n963wb(at)frontiernet.net Guest
Posted: Fri Apr 07, 2006 6:37 am Post subject: 406 Mhz PLB |
Greetings all,
Some time ago there was a discussion about the requirement for the new 406 Mhz PLB. I went to an FAA site and after wading through countless pages knew less than when I started. It appeared that it was going to be an ICAO requirement only, which would mean the 121.5/243.0 would still be monitored in the US. I was on the Aviation Digital Data Service site today and they were able to say in one sentence what took the FAA hundreds of pages to say (and left me clueless). Apparently the current ELT system will shut down on 2/1/09. There after only the 406 Mhz PLB will be monitored. If anyone wants to get the understandable explanation of this new system, go to ADDS and you will see on the opening page the links to get the correct information. I'm glad I ran into this info as I can now return the Ameri-King ELT, that I just bought, and get a full refund towards the purchase price of the more expensive 406 Mhz unit.
I would put the ADDS address here but it is about a foot long. If you don't already have ADDS in your favorite list, use any search engine and type in ADDS. Aviation Digital Data Service will be one of the first to come up. There is also an wealth of weather data available on this site.
Dick Neitzel
Sayner, WI
701 Jabiru 2200
About 70% Hope to be on the gear by end of week end.
daberti(at)sbcglobal.net Guest
Posted: Fri Apr 07, 2006 11:49 am Post subject: 406 Mhz PLB |
not really, the ELT info is on the first page
http://adds.aviationweather.noaa.gov/
Dave
..........I would put the ADDS address here but it is about a foot long.
Posted: Fri Apr 07, 2006 1:44 pm Post subject: 406 Mhz PLB |
I found the new ELT information here:
http://www.sarsat.noaa.gov/
Paul
XL wings
At 12:41 PM 4/7/2006, you wrote:
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Posted: Fri Apr 07, 2006 7:16 pm Post subject: 406 Mhz PLB |
The cheapest 406 MHz unit I know of is the Artex ME406
(http://www.artex.net/me406.html), under $1000.
If you find yourself faced with posting a very long web address (URL) use
http://tinyurl.com to create a short equivalent. The tinyURL for the link
above is http://tinyurl.com/nwjoa. Not a very impressive demo but it will
create an equally short address for ones hundreds or thousands of characters
long.
BTW "PLB" is a misnomer for an ELT. A Personal Locator Beacon is typically a
portable, hand-held device (also on 406 MHz) and generally cheaper than a
406 MHz aircraft ELT. You can get one including an internal GPS for around
$800 (I'm ignoring the units intended for marine use). The down-side is that
they have to be manually activated.
-- Craig
n801za(at)hotmail.com Guest
Posted: Sat Apr 08, 2006 10:23 am Post subject: 406 Mhz PLB |
Does anyone know if there are COM receivers that will let us monitor the new
406mhz ELT frequency, or will it only be monitored by the sattellites? I
see that currently available 406 ELTs transmit on both, but will that be the
case after the changeover in 2009?
Jim Frisby
Alaska
cgalley(at)qcbc.org Guest
Posted: Sat Apr 08, 2006 12:49 pm Post subject: 406 Mhz PLB |
Don't think you would hear much being a digital pulsed signal. Still will
have the old low power 121.5 transmitting continuously to home on. The
digital pulsed signal is the reason that can increase the transmitted power
to 5 watts and have the batteries last so long. Shortly there should be an
article on 406 MHz I wrote for Sport Pilot.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
