fuel transducer
rvdave
PostPosted: Wed Oct 14, 2009 6:39 pm    Post subject: fuel transducer Reply with quote
I'm at the point of installing the fuel lines, AFP fuel pump, filter, and wondering which fuel flow transducer should be used? Wondering if I should just wait to see which monitoring system I use and whatever transducer comes with it or plan around a more accurate or known stable device? What are your experiences?
Dave Ford
Cadillac, MI
orchidman
PostPosted: Thu Oct 15, 2009 3:22 am    Post subject: Re: fuel transducer Reply with quote
If you are going with AFS, it comes with the kit. I would put it up front and go with the stock fuel pump & filter in the stock location.
Some of the early AFS supplied transducers had a leak but were recalled by the manufacturer and the current ones are tight and accurate.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Strasnuts
PostPosted: Thu Oct 15, 2009 4:57 am    Post subject: Re: fuel transducer Reply with quote
RVDAVE,
I called Stein and asked them which transducer worked with AFS. They said the red cube which is the FT-60 not the flo-scan. So they shipped me one for 200 bucks and then they'll take that off the screen price when you purchase those down the road. I drilled out my stock location mounting rivets and filled with 3-3's. I saved the mount for mounting it in the firewall location since builders were having better luck and precision with that. Stock location works too, it gives you very little fluctuations from being so close to the fuel pump. I believe the transducer will work with a lot of different avionics. I really haven't decided mine yet.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
MauleDriver(at)nc.rr.com
PostPosted: Thu Oct 15, 2009 5:04 am    Post subject: fuel transducer Reply with quote
And if you are going with GRT, they have their own.
I think you want to wait until you decide on 1) the brand of the
equipment that will be reading it, 2) your equipment acquisition
method. The sensor is brand specific as far as I know and if you use a
Stein-type builder, they will get the sensor to you when needed. If you
are a DIY panel guy, you work with whoever you get the equipment from.
I don't think there's any hurry. The location(s) is easily accessible
later. Panel brand preferences will change. Acting sooner than later
could cost a few bucks. And read up on the location of sensor to reduce
fuel pump turbulence - I don't know if that's a real issue or not but it
has been discussed.
Bill "got to go to work" Watson
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 68022#268022
wcurtis(at)nerv10.com
PostPosted: Thu Oct 15, 2009 6:50 am    Post subject: fuel transducer Reply with quote
If you are going with AFS system, it is probably best to purchase the 6 CLY Sensor kit.  AFS packages the sensor kit separately.  In this kit are all the engine probes, sensors (including fuel flow) and wiring harness.  That way you can install and pre-wire all those items without having to shell out for the EFIS or EM until you need it.  Spruce has the 6 cylinder Sensor kit for $1,300.  All my sensors and probes are installed, my EFIS and EM wiring is done, but I still haven't purchased the EFIS or EM units yet.
http://www.aircraftspruce.com/catalog/avpages/af3400.php
As been mentioned previously, AFS uses the Electronics International "Red Cube" flow transducer.  I believe GRT still uses the original FloScan brand transducer.
William
http://wcurtis.nerv10.com/
On Thu, Oct 15, 2009 at 8:57 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
RVDAVE,
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=268039#268039
t Un/Subscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Matt Dralle, List Admin.
PostPosted: Thu Oct 15, 2009 6:59 am    Post subject: fuel transducer Reply with quote
Though physically different, electrically both the Electronics International (EI) "Red Cube" (used by EI and AFS) and FloScan (used by JPI, GRT, et al) are the same.
The FloScan part used to be the only game in town. Fuel flow sensors used to cost around $600.  EI developed their own electrically compatible "Red Cube" to offer with their line of engine instruments and the competition has brought the price of fuel flow sensors down to about $200.  Both units are fully TSO'd--not that it matter for experimentals.
William
On Thu, Oct 15, 2009 at 9:00 AM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote]--> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
I think you want to wait until you decide on 1) the brand of the equipment that will be reading it, 2) your equipment acquisition method.  The sensor is brand specific as far as I know and if you use a Stein-type builder, they will get the sensor to you when needed.  If you are a DIY panel guy, you work with whoever you get the equipment from.
I don't think there's any hurry.  The location(s)  is easily accessible later.  Panel brand preferences will change.  Acting sooner than later could cost a few bucks.  And read up on the location of sensor to reduce fuel pump turbulence - I don't know if that's a real issue or not but it has been discussed.
orchidman wrote:
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=268022#268022
List Un/Subscription,
Phil.Perry(at)netapp.com
PostPosted: Thu Oct 15, 2009 7:19 am    Post subject: fuel transducer Reply with quote
What does the G900X use?
Phil
From: William Curtis [mailto:wcurtis(at)nerv10.com]
Sent: Thursday, October 15, 2009 9:58 AM
Subject: Re: Re: fuel transducer
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
speckter(at)comcast.net
PostPosted: Thu Oct 15, 2009 7:57 am    Post subject: fuel transducer Reply with quote
FloScan
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Thursday, October 15, 2009 11:15 AM
Subject: RE: Re: fuel transducer
Phil
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
robin1(at)mrmoisture.com
PostPosted: Thu Oct 15, 2009 8:14 am    Post subject: fuel transducer Reply with quote
The G900X uses the UMA Fuel Pressure Transducer
I have had one go bad so far (under warranty).
Seems to me you need to know what avionics suite you are going to fly behind before purchasing the sensors.
Robin
Sent: Thursday, October 15, 2009 8:15 AM
Phil
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
Checked by AVG - www.avg.com
10/14/09 18:32:00
PostPosted: Thu Oct 15, 2009 8:21 am    Post subject: fuel transducer Reply with quote
Phil,
  Allow me to clarify the G900x sensor selection (attached).
Robin
Phil
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
10/14/09 18:32:00
 Filesize:  59.57 KB
 Viewed:  15077 Time(s)
FUEL_FLOW_TYPE_PAGE.PDF
 Filename:  FUEL_FLOW_TYPE_PAGE.PDF
 Filesize:  31.13 KB
 Downloaded:  3322 Time(s)
tsts4
PostPosted: Thu Oct 15, 2009 8:45 am    Post subject: Re: fuel transducer Reply with quote
Has anyone with using the EI "red cube" (or any fuel flow transducer for that matter) installed it the way EI suggests in the instructions, which is simply suspended between 2 sections of fuel hose and not hard mounted to any structure?
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
PostPosted: Thu Oct 15, 2009 9:42 am    Post subject: fuel transducer Reply with quote
Robin,
According to the document you sent the Fuel Flow transducer is Flo Scan.  The pressure sensors are UMA.
William
On Thu, Oct 15, 2009 at 12:16 PM, Robin Marks <robin1(at)mrmoisture.com (robin1(at)mrmoisture.com)> wrote:
Phil,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Perry, Phil
Phil
From: William Curtis [mailto:wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)]
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
10/14/09 18:32:00
 Filesize:  59.57 KB
 Viewed:  15071 Time(s)
I don't think UMA makes a flow transducer themselves.  If I was to guess, I would say that either EI or Flo Scan was the OEM for them.  Checking their site, they have the EI "Red Cube" transducer pictured.
http://www.umainstruments.com/FuelFlow.htm
The Flo Scan unit was the industry standard for decades and the electrical characteristics are well understood.  This is why EI chose to "clone" the characteristics--not to mention that they would not then have to change their instruments.
http://www.floscan.com/html/blue/aviation.php
Original Flow Scan
http://www.buy-ei.com/Pages/Miscellaneous/Misc_Flow.html
EI "Red Cube"
William
On Thu, Oct 15, 2009 at 12:10 PM, Robin Marks <robin1(at)mrmoisture.com (robin1(at)mrmoisture.com)> wrote:
Robin
Subject: RE: RV10-List: Re: fuel transducer
Phil
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
10/14/09 18:32:00
 Filesize:  26.4 KB
 Filesize:  30.71 KB
PostPosted: Thu Oct 15, 2009 12:54 pm    Post subject: fuel transducer Reply with quote
Correct, that is why I was specific on my first email “Fuel Pressure Transducer” then I saw what could be confusing and sent the PDF so Phil could have the official document detailing all units.
BTW I did have a problem with my Fuel Pressure and sent it back to UMA where they rebuilt it so maybe they do make their own which is not a comforting thought after speaking with them twice on the phone.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis
Sent: Thursday, October 15, 2009 10:42 AM
Robin,
William
Phil,
Robin
Phil
William
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
10/14/09 18:32:00
10/15/09 12:02:00
 Filesize:  59.57 KB
 Viewed:  15064 Time(s)
rvdave
PostPosted: Thu Oct 15, 2009 6:40 pm    Post subject: Re: fuel transducer Reply with quote
Thanks for the info and the photos. Now I realize the FT 60 is the red cube and the gray is the flo-scan. Actually I see now I have the flo-scan in my RV6 which came with my engine monitor, IK2000. I have it mounted in the engine compartment in a horizontal run before the mechanical fuel pump, where I was told would have the most accurate readings. It is not stable most of the time as I would expect it to be and my digital readout is always fluctuating, not sure if the FT60 would be any better? I believe that is the reason Matt Dralle sells the pulsation dampener? I don't have that but am tempted to try it.
I believe I will wait to see which monitoring system I end up with and use what has been tested with that system, thanks all.
Dave Ford
Cadillac, MI
ricksked(at)embarqmail.co
PostPosted: Thu Oct 15, 2009 6:58 pm    Post subject: fuel transducer Reply with quote
My red cube is ROCK solid....the engine sputters when the AFS 3500 says 29.5 gals used....never fluctuates and is mounted in "God forbid" the tunnel in front of the pump/filter.....FWIW...and it's flyin...IMHO which is based on flyin just my 2 cents worth...
Rick S.
N246RS
