rvg8tor
Posted: Thu Sep 24, 2009 7:19 am Post subject: Welding cable |
My van's kit came with MS 2 awg cable for big wires, but the stuff is too stiff for my application, I have very short runs from my battery to the contactor. I know welding cable can be used, a friend found some "200 amp inverter cable" at Harbor Freight that he is using in his airplane, it is 4 awg cable. Does anyone know if this is the same stuff as welding cable. The connections I want to use this flexible cable for are all behind the firewall, I will use the mil spec stuff to run power forward to the starter. Thanks for any help with this.
_________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
Sam
Posted: Thu Sep 24, 2009 8:55 am Post subject: Welding cable |
I don't know about the Harbor Freight stuff, but when I was looking for welding cable, I did find a variety of quality in insulation. Some had an inner jacket, which I took to be a better quality, and some had not.
Sam
www.samhoskins.blogspot.com
On Thu, Sep 24, 2009 at 10:19 AM, rvg8tor <rvg8tor(at)comcast.net (rvg8tor(at)comcast.net)> wrote:
[quote]--> AeroElectric-List message posted by: "rvg8tor" <rvg8tor(at)comcast.net (rvg8tor(at)comcast.net)>
My van's kit came with MS 2 awg cable for big wires, but the stuff is too stiff for my application, I have very short runs from my battery to the contactor. I know welding cable can be used, a friend found some "200 amp inverter cable" at Harbor Freight that he is using in his airplane. Does anyone know if this is the same stuff as welding cable. The connections I want to use this flexible cable for are all behind the firewall, I will use the mil spec stuff to run power forward to the starter. Thanks for any help with this.
Mike "Nemo" Elliott
RV-8A QB (Fuselage)
http://forums.matronics.com/viewtopic.php?p=264699#264699
le, List Admin.
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Posted: Thu Sep 24, 2009 11:25 am Post subject: Welding cable |
At 10:19 AM 9/24/2009, you wrote:
No good way to know details of this product.
Welding cable is really inexpensive. Pick up
what you need at a local welding supply store.
Also, 2AWG is REALLY oversized for an RV with battery
on the firewall. If it were my airplane, 4AWG
welding cable would be used for all fat wires
that carry starter current.
( -Thomas Paine 1776- )
Posted: Thu Sep 24, 2009 3:05 pm Post subject: Welding cable |
At 11:51 AM 9/24/2009, you wrote:
| Quote: | I don't know about the Harbor Freight stuff, but when I was looking for welding cable, I did find a variety of quality in insulation. Some had an inner jacket, which I took to be a better quality, and some had not.
Sam |
Thanks for reminding me of that Sam. A guy
at a welding store told me that the two-layer
cable lasted longer in the field. Little nicks
in the outer jacket tended to propagate cracks
through to the strands when the cable was flexed/
stretched. By making it two layers, the gap
was a "crack stopper" while the inner layer
maintained environmental integrity.
http://aeroelectric.com/Pictures/Wire/4AWG_Welding_Cable_1.jpg
It seems a logical explanation. Of course,
the cables in our airplanes don't get stretched
across gravel drives and run over by dump-trucks.
The Anchor brand welding cable illustrated above
has an HDPM outer jacket which is revered for
its flexibility and toughness. Here's an excerpt
from a wire catalog describing this insulation.
[img]cid:.0[/img]
115.3 KB |
19761 Time(s) |
rvg8tor
Posted: Thu Sep 24, 2009 4:41 pm Post subject: Re: Welding cable |
I found my local welding shop and bought some 4 AWG. Man this stuff is flexible, I can't believe I was trying to wrestle with the mill spec stuff for those short runs. It is not the double insulated stuff you showed in the picture but it seem tough. it is labeled as "Heavy Duty Welding cable 600V -50 degrees C to 105 degrees C. I will use a crimp on ring terminal, I have the tool from ACS for this but should I solder the end before crimping, there are a lot of fine wires in this cable. I will have to check the AEC Bible, I seem to remember reading something on this subject.
RV-8A QB (Engine)
longg(at)pjm.com Guest
Posted: Fri Sep 25, 2009 6:56 am Post subject: Welding cable |
Mike,
Maybe a small thing, but I would crimp "before" I'd solder. Soldering
just seals the deal.
Glenn
At 07:41 PM 9/24/2009, you wrote:
NICE to work with . . .
| Quote: | It is not the double insulated stuff you showed in the picture but
Yup, it will be just fine . . .
| Quote: | I will use a crimp on ring terminal, I have the tool from ACS for
If your crimp tool produces the proper crush, then
crimping is as good as solder. The two processes
are essentially interchangeable. If you solder at
all, then crimping adds no value.
http://www.aeroelectric.com/articles/big_term.pdf
toaster73(at)embarqmail.c Guest
Posted: Sat Sep 26, 2009 6:53 am Post subject: Welding cable |
Where can you find the anchor brand cable? Any weblinks/supply you can point to.
Chris
RV-10
Sent: Thursday, September 24, 2009 3:54 PM
Subject: Re: Welding cable
Sam
115.3 KB |
19716 Time(s) |
Posted: Sat Sep 26, 2009 9:18 am Post subject: Welding cable |
At 09:45 AM 9/26/2009, you wrote:
| Quote: | Where can you find the anchor brand cable? Any weblinks/supply you
can point to.
Chris
RV-10
A local welding supply store will offer Anchor or
a suitable equivalent. Some mention was made of
a "200A inverter cable" from Harbor Freight. While
these wires will probably have enough finely stranded
copper for the task, the question to be asked deals
with temperature characteristics and ruggedness of
the INSULATION. Welding cable produced to an ATSM
specification (as are most if not all American
products) will do the job for you . . .
I searched for Anchor outlets but without success
after 20 minutes or so . . . however, the storefront
where I purchased the pictured sample was offering
Anchor brand cable at the time I bought it. That
was several years ago.
Shop around locally first . . .
Sam
Posted: Sat Sep 26, 2009 9:53 am Post subject: Welding cable |
I was at my local True-Value hardware store, this morning, and they had the 4AWG inner jacketed stuff. I didn't look for the brand name, though.
Sam
On Sat, Sep 26, 2009 at 12:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Where can you find the anchor brand cable? Any weblinks/supply you can point to.
Chris
RV-10
le, List Admin.
halbenjamin(at)optonline. Guest
Posted: Sat Sep 26, 2009 10:14 am Post subject: Welding cable |
Hi Bob C
6nbsp;
West Marine carries ANCOR brand battery cable E I don 7t know if it 7s any good E Just another piece of intel to muck things up E
6nbsp;
Hal Benjamin
RV4 Long Island C NY
Posted: Sat Sep 26, 2009 11:24 am Post subject: Welding cable |
At 01:00 PM 9/26/2009, you wrote:
| Quote: | Hi Bob,
West Marine carries ANCOR brand battery cable. I don't know if it's any good. Just another piece of intel to muck things up.
Thanks for the heads-up. I checked a portion of
their offerings at:
http://tinyurl.com/ycmabhn
It's not clear to me that this is the same "Anchor"
cable company. The material illustrated has tinned
conductors while welding cable does not. Further,
their prices (before shipping I presume) are pretty
breathtaking. Higher than 22759 stuff from Aircraft
Spruce!
It seems that 'Anchor' is an exceedingly popular
name for various brands/businesses. Makes it
difficult to find 'the one' . . .
Here's one good hit
http://tinyurl.com/ydjdlr2
assuming you can use 500' of 4awg. This stuff
is about $1.50/ft before shipping. This is how
your welding supply store would buy it and sell
it for $2.25/ft or so . . .
It appears that the folks we're looking for
offer a huge selection of electric and wire-welding
parts and tools of which welding cable is only
a small fraction of their catalog. Given this
penetration into the welding supplies market,
it's quite likely that local stores will know
all about them.
If anyone finds the mother website for Anchor
brand welding products, I'd appreciate hearing
about it.
Posted: Sat Sep 26, 2009 3:26 pm Post subject: Welding cable |
Well I guess you see why I asked, I spent some time googling and didn’t find much whioch actually called out the epdm insulation. Guess I should have mentioned that. I did find this place and I sent an email to ask what brand it is they carry, hopefully they will respond Monday and I’ll report back. Its finding that EPDM insulation that seems tricky, I had some stuff locally but it had a paper inner liner and I didn’t find the outer stuff to be very tough, it seemed easy to nick and penetrate.
http://www.wesbellwireandcable.com/Welding.html
-Chris
RV-10
Sent: Saturday, September 26, 2009 3:20 PM
Subject: Re: RE: Welding cable
Hi Bob,
their offerings at:
Spruce!
Here's one good hit
all about them.
about it.
--------------------------------------- [quote] [b]
Posted: Sun Sep 27, 2009 6:41 am Post subject: Welding cable |
At 06:22 PM 9/26/2009, you wrote:
| Quote: | | Well I guess you see why I asked, I spent some time googling and didn’t find much whioch actually called out the epdm insulation. Guess I should have mentioned that. I did find this place and I sent an email to ask what brand it is they carry, hopefully they will respond Monday and I’ll report back. Its finding that EPDM insulation that seems tricky, I had some stuff locally but it had a paper inner liner and I didn’t find the outer stuff to be very tough, it seemed easy to nick and penetrate. |
I looked at some wire in the junk box that
I think came from an installation kit for
an automotive super-sound system. The insulation
was decidedly plastic looking (shiny) and
also had a paper liner.
Hey, good find on the web-source! Looks like
their prices are really good too. As you can
see from their offerings, there are MANY different
kinds of insulation . . . EPDM is not the magic
material, just one of many that would be
suitable. I didn't intend that one zero in
on EDPM in that manner. The fact that a reel
of wire (or a catalog page) cites EDPM says
that you KNOW what's being offered. That reel
of shiny stuff with unknown and/or questionable
insulation material MIGHT be okay. Without
identification or other qualification data
like materials or temperature ratings, it's
good to move on and consider other sources.
Looks like the WesBell folks are an excellent
source of wire suitable for use as fat wires
in your airplane.
tomcostanza
Posted: Mon Sep 28, 2009 6:45 am Post subject: Welding cable |
At 08:56 AM 9/28/2009, you wrote:
Another score from the 3-point line . . . thanks!
rv8iator
McMaster-Carr supplies welding cable in two insulation types at a reasonable price...
http://www.mcmaster.com/#welding-cable/=3tsvkp
Chris Stone
RV-*
<snip>
| Quote: | >Where can you find the anchor brand cable? Any weblinks/supply you
>can point to.
>Thanks
>Chris
>RV-10
_________________ C. Stone (RV8iator) |
Posted: Mon Sep 28, 2009 8:58 am Post subject: Welding cable |
At 09:36 AM 9/28/2009, you wrote:
Thanks! I should have thought about those guys.
I'm thinking about adding a page to the
website too link to the hot prospects . . .
Posted: Mon Sep 28, 2009 10:12 am Post subject: Welding cable |
Broke down and did it. See:
http://aeroelectric.com/Sources.html
. . . as readers discover additional web
sources for other unique materials or tools
that belong on this list are encouraged to
let me know about them.
Posted: Mon Sep 28, 2009 3:38 pm Post subject: Welding cable |
Ditto on that Bob!! I always go to McMaster and just as quickly forget I
did.
-Chris
