Posted: Fri Oct 02, 2009 7:50 pm Post subject: Basic Electrical Architecture for review... |
At 10:17 AM 10/2/2009, you wrote:
Quote: |
<handainc(at)madisoncounty.net>
Bob -
I'm a lurker on this site, but am in progress on a Pa22-20 project
(certified). How difficult would it be to use Z-11 in a certified
aircraft and get a 337 for that purpose? Has anyone done that
recently? Looks perfect for the project.
M. Haught
I have often fantasized about taking a nice
ol' rag-wing piper and updating the electrical
system with something like Z-13/8, all
new lightweight hardware and an RG battery.
I'm aware of no projects flying where one
has successfully run the gauntlet for
permission to do a good thing to an ageing
aircraft. Several folks have proposed such
upgrades and have received tentative blessings
on things like the forest of tabs ground bus
and fuse blocks. But those systems have yet
to be completed and signed off for flight.
( -Thomas Paine 1776- )
Posted: Sun Oct 04, 2009 12:11 pm Post subject: Basic Electrical Architecture for review... |
At 04:47 PM 10/3/2009, you wrote:
Bob - Sent this earlier but did not get a reply. Thought I would
send it again.
I found my reply in the out-box. Here it is again:
Bob -
M. Haught
handainc(at)madisoncounty Guest
Posted: Sun Oct 04, 2009 12:54 pm Post subject: Basic Electrical Architecture for review... |
Well, I was afraid that was what you would say, as I had no seen any
discussion of such a project while I have been on here. I guess I'm
stuck with the original. Looking at my fuselage, the wiring harness is
intact and actually, all of the wiring looks really good with no frayed
covering or corrosion on the attachment points. But it will not support
much in the way of avionics, etc.
Thanks, Bob -
M. Haught
Quote: |
<nuckolls.bob(at)aeroelectric.com>
> send it again.
> Bob -
> M. Haught
BobsV35B(at)aol.com Guest
Posted: Sun Oct 04, 2009 1:25 pm Post subject: Basic Electrical Architecture for review... |
Good Afternoon Marvin,
I would never qualify as an expert on electrical systems, but I did recently make a few changes which I feel are improvements to our 1955 PA-22-20.
I replaced every piece of wiring that could be reached without cutting the aircraft's fabric covering with nice new Tefzel wiring of the appropriate gauge. I replaced all of the original Circuit Breakers and most switches with new production substitutes. I removed the original CB panel and replaced it with a hunk of angle aluminum that extends left to right all the way across the bottom of the instrument panel. I also made new busses for all switches and CBs.
'Lectric Bob won't care for this next item, but I did add a radio master switch to feed an electronics buss.
I performed all functions in accordance with AC 43.13-1B citing appropriate paragraphs for documentation of suitability. All work was noted on a 337 and filed with the FAA. No local approval required as AC43.13-1B provides adequate documentation for an IA to determine whether or not the installation is in conformance with those provisions.
Our Pacer is now a very nice full WAAS equipped IFR platform!
Any help at all?
Happy Skies,
Old Bob
In a message dated 10/4/2009 3:55:58 P.M. Central Daylight Time, handainc(at)madisoncounty.net writes:
Quote: | --> AeroElectric-List message posted by: Marvin Haught <handainc(at)madisoncounty.net>
Thanks, Bob -
M. Haught
Posted: Sun Oct 04, 2009 3:02 pm Post subject: Basic Electrical Architecture for review... |
At 11:28 AM 10/4/2009, you wrote:
Quote: |
Hi Bob,
Thanks for taking a look at my architecture drawing. As to why it
differs from the recommendations in the Z-figures. Good
question. I hope my answers are as good (I have no inherent desire
to be "different").
- Removed the starter and associated support. (As I also removed it
from the aircraft. I saved the parts as I might want to reinstall
it (more appropriately wired) later.
Okay
Quote: | - Removed the primer (As I also removed it from the aircraft. This
might also be added back later in a more appropriately wired and
plumbed manner)
Hmmmm . . . must be a REALLY easy-to-prop engine . . .
Quote: | - Replaced the ignition switches with SPST as part of the removal of
the starter support features. If/when I re-install the starter I
intend to revisit the latest recommendations regarding connections
here and anticipate I will be replacing these with the progress
transfers as shown in Z11.
Okay
Quote: | - Rearranged the ground buses to match a pusher
configuration rather than the tractor configuration.
Okay
Quote: | - Redefined the avionics ground bus to be an audio ground bus. My
Nav/Com uses a differential audio path allowing separate audio/power
grounds. All the avionics power grounds, with the exception of the
low-power intercom return, terminate at the PNL Gnd bus. All audio
grounds (including the intercom power ground) terminate at the Audio Gnd bus.
- Reduced the number of connections tying the PNL ground to the
Audio ground as it no longer carries any significant current.
Can't comment on this without having understood/crafted
the system . . .
Quote: | - Replaced the regulator shown on Z11 with the one existent on the aircraft.
good
Quote: | - Added a stand alone low-voltage indicator as the existent
regulator (to my knowledge) does not support the feature.
always good
Quote: | - Replaced the ANL with one sized to the existent alternator.
okay . . . recall too that ANLs are VERY robust . . .
you can go as small as ANL30 with plenty of headroom
for 50A alternator.
Quote: | - Replaced the shunt with one sized to match the existent Ampmeter.
You have a 50A alternator?
Quote: | - Used a 20Amp blade fuse instead of a fuse-link for the regulator
power for reasons that are lost to history. I will be using the
fuse-link rather than 20A fuse approach. (I suspect that, back when
I did this, the recommendation for a fuse-link wasn't as obvious but
who knows...
My book is years old.)
. . . you can always download the latest Appendix
Z from the websit along with the change-pages from
the last revision. It's easy to keep your book up to
date.
Quote: | - Combined the endurance bus and main battery bus as the only items
on the main bus that have significant load are the position,
landing, and strobe lights and, if I end up with a (currently not
shown) backup path for the bus feed, the check list will list
specific loads to drop (e.g. turn off these lights) before enabling
the backup power path.
- Removed the bus alternate feed as I haven't (yet) justified it as
a worthy exception to the project guidelines (repair, not enhance as
this stage).
Re-read the explanation for an E-bus in Appendix
Z notes and chapter 17 on reliability. The E-bus
is for maximizing a limited resource (battery energy
stored) during alternator-out operations. It's also
a plan-B during battery contactor failure. Highly
recommended.
Quote: | - Removed the Battery Bus as I have nothing that would attach to it.
Okay
<snip>
Quote: | It occurs to me now that the cleanest way to add an alternate power
path (I don't like the approach I pondered on the schematic) may be
to (conceptually, relative to Z11) move everything except the
regulator power path from the main bus to the endurance bus (thus
the main bus effectively becomes the output contact on the
contactor). And then replace the battery bus and the alternate feed
switch with a fuse-link to a panel mounted breaker switch. (Ideally
a fuse link appropriate for 7-10 Amps, assuming such a thing
exists) My justification for the breaker switch in this application
that I want this resettable in flight given that I will be required
to manually load shed (i.e. turn off the lights) and, if I neglect
the check list and leave the lights on, I want to have a reasonable
recovery option.
I'm also still seriously considering leaving the alternate feed
path off until I revisit the electrical system during the
"enhancement" project to follow in a couple of years. For my current
project, I think the alternate feeds greatest value is, in the event
of a contactor failure, allowing my to keep my redundant source of
ignition (but it also allows me to keep my primary nav/com etc. which
is also nice
Your e-bus should supply power to goodies especially
useful for continued flight to airport of intended
destination without an alternator. This usually amounts
to a handful of electro-whizzies for a battery only
endurance that exceeds hours of fuel aboard
Posted: Sun Oct 04, 2009 3:05 pm Post subject: Basic Electrical Architecture for review... |
Quote: |
Hi Bob,
to be "different").
Correction, how about the electronic ignition. It has
its own power switch and is an excellent candidate
for battery bus power. If you got bad smells in
the cockpit you can power down the whole electrical
system without reducing engine support. Fuel pump
might run from battery bus too.
Posted: Thu Oct 08, 2009 9:23 am Post subject: Basic Electrical Architecture for review... |
At 08:50 AM 10/6/2009, you wrote:
Quote: |
Bob said:
>**These are exceedingly difficult to read**
Surprisingly enough, they work well for me but then they are much
closer to what I'm used to than the book format. I appreciate your
efforts none-the-less. I'll reformat extracts into your preferred
format (as I did with the "architecture drawing") when offering
things for you and the group to review in the future.
Don't redraw them on my account. I'm only saying that
the thought processes needed for analyzing functionality
and doing a failure mode effects analysis requires rapid
and definitive observation of electron pathways. The
road-map technique is find for manufacturing but still
impedes operational understanding.
Ultimately, you're the one who needs to work and live
with this project for the foreseeable future. By all
means, use what ever documentation techniques offer
you the greatest comfort.
