n8vim(at)arrl.net Guest
Posted: Thu Oct 01, 2009 2:11 pm Post subject: Control column mounts |
Wow, I thought this would have been a simple question, but no response.
Perhaps it was lost in the regular mail, so I'll send this again:
I'm about at this step, and Phil's QB feedback prompted this question
from me:
Is there any reason (other than to save weight) for trimming the control
column mounts? Would it cause interference problems with anything later?
Here's the step (copied from Phil's email)
28-4 Step #1) “Radius the corners and remove material from the middle of
both control column mounts.” (Remove hatched area).
-Jim 40384
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Oct 01, 2009 5:16 pm Post subject: Re: Control column mounts |
Looking at my pictures, I don't think there is anything that would get in the way. Not sure why you don't want to remove it. I didn't have any problems removing the material and then finishing it.
I would suggest following the plans.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Bob Turner
Posted: Fri Oct 02, 2009 9:39 am Post subject: Re: Control column mounts |
In his case, the QB guys have already installed it, without removing material.
I see no interference issues, just a little extra weight. But I'm not flying yet!
_________________ Bob Turner
RV-10 QB |
Phil.Perry(at)netapp.com Guest
Posted: Fri Oct 02, 2009 10:18 am Post subject: Control column mounts |
Thought I'd share this piece of knowledge with the QB group too.
Check the torque values of all your QB installed AN3 hardware. I
started sneaking up on mine the other night to see what value they were
tourqed to.
Any guesses????
85 inches.
Phil
rv10rob(at)gmail.com Guest
Posted: Fri Oct 02, 2009 2:53 pm Post subject: Control column mounts |
If they start turning at 85 in-lbs, that doesn't mean they were torqued to 85, correct? Isn't extra torque required to "break free"?
On Fri, Oct 2, 2009 at 11:06 AM, Perry, Phil <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
[quote]--> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)>
tourqed to.
Any guesses????
85 inches.
Phil
Posted: Sat Oct 03, 2009 3:21 am Post subject: Control column mounts |
I tested them a couple of ways.
<![if !supportLists]>1) <![endif]>I crept up on the torque values until I could get it to budget. – 85 inches
<![if !supportLists]>2) <![endif]>I marked a few nuts (before I touched them) so I knew where they started.
<![if !supportLists]>a. <![endif]>Then backed them off to neutral
<![if !supportLists]>b. <![endif]>Torque back to 25 inches
They were all at around 1 flat too far.
Sent: Friday, October 02, 2009 5:51 PM
Subject: Re: Re: Control column mounts
tourqed to.
Any guesses????
85 inches.
Phil
Posted: Sat Oct 03, 2009 7:30 am Post subject: Control column mounts |
It was more of a curiosity more than anything; I didn't see anything
that would interfere in the plans, but previously the plans for other
parts had said "If desired, remove xxx if desired for lightening...." or
something like that.
I've got a mill (and a lathe ), so doing it per the plans is not an
issue (and what I plan on doing).
-Jim 40384
orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 65961#265961
