Brake cylinder
jim.naylor(at)talktalk.ne
PostPosted: Thu Oct 15, 2009 5:42 am    Post subject: Brake cylinder Reply with quote
Be aware that you will also need a none return valve fitted between the
reservoir and the cylinder, otherwise the reservoir will just be an
extension of the cylinder with no advantage.
Jim
I have an ACS brake reservoir bottle. All I need is a decent place to put
it and a means
of plumbing it to the master cylinder.
Bob
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4509 (20091015) __________
The message was checked by ESET NOD32 Antivirus.
raimo.toivio(at)rwm.fi
PostPosted: Thu Oct 15, 2009 11:39 am    Post subject: Brake cylinder Reply with quote
Jim,
the reservoir in the cockpit is much easier to fill full and keep it also full. If it is transparent you will easily notice the level and fill again.
Anyway - you are right. No-return-valve makes it perfect. Just like in our cars and mcs has been always...
The valve; is it an integral part of the fluid bottle who knows?
Raimo
[quote] To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Sent: Thursday, October 15, 2009 4:39 PM
Subject: Brake cylinder
Jim
it and a means
Bob
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
