tuft/stall testing (with video)
Goto page 1, 2  Next
carlisle
PostPosted: Sun Oct 04, 2009 4:17 pm    Post subject: tuft/stall testing (with video) Reply with quote
http://www.youtube.com/watch?v=afPCxoogLic
Had some fun with wool tufts on my Model 2 wing today. I've always been impressed with the stall characteristics of if and wanted to see just how the stall progressed out the wing.
First thing everyone will notice is how the fabric, especially at the root seems loose and does a lot of oil canning. I had no idea this was happening until I saw this vid and quickly checked the fabric tension after this flight. It's nice and tight so I wonder if some of it is due to normal wing flexion and some is due to the violence of the slip stream where the prop wash interacts with the wing. Remember also that this plane was built in 1991 (by me) and at that time, Denney shipped the lightest Stits fabric available (1.7 oz) which I see now is reserved for ultralight use only. All Kitfox's since use the 'medium' weight 2.4 oz fabric. At least I think they do.
Anyway, the 1.75" twist I built into the wing seems to be working and the stall is nice and linear as it spreads from root to tip.
Next step. Vortex generators!
Chris Carlisle
Model 2, Rotax 582
Sioux Falls, SD
Lynn Matteson
PostPosted: Sun Oct 04, 2009 4:47 pm    Post subject: tuft/stall testing (with video) Reply with quote
1.75" ? WOW...that seems like a lot. Is this normal for the model II?
Seems like my model IV was 0.75" on each side.
Lynn Matteson
Jabiru 2200, #2062, 786.8 hrs
Countdown to 1000 hrs~213 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
think they do.
Chris Carlisle
Model 2, Rotax 582
Sioux Falls, SD
Lynn
Kitfox IV-Jabiru 2200
N369LM
carlisle
PostPosted: Sun Oct 04, 2009 5:07 pm    Post subject: Re: tuft/stall testing (with video) Reply with quote
Checked the manual again. 1.75 inches of twist is correct.
Chris
Fox5flyer
PostPosted: Sun Oct 04, 2009 6:00 pm    Post subject: tuft/stall testing (with video) Reply with quote
Excellent video, Chris. The most informative I've seen yet on this forum.
It makes me wonder if all of our Fox wings are doing the same thing when
under load. Of course, in your video there was no wing tank as most of the
later models have. Still, it would be interesting to see the same video of
later models.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
HTTP://www.youtube.com/watch?v=xIODNmGuQ0Y
Chris Carlisle
Model 2, Rotax 582
Sioux Falls, SD
http://forums.matronics.com/viewtopic.php?p 66493#266493
carlisle
PostPosted: Sun Oct 04, 2009 6:10 pm    Post subject: Re: tuft/stall testing (with video) Reply with quote
Thanks Deke. I've got the 13.5 gal fiberglass tank in the opposite wing. I agree it'd be interesting to see the fabric over there. The camera is still mounted. Maybe I'll turn it around and see what that looks like on my next flying day.
Chris
hlang(at)bluewin.ch
PostPosted: Mon Oct 05, 2009 2:16 am    Post subject: tuft/stall testing (with video) Reply with quote
Thanks a lot Chris. Please do the same with the Vortex Generators. That
will be even more interesting.
Regards:
Heinz
carlisle
PostPosted: Sun Oct 11, 2009 10:25 am    Post subject: Re: tuft/stall testing (with video) Reply with quote
http://www.youtube.com/watch?v=gor7LhsAILs
OK, here's the new video with Stolspeed vortex generators added.
Stall now happens around 30 mph instead of 35 and I can't get it to progress out to the tip of the wing, even trying to hold it (at) high pitch for a while with power on. The last stall does fall off to the right a little and this vid is of the left wing so I wonder if it didn't go ahead and go out to the tip on that side.
Also note; the flexing/flapping/oil canning fabric is no more. I did take a heat gun to the entire upper surface after seeing the first vid but couldn't really tell that that made much difference, at least to the 'feel' of the fabric tension. I suppose the fabric might have loosened over the years a little. One has to wonder though if the vg's are at least partially responsible for smoothing out the boundary layer and therefore the fabric a little too.
Guess I'll leave them on.
Chris
Fox5flyer
PostPosted: Sun Oct 11, 2009 5:26 pm    Post subject: tuft/stall testing (with video) Reply with quote
Again, another great video, Chris. Thanks. Please tell us more about your
VGs. Where you obtained them, how much you paid, etc. Also, how did you
determine exactly where to place them on the wing, especially the spacing.
Any other observations welcome.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 439+ TT
MichaelGibbs(at)cox.net
PostPosted: Sun Oct 11, 2009 9:43 pm    Post subject: tuft/stall testing (with video) Reply with quote
I agree! Do you have a picture of your camera rig (or did I miss it)?
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
dave
PostPosted: Mon Oct 12, 2009 3:39 am    Post subject: Re: tuft/stall testing (with video) Reply with quote
I did some testing of Stol speed's V G's a few years ago.
I have used both Stop Speeds and Harrison VGs. STolspeed are the best value as the adhesive comes with it and they have a less sharp trailing edge.
Mine are placed at 10% MAC -- I have never moved them around to optimize them. Mine are on a Model IV that has a different wing than yours.
I saw about 1 to 2 mph stall reduction at the most, no cruise speed loss. The biggest differance I found was there is no buffet on power off or power on stalls. You will just mush during power off stalls. Power on stalls when more aggressive there is no buffet or warning signs until the nose drops and usually a wing will drop as well.
http://www.cfisher.com/cowl.html
http://www.cfisher.com/vg.html
I got cooling gains by using VGs under the cowl after some cowl mods.
All the being said , I have over 700 hours in last 2 years and have not removed them or changed them yet.
If you do some searches on this forum you will find my comments likely about his topic.
Chris
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
carlisle
PostPosted: Mon Oct 12, 2009 6:28 am    Post subject: Re: tuft/stall testing (with video) Reply with quote
I used Stolspeed VG's. Kind of a cute little Mom/Pop operation out of Australia where the guy apparently got started using them on his Zenith in place of the big leading edge slat those planes have. He claims the vg's work better than the slat. The web page is very informative though and IMO has sound aerodynamic theory backing their installation.
http://www.stolspeed.com/
A generic set which includes 130 vg's, templates for installation, and some cool sheets of 3M adhesive that holds them tight but can be overcome with steady pressure so you can move them around is $97 (US). He doesn't charge for shipping.
The best evidence for an average plane is that they work about the same if placed within a certain range of the total cord of the wing (including flaperons), the best overall number being around 7% back from the leading edge. That's where I put mine and I haven't moved them. Stolspeed is very candid about how the experimentation he did within the recommended range didn't make much difference in overall performance.
The templates that come with are just simple rectangles of cardboard with slots cut out. The first 15 vg's beginning from the tip are spaced 30mm apart and are at a 30 deg angle to the slipstream. This is to ensure that the stall occurs at the wing tip last so as to preserve flow over any ailerons one might have (not applicable for us but still a good idea). Remaining are placed at the same angle but at 60 mm intervals all the way to the root.
I'll try and get a pic of the camera setup. Mean time, here's one of the wing showing the vg's more clearly than in the vid.
Model 2 Kitfox with vortex generators, left wing
 Filesize:  580 KB
 Viewed:  16793 Time(s)
hlang(at)bluewin.ch
PostPosted: Mon Oct 12, 2009 11:51 am    Post subject: tuft/stall testing (with video) Reply with quote
Hello Chris
Thanks for the very interesting message and video. Meanwhile I have also
put VGs on the elevator (5Cool and wings (68)and flown the first time with
them yesterday. I have a Kitfox IV with Rotax 582LC and warp drive 3
blade 70". My observations are: stallspeed 3..5mph lower, but only with
power on. This means, similar as yours. Secondly, the stall seems to be
better controllable, smoother as before. I have the feeling, that the
aircraft is more stable, specially in thight turns. I also will leave
the VGs on, because I think that it is an improvement and helps to land
"uphill" at mountain airfields and glaciers.
Heinz
carlisle
PostPosted: Mon Oct 12, 2009 2:25 pm    Post subject: Re: tuft/stall testing (with video) Reply with quote
Here's the camera setup. Just a cheap webcam shoved up through a hole drilled in the roof Lexan just where it meets the turtle deck. Gonna replace the Lexan this winter anyway. Everything held in place with nylon tie wraps. Laptop sits on passenger seat where I can fuss with it in flight. Plan to do some more vids with it facing foward and backwards!
Chris
Cam mount
 Filesize:  539.37 KB
 Viewed:  16758 Time(s)
FlyboyTR
PostPosted: Wed Oct 14, 2009 7:51 am    Post subject: Re: tuft/stall testing (with video) Reply with quote
Chris,
Great video's. Thanks for sharing with us! I've got to get me some VG's for my 5 (Vixen). I've got cracks in the paint showing up aft of the fuel tanks. I wonder if I'm having the same fabric flutter you were having?
If anyone has VG's on a 5 (or higher), please let me know your experience with them.
Thanks again!
FlyboyTR
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
Lynn Matteson
PostPosted: Thu Oct 15, 2009 4:14 am    Post subject: tuft/stall testing (with video) Reply with quote
What kind of paint did you use, Travis? If it was an automotive
paint, I've heard that could be the cause of the cracks.
Lynn Matteson
Jabiru 2200, #2062, 795.1 hrs
Countdown to 1000 hrs~207 to go
Status: flying
On Oct 14, 2009, at 11:51 AM, FlyboyTR wrote:
Chris,
Great video's. Thanks for sharing with us! I'm got to get me some
you were having?
Lynn
N369LM
ruebd(at)skymail.csus.edu
PostPosted: Thu Oct 15, 2009 6:40 am    Post subject: tuft/stall testing (with video) Reply with quote
Chris:
It looks like you enjoyed a sooner liftoff and possibly a better climb with the generators.
Did you fly at cruise? Did you fly at any of the speeds in the yellow region?
Duane N24ZM
FlyboyTR
PostPosted: Thu Oct 15, 2009 9:05 am    Post subject: Re: tuft/stall testing (with video) Reply with quote
Lynn,
I didn't paint the plane (I'm the second owner). However the logs show that is was a Poly.....something...??? purchased from Aircraft Spruce.
Travis
Travis Rayner
Mobile, AL
ADI-II Autopilot
Lynn Matteson
PostPosted: Thu Oct 15, 2009 12:00 pm    Post subject: tuft/stall testing (with video) Reply with quote
Probably Polytone, one of the Poly Fiber final color products.
Lynn Matteson
Jabiru 2200, #2062, 796.4 hrs
Status: flying
On Oct 15, 2009, at 1:05 PM, FlyboyTR wrote:
Lynn,
Aircraft Spruce.
Travis
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 68088#268088
Lynn
N369LM
carlisle
PostPosted: Thu Oct 15, 2009 5:40 pm    Post subject: Re: tuft/stall testing (with video) Reply with quote
Duane...Hard to say about the takeoff and landing rolls and how they were effected by the vg's. The wind here in South Dakota, especially this time of year is quite variable and I don't get a lot of choice when it comes to flying conditions. The plane got off the ground in such a short time without the vg's, I'm not sure I could tell!
Cruise speed seems down a couple of mph. I usually cruise right at 75 which is the beginning of the yellow arc on the Model 2.
An interesting idea that's been tossed out is to try VG's on the UNDERsurface of the wing. Theory is that because of the convex undercamber of the early Kitfox wings (through model 3) , there are areas of very low relative pressure that might be smoothed out and decrease overall drag (at) cruise speeds and angles of attack. I think I'll try some tufts there next time and see what happens.
Chris
thesupe(at)hotmail.com
PostPosted: Thu Oct 15, 2009 7:05 pm    Post subject: tuft/stall testing (with video) Reply with quote
Be sure to put lots of tuffs around where the lift struts connect to the wing.  Got to be some interesting turbulance between them.  I know I see small ripples in the fabric in that area while flying on my Avid B.  And thanks for doing these videos C it sure is interesting to see what is going on with the wings.  Take care C  Jim Chuk
[quote] Subject: Kitfox-List: Re: tuft/stall testing (with video)
Date: Thu C 15 Oct 2009 18:40:26 -0700
--> Kitfox-List message posted by: "carlisle" <carlisle_99(at)yahoo.com>
Duane...Hard to say about the takeoff and landing rolls and how they were effected by the vg's. The wind here in South Dakota C especially this time of year is quite variable and I don't get a lot of choice when it comes to flying conditions. The plane got off the ground in such a short time without the vg's C I'm not sure I could tell!
An interesting idea that's been tossed out is to try VG's on the UNDERsurface of the wing. Theory is that because of the convex undercamber of the early Kitfox wings (through model 3) C there are areas of very low relative pressure that might be smoothed out and decrease overall drag (at) cruise speeds and angles of attack. I think I'll try some tufts there next time and see what happens.
Chris
http://forums.matronics.com/viewtopic.php?p=268153#268153
Hotmail: PowerGBL/go/171222986/direct/01/' target='_new'>Get it now.
Goto page 1, 2  Next
Page 1 of 2
