Lacing
ChangDriver
PostPosted: Wed Oct 21, 2009 8:33 pm    Post subject: Lacing Reply with quote
Bob:
You mentioned Dacron lacing as a good alternative to high temp wire ties in the engine compartment. Is there a good place to get the material and where would I find a tutorial on how to lace?
Craig
Neal.George(at)hurlburt.a
PostPosted: Thu Oct 22, 2009 4:31 am    Post subject: Lacing Reply with quote
Craig -
Stein carries lacing:
http://www.steinair.com/accessories.htm
Sixth item down the page.
And here's a link to Bob's shop notes on tying bundles:
http://www.aeroelectric.com/articles/cable_lace/cable_lace.html
neal
Bob:
Craig
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.04 KB
 Downloaded:  434 Time(s)
PostPosted: Thu Oct 22, 2009 6:03 am    Post subject: Lacing Reply with quote
At 11:33 PM 10/21/2009, you wrote:
<capav8r(at)gmail.com>
Bob:
I don't recommend a "running lace" for
aircraft wiring. Spot ties used on the same
frequency as you might use tie-wraps is
preferred. See:
Aircraft Spruce, Steinair, and many electronic supply
houses stock lacing tape. See:
http://www.aeroelectric.com/Mfgr_Data/Misc/Lacing_Tape/
My favorite is the Type II, Size 3, Finish B but
they're all suited to your task.
( -Thomas Paine 1776- )
ChangDriver
PostPosted: Thu Oct 22, 2009 3:29 pm    Post subject: Re: Lacing Reply with quote
Intersting as the avionics shop on my field said using wax covered lacing cord was not appropriate under the cowling. Comments?
Craig
PostPosted: Thu Oct 22, 2009 4:40 pm    Post subject: Lacing Reply with quote
The clove hitch methodology (I) leaves the knot
in tension and would probably be more secure
if not waxed. I've not had any knots come loose
when you tie 'em up like (II) . . .
http://aeroelectric.com/articles/cable_lace/cable_lace.html
The knot serves only to provide a "lump" that
stops the free ends from slipping though the noose-
loop, there's little or no tension on the final
knot.
Actually, I think the waxed cord gets you a tighter
knot because the string slides over itself easier
during the tightening process. But all the
listed tapes are better than nylon-tie wraps.
