john.marzulli(at)gmail.co Guest
Posted: Sun Oct 04, 2009 12:53 pm Post subject: Gascolator position for 701? |
I am starting to work on the fuel system and a bunch of FWF items now that I have my EFIS/EMS in place.
This raises a few questions about the directions for the new FWF ( ring mount ) system and the plans that I have ( 06/2006 ).
The manual for the new mount have photos of what looks like a gascolator mounted on the firewall, passenger side.
It seems Zenith has moved a bunch of stuff around on the demonstrator without a plans update.
Right now I am planning on positioning the gascolator aft of the main gear like my plans.
Can anyone comment on it this will be a problem with the new ring mount?
Also, where have people placed the fuel flow sensor for their Dynons?
John Marzulli
http://www.GenevieveMarzulli.org/
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
dwilde(at)clearwire.net Guest
Posted: Sun Oct 04, 2009 4:30 pm Post subject: Gascolator position for 701? |
John Marzulli wrote:
gear like my plans.
John: That is where I placed my gascolator with no problems. Unless
they have changed mounts since I ordered my firewall forward in Feb
2007, it should be ok. There probably is no problem mounting it on the
firewall either.
Dan Wilde
jetboy
Posted: Thu Oct 08, 2009 1:48 pm Post subject: Re: Gascolator position for 701? |
Because there needs to be a drain at the lowest point in the fuel system its best to combine this with the gascolator position in the aft compartment on one side, so the drain is available via a hole underneath. I did this with an ACS unit and the drain check is easy to reach down the RHS near the main gear.
Ralph
_________________ Ralph - CH701 / 2200a |
