CB-1002-H Governor Bracket Installation Photos...?
Site Admin
PostPosted: Fri Sep 18, 2009 7:58 pm    Post subject: CB-1002-H Governor Bracket Installation Photos...? Reply with quote
Dear Listers,
Van's turned me on to a bracket for the RV-10 called the CB-1002-H which is a bracket for mounting the governor control cable on front mounted governors.
Does anyone have some good pictures of how this bracket is installed? Maybe even a scan of the baffling installation OP sheet where the RV-10 baffling is described?
Since the IO-390 has a front mounted governor similar to the IO-540 used on the RV-10, some of these baffling pieces seem to work.
Any docs you could provide would be most appreciated!
RV-8 #82880 N998RV
Engine Baffling...
 Filesize:  144.01 KB
 Viewed:  3966 Time(s)
 Filesize:  140.41 KB
Lenny Iszak
PostPosted: Fri Sep 18, 2009 8:28 pm    Post subject: Re: CB-1002-H Governor Bracket Installation Photos...? Reply with quote
Matt,
See if this helps.
Lenny
 Filesize:  420.27 KB
 Viewed:  3960 Time(s)
rv10builder(at)bellsouth.
PostPosted: Fri Sep 18, 2009 8:48 pm    Post subject: CB-1002-H Governor Bracket Installation Photos...? Reply with quote
Hope this helps...lower left of the photo.
 Filesize:  45.83 KB
 Viewed:  3958 Time(s)
AV8ORJWC
PostPosted: Sat Sep 19, 2009 10:49 am    Post subject: CB-1002-H Governor Bracket Installation Photos...? Reply with quote
Beautiful bracketry.
John Cox
