messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Sat Oct 10, 2009 11:16 am Post subject: Starter Cable and Engine Ground |
Hello
In the Z diagrams that I’ve seen, Bob shows wiring from the battery positive to the master contactor, then to the starter contactor. Some people wire directly from the battery positive terminal to the starter contactor instead, then to the master contactor. This seems like it would provide more juice to the starter and eliminate a short section of heavy cable. Is there a disadvantage to doing this?
And I understand it is best to ground everything to a common ground block on the firewall. Jabiru suggests grounding the starter case to the negative battery terminal. I would instead run this starter ground to the firewall ground block. Would this take the place of a separate engine block ground called out in the Z diagrams? If not, then where on a Jabiru 3300 would I connect for this ground? I would also have ground cable between the battery and firewall ground block.
Attached are pics from the Jabiru manual and service bulletin.
58.28 KB |
7143 Time(s) |
81.59 KB |
7143 Time(s) |
_________________ Dan |
Posted: Sat Oct 10, 2009 12:41 pm Post subject: Starter Cable and Engine Ground |
At 02:16 PM 10/10/2009, you wrote:
Hello
If the starter contactor or starter switch
sticks, there's no way to shut down a runaway
starter.
| Quote: | And I understand it is best to ground everything
The z-figures are a product of many years refinement
tailored to the single-engine light aircraft but are
not "carved in stone". What you propose would work.
One suitable conductor between the crankcase and central
point ground is sufficient.
( -Thomas Paine 1776- )
messydeer
Posted: Sat Oct 10, 2009 4:35 pm Post subject: Re: Starter Cable and Engine Ground |
| Quote: | If the starter contactor or starter switch
starter. |
Doh! I knew it must have been something simple I'd overlooked.
| Quote: | One suitable conductor between the crankcase and central
point ground is sufficient. |
Goodie!
Dan
