INVOICE AS REQUESTED
Peter H
PostPosted: Wed Sep 16, 2009 2:50 pm    Post subject: INVOICE AS REQUESTED Reply with quote
Lynn,
I could not find Al tubes bends of correct diameter although I spent a good
time looking. Al tubes would save weight.
I have attached a link to the source of my SS tubes and bends. They are high
quality food grade product.
Doing the job at home sounds like the way to go; or you could start in the
hangar and then decide.
Peter
20080812131939578.pdf
 Filename:  20080812131939578.pdf
 Filesize:  54.61 KB
 Downloaded:  544 Time(s)
CINDY_LITTLE.vcf
 Filename:  CINDY_LITTLE.vcf
 Filesize:  4.19 KB
 Downloaded:  535 Time(s)
Lynn Matteson
PostPosted: Wed Sep 16, 2009 3:51 pm    Post subject: INVOICE AS REQUESTED Reply with quote
Thanks for the info, Peter. I'll have a look around the US first, and
if I have to, I'll use your vendor.
What I like about doing it at home is the concrete floor....lets the
engine hoist roll much easier than the carpeted dirt of the hangar .
But you are correct, it would be easier to start at the hangar, and
then decide...based on temperature, etc. No reason to fold those
wings unless I have to.
Lynn Matteson
Jabiru 2200, #2062, 770.6 hrs
Countdown to 1000 hrs~230 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
On Sep 16, 2009, at 6:46 PM, Peter Harris wrote:
Lynn,
spent a good
are high
in the
Peter
Lynn
Kitfox IV-Jabiru 2200
N369LM
pjdisher(at)bigpond.com
PostPosted: Wed Sep 16, 2009 5:16 pm    Post subject: INVOICE AS REQUESTED Reply with quote
G'Day Lynn, I just found out this morning that RevMaster carbys supply
bends.
Pete D
VH-PDI
Lynn Matteson
PostPosted: Thu Sep 17, 2009 2:13 am    Post subject: INVOICE AS REQUESTED Reply with quote
Good morning, Pete-
Would these be the size bends needed for the Jabiru intake
manifolding tubes? I believe they are 1 -1/4" in size. I'll search
their website....thank you. Pete.
Lynn Matteson
Status: flying
On Sep 16, 2009, at 9:15 PM, peter disher wrote:
<pjdisher(at)bigpond.com>
supply bends.
Pete D
VH-PDI
Lynn
N369LM
PostPosted: Thu Sep 17, 2009 3:11 am    Post subject: INVOICE AS REQUESTED Reply with quote
Give them a quick call Lynn, there No. 760-244-3074 revavia(at)aol.com
Pete D
Lynn Matteson
PostPosted: Thu Sep 17, 2009 8:15 am    Post subject: INVOICE AS REQUESTED Reply with quote
I went to their website, Pete, and lo and behold, they're in the US!
Just goes to show what happens when I "played" photographer for 22
years, and sort of lost track of what was happening in the automotive
field, and I never got started into the aircraft field...except for
model airplanes...until 2004. Sheeeesh!
Back in the day, I used to be a dealer for Cyclone Exhaust products,
and I would get all sorts of exhaust pipe tubing shapes from them,
and weld up race car exhaust systems. Now it looks like I'll be
heading in that direction again....kinda like coming full circle, eh?
Lynn Matteson
Status: flying
Pete D
Lynn
N369LM
