redswing(at)mcn.org Guest
Posted: Sun Apr 09, 2006 7:56 pm Post subject: Lycoming flywheel pulley diameter |
I think that there are two flywheel pulley diameters for the 4 cyl Lyc, does anyone know what they are?
TIA,
Red Hamilton
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
Hopperdhh(at)aol.com Guest
Posted: Mon Apr 10, 2006 4:07 am Post subject: Lycoming flywheel pulley diameter |
Hi Red,
I have two "ring gear supports". The one I would consider standard measures
9 3/4 inches on the outside with a 3/8 inch wide belt groove. This one is
marked 75030 ASSY.
I also have one with 2 pulleys. At the rear is one 8 3/8 inch on the
outside with a 1/2 inch wide groove. Just ahead of this groove is one that is 8
5/8 on the outside with a 3/8 inch wide groove. This one is marked LW15602
ASSY. This flywheel would not work on my IO-360-C1E6 with the front mounted
prop governor because the ID of the pulley interfered with the case.
These both are for an IO-360 with prop bolt/bushing holes about 3/4 inch
diameter.
Hope this helps. There are surely more flywheels than this out there.
Dan Hopper
RV-7A
In a message dated 4/9/2006 10:57:34 P.M. Eastern Standard Time,
redswing(at)mcn.org writes:
TIA,
Red Hamilton
