Nick Leonard
Joined: 18 Jun 2007 Posts: 35 Location: Sacramento, CA
Posted: Tue Oct 13, 2009 1:29 pm Post subject: Flight Testing Process |
Does any have a good flight testing process document that they could share. Ideally, it would go through a stepped (flight-by-flight) process covering all of the items that should/could be checked, verified, calibrated and/or documented in a logical and thorough process.
Thanks in advance,
Nick
_________________ Nick Leonard
RV-10 (40015) Flying |
kearney
Posted: Tue Oct 13, 2009 2:13 pm Post subject: Flight Testing Process |
Nick
I received the ASA Flight Testing Homebuilt Aircraft book by Vaughan Askue
as my Matronics "premium" when I donated a few $$ last year. It looks
thorough enough but I haven't put it to the test yet!
Cheers
Les
#40643
kearney
Posted: Tue Oct 13, 2009 2:24 pm Post subject: Flight Testing Process |
Nick
Here is another book you might find useful. http://www.javifix.com/index.php
It is written by a Czech jet pilot I met at Kosh many years ago. He was in
the process of writing it at the time and I was impressed with what I saw.
Jerry (the author) was staying at the same house as me and was a very
engaging person - he had a very interesting story about how he defected to
France before coming to Canada.
Cheers
Les
#40643
coop85(at)verizon.net Guest
Posted: Tue Oct 13, 2009 8:33 pm Post subject: Flight Testing Process |
Nick,
Here's a couple things I've sent out before, one from when I was a First
Flight Advisor and another stolen from an RV-6 driver. I recommend you
check with your local EAA chapter to see if they have an advisor as there
might be more current info.
Have fun testing!
Marcus
40286
First_Flight_Script0001.pdf |
624.14 KB |
483 Time(s) |
FLIGHT_TEST_PROGRAM_BP.doc |
54 KB |
505 Time(s) |
tgesele(at)optonline.net Guest
Posted: Thu Oct 15, 2009 5:23 am Post subject: Flight Testing Process |
Nick C
6nbsp; Attached is the un-filled out version of the flight test program I 7m using E It 7s based on what others have done and the advice of local builders E I 7ve been doing one test card per flight and limit the testing to 2 per day max E
6nbsp;
6nbsp; Hope this helps E E
6nbsp;
- Tom Gesele N629RV Phase I
N629RV-Flight-Test.doc |
254.5 KB |
544 Time(s) |
