dsyvert
Posted: Mon Sep 21, 2009 6:20 am Post subject: Dual Battery Dual Alternator Grounding |
I have two #2 AWG cables running from the back of my RV-10 to the firewall. My question is if I put in two batteries and two alternators, where do I ground each one. Van's plans show the grounding at the behind the baggage bulk head. Could both batteries be grounded there to a common ground? I intended to use the second cable as a ground from the battery to the firewall, but Van's shows it to be grounded to the battery box.
Sorry if this has already been addressed
dsyvert
Posted: Mon Sep 21, 2009 7:33 am Post subject: Dual Battery Dual Alternator Grounding |
At 09:20 AM 9/21/2009, you wrote:
Independent grounds to structure will be
consistent with design goals for elimination
of single points of failure. See . . .
http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_2.jpg
do this for EACH battery. Also, 4AWG welding cable
jumpers from battery(+) to contactor and battery(-)
to ground are a good idea to minimize mechanical
stress on terminals.
( -Thomas Paine 1776- )
