10:41 pm    Post subject: adhesive Reply with quote
Also as I recall you don't use a continuous bead. Instead use a drop every
inch or so.
-- Craig
