tri gear line drawing
stranfaer(at)btinternet.c
PostPosted: Sun Oct 18, 2009 10:56 am    Post subject: tri gear line drawing Reply with quote
Does anyone have a side on view line drawing of a tri gear that they can let me have, I did have one a while ago that I used on a website but have given up after 3 hours searching and have decided to use the power of the forum
rgds
David J
Ivor Phillips
PostPosted: Sun Oct 18, 2009 11:39 am    Post subject: tri gear line drawing Reply with quote
Found a copy David,
regards
Ivor
rgds
David J
Europa_tri_gear.doc
 Filename:  Europa_tri_gear.doc
 Filesize:  132 KB
 Downloaded:  288 Time(s)
g-iani(at)ntlworld.com
PostPosted: Mon Oct 19, 2009 12:28 am    Post subject: tri gear line drawing Reply with quote
David
Yes with all sorts of level of detail and in almost any format you want.
Give me a call on 10483 714096 to discuss want you want.
Ian Rickard G-IANI XS Trigear, 280 hours
Europa Club Mods Rep (Trigear)
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Joyce
Sent: 18 October 2009 19:51
Subject: tri gear line drawing
rgds
David J
frans(at)paardnatuurlijk.
PostPosted: Mon Oct 19, 2009 3:44 am    Post subject: tri gear line drawing Reply with quote
Hi Ian, I sent you a private email but it appears that you didn't
receive it. I tried to call the number above (assuming it is an UK
number so I prefixed it with +44) but the I get a message that the
number is invalid.
What is the best way to contact you?
Frans
