Front Mounted Governor vs. Rear Mounted Governor...
Site Admin
PostPosted: Sun Sep 20, 2009 11:04 am    Post subject: Front Mounted Governor vs. Rear Mounted Governor... Reply with quote
I just discovered something very interesting. The gear ratio is different between a Front mounted governor and a Rear mounted governor - .947 to 1 (front) vs. .866 to 1 (rear). So that means that the McCauley governor that I have that I originally purchased for use with and O-360 won't even work with the IO-390. This page from the PCU5000 web site is very informative:
http://www.pcu5000.com/pcu5000x.htm
It details the various ratios and what not.
I also found a PDF on the dimensions of the MT governor that Van's sells:
http://www.mt-propeller.com/pdf/manuals/e-1048.pdf
This MT governor is also 1" shorter than the McCauley governor similar to the PCU5000:
http://www.pcu5000.com/pcu5000x_spec.pdf
In this picture of the PCU5000:
http://www.pcu5000.com/index_i/hmpg_pic.gif
the PCU5000 shows an auxiliary control arm that might be very helpful in pushing the control cable out of the way of the fiberglass intake. Although, I think that just moving the control arm in by 1" compared to the McCauley is going to be plenty.
At any rate, I've ordered a PCU5000X number "P-520-029/A-947" for my RV-8/IO-390 combination so hopefully I can move forward on this project...
RV-8 #82880 N998RV
http://www.mattsrv8.com
Engine Baffling...
wgill10(at)comcast.net
PostPosted: Sun Sep 20, 2009 7:22 pm    Post subject: Front Mounted Governor vs. Rear Mounted Governor... Reply with quote
Hello Matt,
I installed the offset arm as well, but found that I needed an additional 0.5 inch offset -- fabicated from .5 inch aluminum stock. You might find the attached photos helpful.
Best regards,
Bill
 Filesize:  238.74 KB
 Viewed:  3966 Time(s)
 Filesize:  256.98 KB
 Filesize:  153.86 KB
 Filesize:  164.33 KB
 Filesize:  167.25 KB
 Filesize:  166.97 KB
 Filesize:  250.67 KB
Site Admin
PostPosted: Mon Sep 21, 2009 2:00 pm    Post subject: Re: Front Mounted Governor vs. Rear Mounted Governor... Reply with quote
Great pictures, Bill; thank you!
I just ordered a PCU5000 with the extension arm and the clockwise rotation (clockwise to increase pitch).
What length control cable did you use?
If you had made your bracket stick out a little farther, could you have gotten away with not using the extra bushing on the control arm?
RV-8 #82880 N998RV
Engine Baffling & Governor Installation...
