naumuk(at)windstream.net Guest
Posted: Wed Oct 07, 2009 1:11 pm Post subject: Matco brake installation |
All-
No response from Zenith on several subjects for the past couple of weeks.
Didn't receive any instructions for the installation of my Matco brakes+wheels. If anyone has the applicable information for an HD/HDS, please forward. Thanks.
Bill Naumuk
Townville, Pa.
HDS N601MG/Corvair 95%
Posted: Wed Oct 07, 2009 4:40 pm Post subject: Matco brake installation |
Hi Bill,
The Matco install is probably not much more than getting the orientation
of the brake correct for the rotors and at an angle that
will permit easy plumbing.
The picture of this gear shows the brake installed with the red cap on
the bottom and the brake angled down and to the rear.
This allows easy plumbing with the brake inside, or between the mains.
When installed this way, you should be able to jack the
fork and remove the wheel and rotor intact and without disassembly of
the brake assembly on the fork.
http://www.macsmachine.com/images/gear/full/forkscut.gif
http://www.macsmachine.com/images/gear/full/brakes2forks.gif
Then all you need is a tuff flex hose that can take the beating from the
brake to a connection with a standard brake line at the wing.
http://www.macsmachine.com/images/gear/full/tubetireandwasher.gif
Suggest the S83 Michelin 3.5 x 8.0 tires from a motorscooter
for $35.00 each with tubes that have bent stems. Farm and Fleet has
rubber fender washers that protect the tubes really well.
Hope this is helpful,
Bill Naumuk wrote:
| Quote: | All-
weeks.
Bill Naumuk
Townville, Pa.
MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Wed Oct 07, 2009 6:42 pm Post subject: Re: Matco brake installation |
HI Bill,
My Matco's on my HD came with generic instructions for installation (not Zenith Specific). I consulted with King Larry's website, found some photos and compared... Found that my brakes provided were slightly different than his but basically the same, the main thing that I found in Matco's instructions was to put the brakes on the rear whenever possible. Contact me offline and I'll see if I can snap a photo for you of what I did.
When in doubt, I consult Larry's website, all HD/HDS builders owe it to themselves to visit his site. THANKS SO MUCH LARRY!!! Youve saved hours of head scratchin!!!
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
Posted: Wed Oct 07, 2009 7:34 pm Post subject: Matco brake installation |
Larry-
I just emptied the shipping box for the first time today- parts and old
newspaper but no instructions. I was more concerned with how to mount the
rotor assembly to the fork than anything else. 1/4" SAE mounting the rotor
assembly, with no spacers between the rotor and fork? Thanks.
Bill
Posted: Thu Oct 08, 2009 6:59 am Post subject: Matco brake installation |
Bill,
Once you've spacer centered your wheel in the fork, the brake calipers
will bolt on and you can decide what may be needed to get the pads
float pattern centered each side of the rotors.
Larry
Bill Naumuk wrote:
Larry-
old newspaper but no instructions. I was more concerned with how to
mount the rotor assembly to the fork than anything else. 1/4" SAE
mounting the rotor assembly, with no spacers between the rotor and
fork? Thanks.
Bill
jlatimer1(at)cox.net Guest
Posted: Thu Oct 08, 2009 7:36 am Post subject: Matco brake installation |
Bill,
The Zenith site has an 6 page manual that I used to install my brakes.
http://www.zenithair.com/pdf-doc/6-gear.pdf
Have you seen it. I will also attach the PDF.
Jerry
matco.pdf |
219.01 KB |
945 Time(s) |
Posted: Thu Oct 08, 2009 9:19 am Post subject: Matco brake installation |
Jerry-
Just recently. Will try and make adjustments to my installation.
Bill
mosquito56
Posted: Mon Nov 23, 2009 4:36 pm Post subject: Re: Matco brake installation |
I am trying to find a diagram of how to connect a Mc5 master with a mc-4 slave. The slave has two holes but the master only has one.
Can someone expain or show picture of correct connections?
I assume that top of slave goes to resevoir and bottom goes to T on master then to the brake.
Help
_________________ Don Merritt- Laredo, Tx
psm(at)att.net Guest
Posted: Mon Nov 23, 2009 5:36 pm Post subject: Matco brake installation |
Hi Don,
I hope my memory is correct . . .
The master has a reservoir in the top of the cylinder. The single
port is for connection to the wheel cylinder . . .
The slave goes in the line between the master and the wheel cylinder.
I found a drawing on the Aircraft Spruce web site that shows which
end of the slave goes to the master and which goes to the wheel.
The fun part is figuring out how to get all the lines full of fluid
with no bubbles. The trick I learned is to do just the opposite of
what you do when you bleed brakes. With the lines and cylinders
empty you connect a pump and load of hydraulic fluid (airplanes don't
use brake fluid, they use the red stuff) and then pump fluid from the
bottom of the system all the way to the top of the master
cylinder. Suitable pumps can be something like a plastic ketchup
bottle or an oil can with one of those little pump handles built in
attached to the bleed valve on the wheel cylinder with a foot or two
of flexible hose.
Good luck,
Paul
XL awaiting release of upgrade kit
At 04:36 PM 11/23/2009, you wrote:
| Quote: | I am trying to find a diagram of how to connect a Mc5 master with a
Help
burbby
Posted: Thu Nov 26, 2009 7:59 am Post subject: Matco brake installation |
I'm not sure what your looking for but try this address:
http://matco.veracart.com/pdf/mastercylinder21a.pdf
--- On Mon, 11/23/09, mosquito56 <mosquito-56(at)HOTMAIL.COM> wrote:
| Quote: | From: mosquito56 <mosquito-56(at)HOTMAIL.COM>
Subject: Re: Matco brake installation
Date: Monday, November 23, 2009, 6:36 PM
"mosquito56" <mosquito-56(at)hotmail.com>
connections?
Help
Apologies if I seem antagonistic.
I believe in the freeflowing ideas and discussions
between individuals for assistance in this thing we call
life.
http://forums.matronics.com/viewtopic.php?p 74476#274476
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser. Click on
out more about
Gifts provided
www.aeroelectric.com
www.buildersbooks.com
www.homebuilthelp.com
-Matt
Dralle, List Admin.
Email Forum -
FAQ,
- MATRONICS WEB FORUMS -
