fklein(at)orcasonline.com Guest
Posted: Tue Oct 13, 2009 10:13 pm Post subject: Mod 73 |
With the premise that the only stupid questions are those which aren't
asked, I have a couple for anyone who'd like to comment on this Mod 73.
As I recall, Mod 73 is a direct outcome of the initial concerns
following William Mills' tragic in-flight break up...particularly a
concern that the triggering event was one of the tailplanes moving
outboard and decoupling from the pins on the torque tube flange.
Following the grounding of UK-based Europas, Mod 73 was devised,
approved, and implemented on the entire UK fleet as well as on many
other aircraft based elsewhere. From the list prepared of those who
implimented Mod 73 (I don't believe) any instances were discovered or
reported of incipient failures.
Subsequently, the accident investigation (if I recall correctly)
determined that the triggering event was a failure caused by the
incorrect location of embedded aluminum plates on the inboard face of
a flap...a condition which precluded the proper threading for the flap
pin which was pulled free and destabilised the aircraft...a condition
totally unrelated to issues intended to be addressed by Mod 73.
If I am even partially incorrect thus far, please enlighten me.
So my questions are:
- Is Mod 73 a required mod for any aircraft based outside of the
UK?...particularly in the US?
- If not, why implement Mod 73 when there is no evidence that a
problem with the original design exists?
- Is Mod 73 an example of a prematurely arrived at "fix", approved and
implemented in a rush to get the Europa fleet airborne again before
the real culprit was determined...and...does it remain in effect today
out of a reluctance of regulatory agencies to set things right?
Thanks for any comments and input,
Fred
A194
frans(at)paardnatuurlijk. Guest
Posted: Tue Oct 13, 2009 11:27 pm Post subject: Mod 73 |
Fred Klein wrote:
| Quote: | why implement Mod 73 when there is no evidence that a problem
Because it makes sense. The changes imposed by mod 73 enhance the safety
of the aircraft. The pip pins are intended to hinder outboard movements
of the tail plane, not to take over torque loads. So changing the design
so that the parts involved can only do what they are supposed to do, and
nothing else, is a valuable improvement.
Whether a real accident has happened or not is not really my concern.
The good thing about the accident was that is was a reason to look again
with an eagle eye to the design of the Europa, and to correct any
(theoretical) flaws. Mod 73 was a result of that.
Frans
jonsmitheuropa(at)tiscali Guest
Posted: Wed Oct 14, 2009 12:04 am Post subject: Mod 73 |
Hi, I'm very happy to have completed this mod, if only for peace of mind. Whether or not the pre-mod design was actually a contributing factor to the failure or not may never be known for sure but the mod is a good one and I am now happy in my mind that it is certainly not possible for that potential problem to occur in the future. Any improvement in design is good in my book.
BTW, the wing failure and the addressing mod (74) was the rear wing root pin (that takes the pip pin), not the flap pin.
Cheers, Jon
Visit - www.EuropaOwners.org
johnwigney(at)windstream. Guest
Posted: Wed Oct 14, 2009 8:43 am Post subject: Mod 73 |
Regarding the tailplane retention issue, I attach some photos below of a
modification which precludes any chance of the tailplane becoming
detached. I think they are self explanatory. For those who get the
digest and have these photos stripped off, let me know if you are
interested and I can send them direct. This design is not mine and came
from Europe - my compliments to the original designer, I do not have a
record of his name. The end plug idea prevents enthusiastic helpers from
damaging critical components.
Cheers
ORIGINAL MESSAGE
Subject: Mod 73
other aircraft based elsewhere. -------------
europabill(at)bellsouth.n Guest
Posted: Wed Oct 14, 2009 10:14 am Post subject: Mod 73 |
John,
Can you send again? Didn't see any pictures...
Bill
A010 Europa Monowheel Classic
rlborger(at)mac.com Guest
Posted: Wed Oct 14, 2009 10:25 am Post subject: Mod 73 |
John,
How 'bout posting them on the Europa Owners site. Appropriate place would be a sub album in the "Builders photo album."
Bob Borger
On Wednesday, October 14, 2009, at 11:25AM, "John & Paddy Wigney" <johnwigney(at)windstream.net> wrote:
Cheers
budyerly(at)msn.com Guest
Posted: Wed Oct 14, 2009 10:51 am Post subject: Mod 73 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Fred,
Here is my two cents as an average builder:
Question 1
My Comment:
The US declares you are the builder of the aircraft. You may modify or choose not to modify your kit...It is your decision as the builder, as the kit manufacturer is a 49% helper, but you are the builder. Just as if you built the plane from scratch. It is highly recommended that all ADs/mandatory actions directed by your kit manufacturer be followed. If the UK's PFA or LAA grounds their planes, technically you don't have to ground your experimental, but as some kit manufacturers have found, the FAA can ground a kit if it believes losses are occurring due to design problems or recommended/directed construction procedures... Your plane is an experimental, each is technically different and the rules for FAA involvement in monitoring the accidents, as in certified aircraft, does not receive the same scrutiny... SLSA/ELSA have different rules like certified aircraft.
Question 2
My comment: This is a builder/maintainer issue. All builders are not created equal nor is care always taken putting the tailplanes on and off. Occasionally, the tailplanes are never taken off and rust on. When taken off for inspections, so much force is used, the inner and or outer bearing may be loosened and or broken loose and missed by the owner. I have also seen that in their maintenance exuberance, owners have sprayed oil into the stab holes and melted all the foam away from the bearings leaving only glass to support the outer bearing. Believe it or not some of the pip pin holes are so sloppy, pins can fall out and other methods are used to secure the pin and tail plane...
If built and maintained properly, you may never have a problem, but the Mod 73 tailplane mod, adds extra glass and support to ensure your outer bearing is solidly glassed and in fact glassed more solidly. Down side is you may need a longer pip pin. Oh well. Go to McMaster Carr.
Question 3
Comment:
Yes and no.
It is a quick and necessary bandaid to get the fleet flying abroad and properly inspect the fleet.
I would prefer to see all of us to use the Europa Club mod of a tube of glass supporting both bearings. This is a great mod, in my opinion, and should be the standard. The NG control surfaces bond in the bearings much more securely...Dare I say properly. But the bandaid of outer bearing reinforcement is a great way of getting more support around the bearing and checking the fleet.
The problem with the accident investigations is the cart and horse. What caused Williams accident for sure? He had two problems, both should have been caught and fixed during the build and through subsequent inspections. The tail plane wobble is a point I harp on constantly, that the stab should have no movement when attached. Yes, I disagree with wallowing out the tube to allow the movement. Andy and I have never seen eye to eye on this, but it doesn't hurt anything and should flutter begin, the outer bearing is free to move a little. Dare I say any flutter is BAD, and now you see why I disagree.
I have only found two flying aircraft with tailplane bearings broken here at the shop. But I have done all the tailplanes IAW the mods, because I believe it makes for a better product, and it is easy to sell a plane with all the mods properly documented.
As an accident investigator in a prior life, we all die a little when we loose a fellow aviator. It is our mission not to bury our loss by saying it can't happen to me, but to try to make the aircraft, procedures, or training better to save not just ourselves, but others who come after us so they don't have to experience our loss.
Just my thoughts.
Bud Yerly
[quote] [b]
jeff(at)rmmm.net Guest
Posted: Wed Oct 14, 2009 11:36 am Post subject: Mod 73 |
Well said Bud!!!
Jeff Roberts
Eagleville Marketing Group / www.eaglevillemarketing.com
615-355-7575 Office
615-406-8651 Cell
615-534-1082 Fax
"Not Advertising to save money is like stopping your clock to save
time."
On Oct 14, 2009, at 12:42 PM, Bud Yerly wrote:
| Quote: | Fred,
Question 1
My Comment:
Question 2
Carr.
Question 3
Comment:
Yes and no.
Just my thoughts.
Bud Yerly
3.21 KB |
4414 Time(s) |
Posted: Wed Oct 14, 2009 3:20 pm Post subject: Mod 73 |
Bud Yerly wrote:
| Quote: | Fred,
Bud Yerly
Bud
I couldn't agree more
Graham
Posted: Wed Oct 14, 2009 4:30 pm Post subject: Mod 73 |
On Oct 14, 2009, at 4:18 PM, Graham Singleton wrote:
| Quote: | > As an accident investigator in a prior life, we all die a little
> experience our loss. Bud Yerly
Bud
Graham
Graham...I too quite agree w/ Bud's sentiments.
In our common interest of making our aircraft better, would you
venture an opinion on the tailplane "fix" shown in John Wigney's
photos posted earlier today?
Fred
A194
Posted: Thu Oct 15, 2009 12:24 am Post subject: Mod 73 |
Hi! Fred
You probably weren't asking me about my opinion of the photo's of the fix
which John Wigney published but here goes anyway.
I think it is an excellent fix with one note of caution which is that I
don't like shaving down the flange of the drive plate. I would have thought
it possible to make the lever bent in the right places to still do it's job
as per the concept, without weakening the drive plate.
Like it or not you now have my humble opinion!
Bob Harrison G-PTG
Posted: Thu Oct 15, 2009 1:44 am Post subject: Mod 73 |
Fred Klein wrote:
imho John's solution is adding more engineering to fix a symptom. I
would prefer removing the cause, which is relying on the adhesion of
epoxy to stainless steel. Purely mechanical, no true bond. Better to
make a glass tube properly laid up onto the foam core and the ribs,
lined with a full length tube with lightening holes. Much more expensive
in labour but hey, we can always pay ourselves a bit less that day
The problem is the stainless inserts are not always circular and a bit
of swarf from the drillings make them jamb. Trouble!
Graham
peterz(at)zutrasoft.com Guest
Posted: Thu Oct 15, 2009 3:00 am Post subject: Mod 73 |
FWIW, In addition to fixing the original design problem as per the suggestiong below, I am planning on a simple stainless spring-clip on the tailplane which catches the drive-plate as a fail-safe backup.
Pete
A239
On Thu, Oct 15, 2009 at 5:43 AM, Graham Singleton <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote] --> Europa-List message posted by: Graham Singleton <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)>
Fred Klein wrote:
Fred
imho John's solution is adding more engineering to fix a symptom. I would prefer removing the cause, which is relying on the adhesion of epoxy to stainless steel. Purely mechanical, no true bond. Better to make a glass tube properly laid up onto the foam core and the ribs, lined with a full length tube with lightening holes. Much more expensive in labour but hey, we can always pay ourselves a bit less that day
The problem is the stainless inserts are not always circular and a bit of swarf from the drillings make them jamb. Trouble!
Graham
ist Un/Subscription,
www.matronics.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
Matt Dralle, List Admin.
kheindl(at)msn.com Guest
craigb(at)onthenet.com.au Guest
Posted: Thu Oct 15, 2009 3:54 am Post subject: Mod 73 |
" What is wrong with my simple fix of replacing the TP5 with a long TP5 reaching up to the TP6, ensuring that the TP6 cannot ever move inboard.
This also fixes another problem, namely the disbonding of the TP5s , which has happened to me on both tailplanes. "
Karl "
That is exactly what i did during the build. I sourced alloy tube with the same ID as the TP5/6 tubes, made it about 100mm longer
than the torque tube, so it runs from the inner plywood where the drive bushes are out past the central rib in the tailplane. It did require
a slight change in the build order, as i epoxied it into the foam before I created the rib, this however would be hard to do on a completed
tailplane.
craig
[quote] [b]
pjeffers(at)talktalk.net Guest
Posted: Thu Oct 15, 2009 5:21 am Post subject: Mod 73 |
Karl,
When taking the tailplanes on and off the friction produced by having 6 or 7 times the contact are between the torque tubes and the TP bushes would be enormous and add a significant weight penalty to an area with great lever arm IE CG considerations.
Re the plaster stuck onto stainless. This is the significant improvement made by the mod in that disbondment is now prohibited, by introduction of a physical barrier to migration of the bush. Previously it was only held in place by the adhesion of stainless to structure in one linear direction.
Pete
Posted: Thu Oct 15, 2009 7:23 am Post subject: Mod 73 |
On Oct 15, 2009, at 1:15 AM, Robert C Harrison wrote:
| Quote: | You probably weren't asking me about my opinion of the photo's of
the fix
Bob...au contraire...I welcome opinions from all sources...Fred
Posted: Thu Oct 15, 2009 7:41 am Post subject: Mod 73 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Karl,
The problem is friction of the tight fit of the TPs. The longer the bearing, the more force to get it on and off.
Making a tube of glass (using the method of wax paper or similar to keep the glass from direct contact) where both edges of the TPs have a lip which not only holds the bearing in shear, but in compression (via the lip) also. This would be slightly less force required on installation and removal, and as the tube passes into the stab, prevent a hard metal to metal impact on the outer bearing possibly creating a shock failure...
Of course I cringe in how some folks take their tail planes off and on. No bearing would stay put the way some are handled. It is all in balance and alignment as well as the oh so important patience.
As you have found, properly built and maintained tailplanes can last forever. Congrats on a well built stab.
You obviously did a fine job.
Bud
Posted: Thu Oct 15, 2009 8:24 am Post subject: Mod 73 |
Pete and Bud C
I don't agree with the friction theory. My tailplanes slide on and off with ease. If anything C it is easier now C as there is no lignup problem with the two separate tubes. The torque tube is always lightly greased for that reason C but also to keep corrosion of the torque tube at bay.e
I don't think that weight is an issue here. I use an alu tube and the difference between that and the shorter steel tube is really minimal.
Actually C an increase in tail weight is beneficial for many Europas C when you consider all the add-ons up front C like cs propeller C instrumentation C autopilot C cabin heat C you name it C compared to the original 80hp mono C on which the cg calculations were based.
Karl
Subject: Re: Mod 73
Date: Thu C 15 Oct 2009 09:19:16 -0400
Karl C
Re the plaster stuck onto stainless. This is the significant improvement made by the mod in that disbondment is now prohibited C by introduction of a physical barrier to migration of the bush. Previously it was only held in place by the adhesion of stainless to structure in one linear direction.
Pete
Posted: Thu Oct 15, 2009 9:23 am Post subject: Mod 73 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I see, you use aluminum tube. The aluminum tube is probably 1/8 larger (outside) and at .049 thick gives you about 3-4 thousandths clearance for a better slip fit. Hence our concern with friction, thinking you were using the stainless tube.
Bud
