What to use for a cabin speaker and where to mount it?
MauleDriver(at)nc.rr.com
PostPosted: Fri Oct 09, 2009 7:23 pm    Post subject: What to use for a cabin speaker and where to mount it? Reply with quote
Not much in the archives... what have people installed?
Bill "fooling around with a PMA9000EX install" Watson
AirMike
PostPosted: Sat Oct 10, 2009 1:57 am    Post subject: What to use for a cabin speaker and where to mount it? Reply with quote
I got an inexpensive one at Fry's Electronics in Calif. - There, you can also get a nice durable and inexpensive grill to cover the speaker.
There is a specific OHM requirement which is probably in the manual for the audio panel. I cut a hole in the side panel at hip level in the right side of the back seat. Seems to work fine, but with all the excellent headsets out there - not sure it is really needed.
 Filesize:  120.03 KB
 Viewed:  2749 Time(s)
See you OSH '18
Q/B - sold.
dlm46007(at)cox.net
PostPosted: Sat Oct 10, 2009 2:45 am    Post subject: What to use for a cabin speaker and where to mount it? Reply with quote
Not required. Just another thing to break. Put jacks at all four seats and
an aux jack on the panel.
dave.saylor.aircrafters(a
PostPosted: Sat Oct 10, 2009 7:14 am    Post subject: What to use for a cabin speaker and where to mount it? Reply with quote
I mounted a 11-01569 from ACS in the upper section of the rear bulkhead.  Works great.
We put a doubler to beef up the cut in the corrugation, then the interior cloth went right over the speaker so it's invisible.
It's about 2 feet fwd of the AFS magnetometer, but it doesn't seem to affect it.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Fri, Oct 9, 2009 at 8:22 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
http://forums.matronics.com
le, List Admin.
