Speedy11(at)aol.com Guest
Posted: Mon Sep 21, 2009 9:40 am Post subject: Front Mounted Governor vs. Rear Mounted Governor |
Matt,
Now I'm starting to catch on. I wondered why you were using a McCauley governor. You're using it to avoid buying another one.
Good idea, but it may not work too well. I have the MT governor with the MT prop on the IO-390 and, although there were some problems to solve, it works reasonably well. There are problems to solve no matter which one you use. Nothing is bolt on.
Stan Sutterfield
| Quote: | I just discovered something very interesting. The gear ratio is different between
a Front mounted governor and a Rear mounted governor - .947 to 1 (front) vs.
.866 to 1 (rear). So that means that the McCauley governor that I have that
I originally purchased for use with and O-360 won't even work with the IO-390.
This page from the PCU5000 web site is very informative:
http://www.pcu5000.com/pcu5000x.htm
It details the various ratios and what not.
I also found a PDF on the dimensions of the MT governor that Van's sells:
http://www.mt-propeller.com/pdf/manuals/e-1048.pdf
This MT governor is also 1" shorter than the McCauley governor similar to the PCU5000:
http://www.pcu5000.com/pcu5000x_spec.pdf
In this picture of the PCU5000:
http://www.pcu5000.com/index_i/hmpg_pic.gif
the PCU5000 shows an auxiliary control arm that might be very helpful in pushing
the control cable out of the way of the fiberglass intake. Although, I think
that just moving the control arm in by 1" compared to the McCauley is going
to be plenty.
At any rate, I've ordered a PCU5000X number "P-520-029/A-947" for my RV-8/IO-390
combination so hopefully I can move forward on this project...
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
