PeterHunt1(at)aol.com Guest
Posted: Mon Sep 14, 2009 9:51 am Post subject: Van's gauges |
In 420 house over three plus years a number of Van's gauges have failed (fuel quantity, volts, amps, oil pressure). Now I must install the third volt meter. I like the look of Van's gauges and the fact that they match, but don't like the failure rate. What have your experiences been?
Pete in Clearwater
RV-6 - Reserve Grand Champion, S 'n F 2006 and other awards
peter(at)sportingaero.com Guest
Posted: Mon Sep 14, 2009 2:18 pm Post subject: Van's gauges |
Similar, my pressure and temperature gauges failed at around 400 hours. So all of the Van’s gauges, save for fuel gauges, were pull out and replaced with a GRT EIS 4000. Now approaching 700 hours I’m going to replace the fuel gauges with a dual UMA 2 ¼.
Peter
jdubner(at)yahoo.com Guest
Posted: Mon Sep 14, 2009 4:23 pm Post subject: Van's gauges |
Similar to your and Peter Penquilly's poor experiences, my oil pressure
gauge (the only Van's gauge in my Long-EZ) can charitably be described
as "flaky". The basic gauge itself is not reliable as proven on a bench
test with a fixed resistance to replace the sender.
Joe
Independence, OR
Aircraft Position: http://www.mail2600.com/position
PeterHunt1(at)aol.com wrote:
| Quote: | In 420 house over three plus years a number of Van's gauges have failed
Pete in Clearwater
Posted: Mon Sep 14, 2009 6:14 pm Post subject: Van's gauges |
| Quote: | Voltage display is about 11v most of the time (I have a digital
voltmeter hooked up to the bus showing a true 13.5 volts)
Under what conditions? With the engine running and the
alternator supporting all the ship's electrical loads,
one would expect 14.2 to 14.6 volts on the bus.
( -Thomas Paine 1776- )
harvey4(at)earthlink.net Guest
Posted: Wed Sep 16, 2009 4:17 am Post subject: Van's gauges |
It's never 14+v. Since it's a pusher, I had assumed there's a voltage
drop between the alternator and where I'm sampling the voltage behind
the panel - about 8 feet away.
Sounds like it's something I need to look into. The alternator is new.
Neil
At 10:09 PM 9/14/2009, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
Posted: Wed Sep 16, 2009 5:08 am Post subject: Van's gauges |
At 07:04 AM 9/16/2009, you wrote:
voltage drop between the alternator and where I'm sampling the
voltage behind the panel - about 8 feet away.
Hmmmm . . . yeah, you might take some readings
at both the alternator b-lead terminal and the
battery . . . but 0.7v drop is too much. If
your measurements confirm that much drop, then
you need to upsize the b-lead wire.
For example, a 6AWG wire is .00025 ohms per
foot. 10 feet will drop only 0.1 volt at
40Amps. Check the ground path drop between
crankcase and battery (-) too.
Posted: Mon Sep 21, 2009 12:09 pm Post subject: Van's gauges |
At 12:46 PM 9/14/2009, you wrote:
| Quote: | In 420 house over three plus years a number of Van's gauges have failed (fuel quantity, volts, amps, oil pressure). Now I must install the third volt meter. I like the look of Van's gauges and the fact that they match, but don't like the failure rate. What have your experiences been?
Pete in Clearwater
Peter,
Sorry to hear about this . . . I've got a Van's ammeter
on the bench which I disassembled to look at. Hand-
assembled, thru-hole components (not necessarily
a 'bad' thing, especially in TC aviation!). However,
the ammeter proved to be exceptionally vulnerable
to radio-frequency fields (hand held).
It's a line-item on my things-to-do list to see what
sort of filter/shielding would reduce the effects to
acceptable levels.
My discovery raises a perplexing question . . .
How much of the technology and design goals for
the ammeter are common to the rest of the product
line? Of course, my question only goes to system
integration . . . a question which is moot if the
critters have an unacceptable failure rate.
Your question is the first I've heard of it. I'd
be pleased to have updates from the rest of List
membership.
P.S. Sorry we didn't get together while attending
to Dr. Dee at the convention last winter. It was
an interesting and opportunity-packed event. I don't
think we got out of the hotel more than a half dozen
trips to local eateries!
johnd(at)wlcwyo.com Guest
Posted: Mon Sep 21, 2009 2:45 pm Post subject: Van's gauges |
I also used Van’s Gauges.
I had trouble with the ammeter also. Never did get it to work quite right. It worked OK until you transmitted.
The oil pressure gauge only worked when the engine oil was cold. After the temperature climbed to normal temps, the pressure would drop to 20 of 30 psi, sometimes to 0.
The rest of my Vans gauges (fuel quant, fuel pressure, tachometer, volt meter, manifold pressure) worked great after 300 hrs.
John Danielson
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Monday, September 21, 2009 2:08 PM
Subject: Re: AeroElectric-List: Van's gauges
Pete in Clearwater
Peter,
acceptable levels.
membership.
--------------------------------------- | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
