ter_turn(at)yahoo.com Guest
Posted: Sat Sep 19, 2009 4:55 pm Post subject: throttle set-up |
It looks like the dual throttle set up shown on 6-E-5 is a "pull " system. Does anyone have such a set up and has it caused any problems as opposed to the standard push throttle? I realize a person can get used to anything, but this seems counter intuitive. Yes, No?
Terry Turnquist
601XL
bryanmmartin
Posted: Sat Sep 19, 2009 6:39 pm Post subject: throttle set-up |
The throttles should be push to open. The Bing carbs are spring loaded
to open throttle and you have to pull against the springs to close the
throttles. You should try to keep all the major systems as standard as
practical. There's no good reason not to set the throttles up for push
to open.
On Sep 19, 2009, at 8:54 PM, Terry Turnquist wrote:
| Quote: | It looks like the dual throttle set up shown on 6-E-5 is a "pull "
Yes, No?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sat Sep 19, 2009 7:32 pm Post subject: throttle set-up |
Terry,
The pull type system is absurd and one should do all things practical
that sets the throttle to push to open. I would also eliminate the
spring action that
provides no safety or intuitive motion or resolution if one spring
breaks. It's not as hard to do a type certified example if you really
set your mind to
it. When ever would you allow someone to fly your aircraft if it were
different from the expected thing. That becomes a safety issue, big time.
Yes, counter intuitive is incorrect!
Best regards,
Terry Turnquist
601XL
geather
Joined: 06 Feb 2008 Posts: 23 Location: Mt Hutton Australia
Posted: Sat Sep 19, 2009 8:05 pm Post subject: throttle set-up |
All
Whilst on the duel throttle system - does anyone have any ideas on how to
overcome the friction in the standard kit supplied by Jabiru USA. The
thickness of the inner throttle cable and the arc through which it is
required to operate make opening (and closing) the throttle difficult.
Geoff 601 XL (Nearly finished)
_________________ ge |
psm(at)att.net Guest
Posted: Sun Sep 20, 2009 1:13 am Post subject: throttle set-up |
Hi Geoff,
I didn't like the feel of the included dual throttle kit from
JabiruUSA either. I decided the problem was the fact that the torque
tube was mounted on the shelf above the nose gear and the control
path is even higher at that point because of the direction of the
arms on the torque tube. This is natural since it was part of the
firewall forward package and that was the only place forward of the
firewall to mount the torque tube.
On my plane I decided to move the torque tube to aft of the
firewall. I mounted it at three points - two side skins and below
the center channel that runs between the firewall and instrument
panel. Also I faced the arms downward to keep the control path at
the same level as the throttle connection on the carburetor. Rather
than using the supplied torque tube, I reproduced the design with
longer arms. I also mounted the throttle knobs and carb heat knob on
the side skin -- my arms aren't long enough to reach the instrument
panel while leaning back in the seat. The result is a very smooth
dual throttle implementation.
If you look in the archives you will probably find some pictures I
posted of this design.
The bad news is it took me a couple of months to implement this along
with a redirection of the carb heat control.
Good luck,
Paul
XL awaiting engineering changes
At 09:00 PM 9/19/2009, you wrote:
| Quote: | Whilst on the duel throttle system - does anyone have any ideas on how to
geather
Posted: Sun Sep 20, 2009 2:51 am Post subject: throttle set-up |
Paul
Thanks for the reply - sounds like a great idea. Any chance of reposting the
pictures of your design? I found your previous comments in the archives but
am unable to access the pictures.
Geoff
Posted: Sun Sep 20, 2009 3:08 am Post subject: throttle set-up |
Hi Geoff,
I'm not really sure I ever posted the pictures to the group site. I'm sure I sent them out, but perhaps it was only to a few people who asked. In any event, here they are. I hope they help . . .
Paul
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.0[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.1[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.2[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.3[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.4[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.5[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.6[/img]
[img]cid:7.1.0.9.0.20090920035639.04ceae78(at)att.net.7[/img]
Note: the picture file names give a clue about what is contained.
Good luck,
Paul
At 03:48 AM 9/20/2009, you wrote:
| Quote: | Paul
Geoff |
42.42 KB |
12129 Time(s) |
30.87 KB |
12129 Time(s) |
28.66 KB |
12129 Time(s) |
53 KB |
12129 Time(s) |
37.51 KB |
12129 Time(s) |
25.6 KB |
12129 Time(s) |
33.98 KB |
12129 Time(s) |
29.47 KB |
12129 Time(s) |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Sep 21, 2009 3:17 am Post subject: Re: throttle set-up |
Geoff,
I installed the Jabiru FWF supplied dual throttle system as intended by Jabiru. Initially it did have a lot of inherent friction and hysteresis. I worked at reducing friction at all the movement points. I put doublers on the instrument panel and firewall where the throttle cable passes through to eliminate flexing. I also pre-bent the solid throttle wire where it passes through the firewall and flared up the opening that the wire passes through. This and some teflon lube has resulted in very satisfactory operation. I worked on it quite a bit and, admittedly at one point, was near to scrapping the system outright, but persistence paid off. I has been operating very well in flight for over a year and 100+ hours now.
Good luck on yours,
_________________ David Gallagher
Cincinnati, OH area |
ggower_99(at)yahoo.com Guest
Posted: Mon Sep 21, 2009 11:49 am Post subject: throttle set-up |
Is an international safety std... All pilots in the world react instictly to pull to idle the engine and push to power up...
Other will be very dangerous...
Saludos
Gary Gower.
--- On Sat, 9/19/09, Bryan Martin <bryanmmartin(at)comcast.net> wrote:
Subject: Re: throttle set-up
Date: Saturday, September 19, 2009, 10:18 PM
--> Zenith601-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)>
The throttles should be push to open. The Bing carbs are spring loaded to open throttle and you have to pull against the springs to close the throttles. You should try to keep all the major systems as standard as practical. There's no good reason not to set the throttles up for push to open.
| Quote: | It looks like the dual throttle set up shown on 6-E-5 is a "pull " system. Does anyone have such a set up and has it caused any problems as opposed to the standard push throttle? I realize a person can get used to anything, but this seems counter intuitive. Yes, No?
--Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus ://www.matronics.com/Navigator?Zenith601-List" target=_blank>http://www.mp://forums.matronics.com/" ; -Matt Dralle, List Admin==========
z601a(at)anemicaardvark.c Guest
Posted: Mon Sep 21, 2009 12:04 pm Post subject: throttle set-up |
On Monday 21 September 2009 14:32, Gary Gower wrote:
| Quote: | Is an international safety std... All pilots in the world react instictly
It certainly should be made to work in the standard manner. However, I'm not
aware of anything in the FARs which require this for an experimental
aircraft. Those are the only standards which legally apply. I think you can
legally build an aircraft in which "push" idles it, but it would be very
foolish to do so.
I'd personally refuse to fly an aiorcraft with the throttle wired backwards.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
paulrod36(at)msn.com Guest
Posted: Mon Sep 21, 2009 12:53 pm Post subject: throttle set-up |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I dunnooooo, maybe it would be fun to have "push to close" throttles, and reverse the rudder and aileron cables. Make it a real customized plane..........If nothing else, nobody would ever steal it---successfully
Paul R
jaybannist(at)cs.com Guest
Posted: Mon Sep 21, 2009 2:41 pm Post subject: throttle set-up |
I seem to recall reading that the WWII British war birds have a pull-to-go, push-to-stop throttle. I think that airplanes we furnished for their use had to have the throttle action reversed. I wouldn't want to fly just any airplane with that setup, but I think if I got a chance to fly a Spitfire, I wouldn't refuse because of the throttle setup.
Jay Bannister
Posted: Mon Sep 21, 2009 3:55 pm Post subject: throttle set-up |
On Monday 21 September 2009 17:27, jaybannist(at)cs.com wrote:
| Quote: | I seem to recall reading that the WWII British war birds have a
pull-to-go, push-to-stop throttle.? I think that airplanes we furnished for
their use had to have the throttle action reversed.? I wouldn't want to fly
Jay, I suppose I'm a devout coward, but I would probably refuse. I know darned
well I'd forget, and jam the throttle in at a critical time. But that's me.
Do not archive.
Jim B Belcher
A&P/IA
daveaustin2(at)primus.ca Guest
Posted: Tue Sep 22, 2009 1:30 pm Post subject: throttle set-up |
Spitfires were "push to open" for sure.
Dave Austin 601HDS - 912
