Parts that dont fit
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List
aussiech650
PostPosted: Sun Oct 04, 2009 3:05 pm    Post subject: Parts that dont fit Reply with quote
I am building a CH650 in Australia and have found that my center wing spar is the wrong angle (XL601) and that the front fuselage side skins are also wrong (a mix of XL601 outer dimensions and CH650 pre drilled holes). As it will take some time for replacement parts to arrive down under, I would be interested to hear from anyone that is further along with the build (either CH650 or late XL601) that may be able to advise of other parts that are not correct so that I may have them all sent to me in one shipment. I believe that there may be an issue with the seat bottom? and maybe the top skin?
Greg Cox
Zenith Zodiac CH650, VH-ZDC
Sydney, Australia (Cecil Hills)
Email - greg(at)gas-n-go.com.au
Mobile - 0430002333
Fax - (02) 9823 9977
- The Matronics Zenith650-List Email Forum -
http://www.matronics.com/Navigator?Zenith650-List
alsmith
PostPosted: Mon Oct 05, 2009 4:37 am    Post subject: Re: Parts that dont fit Reply with quote
We are also building a 650. We had to add a 1/8" Shim to the bottom front of the Center spar to move it 5 degrees. The side skins were also incorrect. The seat and arm rest and the rear spare supports were also bent incorrectly. Zenith will send new parts, I suggest that you get undrilled side skins to insure the alignment and fit is correct. We have also informed Zenith that not having any Builders instructions for the 650 is making it much more challenging a project. To our knowledge there are zero available for the 650 modifications.
We have been informed that they are making these a priority to publish.
Al Smith
KEOS
Fuselage 650
z601a(at)anemicaardvark.c
PostPosted: Mon Oct 05, 2009 5:28 am    Post subject: Parts that dont fit Reply with quote
zero available for the 650 modifications. We have been informed that they
There are SOME things available, because they sent me 650 wing tips for the
601. when I asked for documentation, I was sent the wingtip drawings for the
650. It sounds as though things may not all that well coordinated.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
Larry Hursh
PostPosted: Mon Oct 05, 2009 6:18 am    Post subject: Parts that dont fit Reply with quote
To all,
I've called and talked to Roger D at Zenith in Mexico Missouri about my new style Todd's canopy. I told him trying to use the old instructional information is nothing close to the parts I was looking at. I am deathly afraid to cut my canopy in half without SOME type of correct information as to how to do it. He could see my point. He told me that a DVD was available on www.homebuilthelp.com that shows how to convert an existing 601XL to the new style canopy. I told him I see how it is if that was the "solution" to my problem - In other words, I buy the kit from them but I also have to buy the instructions from someone else??? Again, he could see my point after I explained it to him. He promised he was going to send a DVD to me....you might want to call Zenith as I did.
YES, there IS quite a few problems concerning a lack of forthcoming information on the new CH650....and YES, I also had a lot of pre-punched holes that was totally useless to me. I suggested to Roger or Caleb (I can't remember which) that if they can't get the holes in the correct place to NOT put any holes at all in the side skins. He DID offer to send me a new set of side skins. I thanked him for the offer but I was so far along with it at that point, I wasn't going to go through it again. So if you are having issues with things not lining up correctly, you are NOT alone.
Hope this helped.
Larry Hursh
Edwardsburg, Michigan
Zenith CH650 - N650LM Reserved
2700cc Corvair Powered
Crankshaft already ground .010 - .010 Balanced and nitrited at Moldex
I hope to someday be that person my dog thinks I am.....
--- On Mon, 10/5/09, Jim Belcher <z601a(at)anemicaardvark.com> wrote:
Subject: Re: Re: Parts that dont fit
To: zenith650-list(at)matronics.com
Date: Monday, October 5, 2009, 8:32 AM
--> Zenith650-List message posted
by: Jim Belcher <z601a(at)anemicaardvark.com>
<alan.smith(at)nutreco.com>
to the bottom front
skins were also
supports were also
is correct. We have
knowledge there are
informed that they
wing tips for the
drawings for the
coordinated.
                Do
not archive.
                Jim
B Belcher
  A&P/IA
manager
mix.
         Do not drink and
derive.
Email Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Oct 05, 2009 8:25 am    Post subject: Parts that dont fit Reply with quote
On Monday 05 October 2009 09:07, Larry Hursh wrote:
To all,
I get the uncomfortable feeling that the bad publicity some of the XLs
generated has caused Zenith to put the XL/650 project on a back burner. I
wonder how many of these they have sold in, say, the last year?
There haven't been any new ads for the 650 in Kitplanes for several months.
Noi ads usually mean no new sales. It would be a bad thing if the model were
shelved. I'm not convinced, on the strength of the information presented to
date, that there's really anything wrong with the basic design.
Do not archive.
Jim B Belcher
A&P/IA
Larry Hursh
PostPosted: Mon Oct 05, 2009 9:07 am    Post subject: Parts that dont fit Reply with quote
Jim,
I never said there was any major problems with the "basic design" of the aircraft. All I was reiterating was the lack of USEFUL information coming out of Zenith - nothing more - nothing less. If I didn't have confidence in the aircraft, I would be the FIRST to put it up for sale or scrap it out. I think in Zenith's case, there was so many bad things happening to the older 601's (mostly all bad word of mouth publicity) they was forced into coming out with the newer 650. The airframe is basically exactly the same, with a few improvements. I just wished Zenith would have thought through all the ramifications going with this new conversion as soon as they did, NOT having all the information needed to available to the builders. I call this "Ready! Fire! Aim!".......or P.P.P.
I do believe you WILL eventually see ads appearing in flying magazines again (after they get all their ducks in a row), but for now, remember they are up to their A$$ in alligators, seemingly forgetting that their original main objective was to the "drain the swamp".
Larry
Date: Monday, October 5, 2009, 11:28 AM
<skyridersbn(at)yahoo.com>
> To all,
of the XLs
back burner. I
year?
several months.
if the model were
design.
convert an existing
kit from them but I
of forthcoming
lot of pre-punched
again.  So if you
you are NOT alone.
                Do
not archive.
                Jim
B Belcher
  A&P/IA
manager
mix.
         Do not drink and
derive.
Email Forum -
FAQ,
              -Matt
Dralle, List Admin.
PostPosted: Mon Oct 05, 2009 11:01 am    Post subject: Parts that dont fit Reply with quote
On Monday 05 October 2009 12:00, Larry Hursh wrote:
Jim,
Sorry. I did not mean to imply you had suggested this. I do think that there
may be the impression that there is something wrong with the design amongst
those less familiar with it. I'm building an XL, and I haven't let the
various rumors slow me down.
Something I wish they would do is completely revise the documentation for the
650. It would be nice to see parts built on one drawing, made into
subassemblies on another drawing, and so on. In other words, a drawing tree.
Separate parts numbers for left and right hand parts would also be a good
idea, and perhaps a cross reference by part number that shows every drawing
where that part number is referenced.
I feel I spend entirely too much time searching between several pages to find
rivet pitch, etc etc.
Do not archive.
Jim B Belcher
A&P/IA
PatrickW
PostPosted: Mon Oct 05, 2009 12:04 pm    Post subject: Re: Parts that dont fit Reply with quote
I noticed during the course of building my XL that some of the components that came with my kit were newer than what was reflected in the drawings. For example, the nose gear is different, as are the upper engine mount brackets. And certainly the new canopy as well.
Looking back, we can now recognize that these were components to what we now call the "650". I think the XL was just evolving at the time, and Zenith was naturally shipping the latest and greatest stuff to their customers (which is appreciated). I think the idea to release a "650" was simply a reaction to the negative press about the XL, which gave Zenith the opportunity to pull the XL off the market and come out with something "new and improved".
Very little difference, and most of the 601 documentation still holds for the 650 - the canopy being the notable exception.
I installed my canopy after watching the HomebuiltHelp DVD, although I did some things differently. It was a bear, and knowing what I know now I think I would have done the 650 style latch and the one-piece XL canopy if I were to do it over again now. Water under the bridge at this point.
I am a bit disturbed at the absence of a Zenith 650 demo plane at the fly-ins, and the lack of advertising of the 650.
All in all, I'm happy with how my project has gone, and with Zenith. The hard part for me is listening to all the other pilots and "experts" out there who know all about the Zodiac and how "the wings are going to fall off". It just gets old hearing it all the time.
- Pat
PostPosted: Mon Oct 05, 2009 12:18 pm    Post subject: Parts that dont fit Reply with quote
On Monday 05 October 2009 15:04, PatrickW wrote:
<snip>
Yup. There were people at this year's IA renewal seminar who I doubt had ever seen an XL or a 650, who were convinced I was slightly out of my mind for building one.
I am probably out of my mind for building an airplane at my age, but not for building an XL.
Do not archive.
Jim B Belcher
A&P/IA
============================================= [quote][b]
chuck960
PostPosted: Mon Oct 05, 2009 7:16 pm    Post subject: Re: Parts that dont fit Reply with quote
I think most of the incorrect parts are listed in this forum or the 601 forum but simply every part that is connected in any way to and including the center wing was wrong for my kit. Zenith has been good about replacing parts and I want to believe that they have most of this fixed by now. At least I know that they have parts that fit. I'm not sure about the center wing. I didn't push for a new one and ended up with a spacer under the front flange.
In my opinion I deserve instructions from Zenith for every assembly, especially the canopy. I should not have to rely on after market DVD's.
Chuck
aussiech650
PostPosted: Mon Oct 05, 2009 9:16 pm    Post subject: Re: Parts that dont fit Reply with quote
Chuck, I agree 100% on the instructions, I can only hope that by the time I get to do the canopy that they have a photo guide to suit the 650.
Regarding my center spar, even with a piece of extruded angle (I think 0.093") under the front it still comes in about 1/2 a degree under spec. ZAC have told me that this is acceptable and the rivet crush will still be sufficient, I would prefer to not to be sitting right out on the spec. for such a critical component.
chuck960
PostPosted: Wed Oct 07, 2009 2:05 pm    Post subject: Re: Parts that dont fit Reply with quote
Greg it's not often that someone agrees with me. It's a bit refreshing.
As to the center wing I have decided to do the LAA mod to the center spar which should beef up the wing to fuse attachment. It will add 1 lb in weight, cost very little and is easy to do because I haven't yet riveted the spar in place.
I'm not close to doing much with the canopy yet aside from fitting up the frame in order to locate the canopy latches.
You might consider Cherrymax rivets for the spar to cabin floor rivets. Just be sure to get the right grip length.
Chuck
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List All times are GMT - 8 Hours
