Visio?
tim2542(at)sbcglobal.net
PostPosted: Tue Sep 29, 2009 8:42 pm    Post subject: Visio? Reply with quote
Has anyone tried using Visio to draw their schematic? It looks like it will
work but I'm not finding much in the way of automotive symbols i.e.
solenoids relays etc.
Can anyone recommend a free or cheap program for this?
Thanks, Tim Andres
rv-9a-online(at)telus.net
PostPosted: Tue Sep 29, 2009 9:41 pm    Post subject: Visio? Reply with quote
Hi Tim.
Go here: www.vx-aviation.com and follow the link near the top of the page
for the free schematic software, library and design example from my RV-9A.
Doesn't have everything but it's very easy to create symbols on the fly.
Vern Little
Sent: Tuesday, September 29, 2009 9:37 PM
To: <aeroelectric-list(at)matronics.com>
Subject: Visio?
<tim2542(at)sbcglobal.net>
will
Thanks, Tim Andres
jay(at)horriblehyde.com
PostPosted: Tue Sep 29, 2009 11:14 pm    Post subject: Visio? Reply with quote
I have used Visio a lot and re-drawn many of the symbols- I can let you have
my 'library page' if you'd like.
I use Visio a lot so I found it pretty useful to draw the schematics as
well.
Jay
pestar
PostPosted: Wed Sep 30, 2009 12:09 am    Post subject: Re: Visio? Reply with quote
well.
Jay
If you are able to make available your library of Visio symbols that would be appreciated. I have a Visio one off aircraft symbols that I got of the net that I am happy to share (the file extension .VSS is not permitted for attachments) - contact to email.
Peter Armstrong
Auckland, New Zealand
Building a French carbon fibre plane MCR-4S "www.dynaero.com"
PostPosted: Wed Sep 30, 2009 12:41 am    Post subject: Visio? Reply with quote
Hi there Peter,
I have sent what I have to you via your email address; you can also convert
the dwg files that Bob supplies, although I find that using them after
conversion is not easy. If anyone else wants what I have (not much..) then
mail me directly.
Jay
andrewbutler(at)ireland.c
PostPosted: Wed Sep 30, 2009 12:59 am    Post subject: Visio? Reply with quote
Hi Tim,
Here's mine, all done in Visio.........
I started off by importing Bob's CAD drawings and then converting them. I then went about "cleaning" up the less than perfect result and saving the individual components as "groups". After that, drag and drop and copy and paste works a charm in Visio.
Would you like a copy of the source?
Andrew.
Dual_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filename:  Dual_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filesize:  762.81 KB
 Downloaded:  1566 Time(s)
MauleDriver(at)nc.rr.com
PostPosted: Wed Sep 30, 2009 4:58 am    Post subject: Visio? Reply with quote
I'm using that product too and like it a lot. A belated Thanks Vern!
If anyone installs it and wants a sample, I'd be glad to share my
schematics. (but you have to have the SCH tool installed to view it)
Bill
Vern Little wrote:
<rv-9a-online(at)telus.net>
Hi Tim.
page for the free schematic software, library and design example from
my RV-9A. Doesn't have everything but it's very easy to create symbols
on the fly.
Vern Little
Subject: Visio?
> it will
> Thanks, Tim Andres
kahuna
PostPosted: Wed Sep 30, 2009 6:01 am    Post subject: Visio? Reply with quote
My drawings all in visio here.
http://mstewart.net/super8/visio/S8Panelandwiringr1.vsd
or if you want to peruse the html version on a browser here.
http://mstewart.net/super8/visio/n687msvisio_files.htm
I keep the html version up so when Im on the raod with a problem, I can access all my connector pin outs and things.
Enjoy,
Mike
[img]cid:1__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]"pestar" ---09/30/2009 04:38:29 AM-----> AeroElectric-List message posted by: "pestar" <peter(at)reivernet.com> jay(at)horriblehyde.com wrot
[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
From:[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
"pestar" <peter(at)reivernet.com> [img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
To:[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
aeroelectric-list(at)matronics.com [img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
Date:[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
09/30/2009 04:38 AM [img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
Subject:[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
Re: Visio? [img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
Sent by:[img]cid:2__=08BBFCD2DFDFE0358f9e8a93df938(at)us.ibm.com[/img]
owner-aeroelectric-list-server(at)matronics.com
> well.
> Jay
Peter Armstrong
http://forums.matronics.com/viewtopic.php?p=265679#265679
orum -
tor?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
Site -
bsp; -Matt Dralle, List Admin.
bution">http://www.matronics.com/contribution
 Filesize:  105 Bytes
 Viewed:  12762 Time(s)
 Filesize:  45 Bytes
PostPosted: Wed Sep 30, 2009 8:36 pm    Post subject: Visio? Reply with quote
Nice and complete Andrew!
peter(at)sportingaero.com
PostPosted: Thu Oct 01, 2009 11:11 am    Post subject: Visio? Reply with quote
Bill,
To make Visio drawings viewable by everyone save them as .jpg files (Save
as, and then scroll nearly to the bottom of the menu).
Peter
PostPosted: Thu Oct 01, 2009 12:07 pm    Post subject: Visio? Reply with quote
Some confusion here perhaps. I'm not using Visio - rather I'm using the
ExpressSCH product that Vern has linked to at his site. It does have a
bitmap export function which I just tried and attached the results.
Looks like that works ok.
I've never used Visio. I tried just using Powerpoint which I'm
proficient in but didn't care for the results. I tried Turbocad but
found it to be overkill.
ExpressSCH is one half of a package that appears to support circuit
board design and prototyping. I found it simple to use. Part of it's
attraction is that it 'knows' it is an electrical diagram so the overall
design is consistent with the task at hand.
Bill "on the final lap of an RV10 panel" Watson
Peter Pengilly wrote:
Bill,
Peter
 Filesize:  390.53 KB
 Viewed:  12731 Time(s)
 Filesize:  390.53 KB
