robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Wed Sep 23, 2009 5:50 am Post subject: HKS-700 on a Mark III or extra |
I have an HKS on a Mark I. It does fine on this but the gross weight is exceeded with an average weight passenger. I understand the fellow who clipped the trees has an Mark III with an HKS and would love to hear a flying report.
Rob Cannon
Saltspring Island BC
250-537-8733
Posted: Wed Sep 23, 2009 6:22 am Post subject: HKS-700 on a Mark III or extra |
In the same crowd with a low powered MkIII, I don't see how a normal
landing would make
any difference. -that is excluding unstable ar ledge landings at
high altitudes.
The guy honestly admitted to temporary poor judgement. I give him
sympathy and a salute.
BB
On 23, Sep 2009, at 9:50 AM, robcannon wrote:
Rob Cannon
250-537-8733
http://forums.matronics.com/viewtopic.php?p 64509#264509
pj.ladd(at)btinternet.com Guest
Posted: Thu Sep 24, 2009 6:23 am Post subject: HKS-700 on a Mark III or extra |
flying report.>>
Hi, Clipping the trees is nothing to do with power available. It is about
getting the approach wrong.
Cheers
Pat
russkinne(at)mac.com Guest
Posted: Thu Sep 24, 2009 1:34 pm Post subject: HKS-700 on a Mark III or extra |
Pat
You're absolutely right about 'getting the approach wrong' causes a
lot of accidents.
BUT if you have sufficient power, you can stop a descent and even
make a go-round.
So IMHO power available does have something to do with clipping the
trees.
If enough power's available, hopefully at least, no tree-clipping.
Russ
On Sep 24, 2009, at 10:23 AM, pj.ladd wrote:
would love to hear a flying report.>>
about getting the approach wrong.
Cheers
Pat
rickofudall
Posted: Thu Sep 24, 2009 1:43 pm Post subject: HKS-700 on a Mark III or extra |
Russ, Depends on which side of the power curve you're on. Get on the back side and you can't climb out with out lowering the nose first. If the trees are too close for that, you're going in no matter how much power you have.
Rick Girard
On Thu, Sep 24, 2009 at 4:31 PM, russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)> wrote:
[quote]--> Kolb-List message posted by: russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)>
Pat
You're absolutely right about 'getting the approach wrong' causes a lot of accidents.
BUT if you have sufficient power, you can stop a descent and even make a go-round.
So IMHO power available does have something to do with clipping the trees.
Russ
| Quote: | --> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
I have an HKS on a Mark I. It does fine on this but the gross weight is exceeded with an average weight passenger. I understand the fellow who clipped the trees has an Mark III with an HKS and would love to hear a flying report.>>
Hi, Clipping the trees is nothing to do with power available. It is about getting the approach wrong.
Cheers
Pat
le, List Admin.
robcannon
Posted: Thu Sep 24, 2009 7:28 pm Post subject: Re: HKS-700 on a Mark III or extra |
I was actually just looking to hear how the hks does on the Mark III extra. Will it climb with two aboard ? etc. I must have poorly worded my original post.
Rob Cannon
lcottrell
Posted: Thu Sep 24, 2009 8:40 pm Post subject: HKS-700 on a Mark III or extra |
Just a guess on my part, since I have owned a Mark III with a 582. The weight of my Firestar is pretty close to what most of the lighter Mark III weigh. The wings on the 3 are larger so it would fly, but I wouldn't want to own one.
Larry
JetPilot
Posted: Fri Sep 25, 2009 6:05 pm Post subject: Re: HKS-700 on a Mark III or extra |
I have a MK III Xtra with a 100 HP Rotax 912-S, and its perfect. I would not want much less power than I have though. The 80 HP Rotax 912 is pretty cheap used, and would be a much better engine for the MK III Xtra than the HKS for this plane. I think the MK III would be ok, but not great with the Rotax 80 HP.
I think the MK III Xtra would be HORRIBLE with the HKS. I think climb would be so poor with the HKS that it would be dangerous. This is just a guess as I have never flown an extra with that little power... I do know what my MK III Xtra climbs like if I run just over half power, and it hardly qualifies as a climb.
Mike
Kolb MK-III Xtra, 912-S |
Richard Pike
Posted: Fri Sep 25, 2009 7:03 pm Post subject: Re: HKS-700 on a Mark III or extra |
[quote="lcottrell"]Just a guess on my part, since I have owned a Mark III with a 582. The weight of my Firestar is pretty close to what most of the lighter Mark III weigh. The wings on the 3 are larger so it would fly, but I wouldn't want to own one.
Larry
Reading this thread persuaded me to go back and dig out my April 1995 copy of General Aviation News and Flyer, which had a full article on the MKIII with the 503 and 582. In the article, the 503 is described as "perfectly adequate."
(I can scan the article and post pictures of it if anybody cares)
I got a chance to fly a dual carb 503 powered MKIII with a passenger on board & full fuel. This was a bare bones airplane, no electrical system, maybe just a strobe, it weighed (supposedly) 475 pounds. It was really pretty much a dog, and it was a cool morning.
So IMO, although the HKS makes more power than a 503, but less than a 582, unless I lived in flat Midwest country, probably the HKS engine on a MKIII is not a happy choice.
Richard Pike
MKIII N420P (420ldPoops)
lcottrell
Posted: Fri Sep 25, 2009 8:17 pm Post subject: HKS-700 on a Mark III or extra |
Richard Pike
Even though the HKS makes more power than the 503, I find that it is offset by the additional weight. I can fly faster with the HKS, but I cannot get off the ground as quick. The only plus is the "apparent" safety factor of the four stroke, and the longer TBO.
Larry
rickofudall
Well for what it's worth Richard, the original J-3 Cub started life with a Continental A-40 engine of 37 hp and weighed 2/3 more than a Mk III. I was flying my neighbor's Taylorcraft last week with an A-65 Continental and it too weighs about 2/3 more than my Mk III. Flew real nice. My Mk III will out climb the T craft but he blows by me (relatively speaking) over 15 mph faster at slightly less fuel burn than my 582 can deliver. It's all relative.
Rick Girard
On Fri, Sep 25, 2009 at 10:03 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Larry
Richard Pike
http://forums.matronics.com/viewtopic.php?p=265067#265067
le, List Admin.
zeprep251(at)aol.com Guest
Posted: Sat Sep 26, 2009 6:15 am Post subject: HKS-700 on a Mark III or extra |
Larry,
One more plus,the fuel burn of the HKS. Just slightly more than half of the 503.
G.Aman
lcottrell
Posted: Sat Sep 26, 2009 8:45 am Post subject: HKS-700 on a Mark III or extra |
Oh yeah, some how I forgot that. :-/ I just got back from the Alvord Desert where some of the Top Fun Flyer's will be going for a weekend fly out. I had a head wind of about 10 MPH going so ran full power cruise, (5750) I burned 4 gallons for the round trip of 1.4 hours. The BLM is burning the Steen's Mts. and visibility is terrible. It almost took the GPS to find the place. :-/
I only took one picture the whole trip. There were a couple of wild horses on the rim overlooking the Desert.
151.14 KB |
12411 Time(s) |
