QB Fuse Question
Phil.Perry(at)netapp.com
PostPosted: Thu Sep 10, 2009 10:38 am    Post subject: QB Fuse Question Reply with quote
Last night, my QB fuse was delivered. It’s been a long wait and I’m excited to get started again.
I haven’t removed the floors yet, but hopefully I’ll get started on that later today after I’ve finished the inventory.
It’s pretty obvious that every floor board needs to come out. My question is specific to the forward most floor boards.
The Landing Gear mount has a leg that goes forward and the foot is attached to the floor with some bolts. I’m 99% sure that I need to remove this floor board, but it looks like I have to remove the landing gear mount to do so. This contradicts their intent, because the landing gear mount is already torque’d to the center section carry-thru and the nuts are sealed with Torque Seal.
I can’t imagine them going through the trouble to torque the nuts and apply Torque Seal if they wanted you to remove the landing gear – so you could ultimately remove the forward floor board.
What have others done? Is it possible to pull the forward floor board without removing the landing gear mount?
Phil
Tim Olson
PostPosted: Thu Sep 10, 2009 12:22 pm    Post subject: QB Fuse Question Reply with quote
I pulled mine. Found some clecos, a couple 12" drill bits,
and I think a pliers or some sort of tool under there.
If you can be assured that yours has no "stuff" under it,
and you don't intend to insulate, you could probably leave
them. I put in 3/4" foam to dampen the sounds coming
off the engine.
Tim Olson - RV-10 N104CD
Phil
gengrumpy(at)aol.com
PostPosted: Thu Sep 10, 2009 12:39 pm    Post subject: QB Fuse Question Reply with quote
I did not pull mine, but ran a magnet and vacuumed it well.
grumpy
N184JM
off the engine.
> Phil
Jim Berry
PostPosted: Thu Sep 10, 2009 2:01 pm    Post subject: Re: QB Fuse Question Reply with quote
I was able to vacuum that area by using a piece of soft 1" hose as an extension on my shop vac. It is also possible to insert insulation from the aft edge of the floor boards, sliding each piece forward. It helps if you have small hands. Use the rivet lines on the bottom of the fuselage to make a pattern for each piece of insulation.
Jim Berry
40482
N15JB
dmaib@me.com
PostPosted: Thu Sep 10, 2009 2:05 pm    Post subject: Re: QB Fuse Question Reply with quote
I pulled the left one and was sorry I did. It was a very difficult job and I was concerned that I was going to damage something the entire time. I decided not to remove the right side for that reason. You do have to remove the fasteners from the gear weldment. I felt as if I was undoing work I had paid to have done. Van's does not intend for the builder to remove the front floors on the QB.
$.02 worth
David Maib
RV-10 #40559
New Smyrna Beach, FL
PostPosted: Thu Sep 10, 2009 3:12 pm    Post subject: QB Fuse Question Reply with quote
Sounds like the consensus is to leave it in....
It sure would have been nice if they installed the right rivets to begin
with. Smile
They just have a couple dome headed pop-rivets in the dimpled holes to
hold the panels in place. Sounds like I've got a pretty good chance of
having some rivet tails floating around between the belly skin and the
floor board.
That's a little concerning since it could contribute to a control
surface jam later on.
I'm sure I'll figure it out, just like all the folks before me.....
Thanks again everyone.
Phil
roxianmike(at)msn.com
PostPosted: Thu Sep 10, 2009 4:26 pm    Post subject: QB Fuse Question Reply with quote
Sounds like maybe I was in the minority. I removed the forward floorboards (yes it is a pain to get the gear mounts out) but I am glad I was able to inspect C prime C insulate.  My motivation was to eliminate any little voice in my head in my flying future reminding me I had not inspected every inch of the airframe.
Subject: QB Fuse Question
Date: Thu C 10 Sep 2009 11:36:28 -0700
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri' C'sans-serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Calibri' C'sans-serif';color:windowtext;} .ExternalClass .EC_MsoChpDefault {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Last night C my QB fuse was delivered.  It’s been a long wait and I’m excited to get started again.
I haven’t removed the floors yet C but hopefully I’ll get started on that later today after I’ve finished the inventory.
The Landing Gear mount has a leg that goes forward and the foot is attached to the floor with some bolts.  I’m 99% sure that I need to remove this floor board C but it looks like I have to remove the landing gear mount to do so.  This contradicts their intent C because the landing gear mount is already torque’d to the center section carry-thru and the nuts are sealed with Torque Seal.
Phil
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
n223rv(at)wolflakeairport
On my buddies -10 (mine is a slow build) we pulled them, cleaned and
primed underneath them, installed insulation, then riveted them back
in. It really does not tale very long to remove the bolts.....
On Sep 10, 2009, at 7:07 PM, "Perry, Phil" <Phil.Perry(at)netapp.com>
begin
with. Smile
of
floor board.
Phil
dlm46007(at)cox.net
PostPosted: Thu Sep 10, 2009 5:17 pm    Post subject: QB Fuse Question Reply with quote
No front or rear floor rivet debris could cause a control jam; the controls
are not near these areas at all.
AirMike
PostPosted: Thu Sep 10, 2009 5:44 pm    Post subject: QB Fuse Question Reply with quote
I did not remove the front floor boards either, but worry that there might be some stuff down there. If I were building over again, I would nut plate the rear floorboards for inspection/maintenance and smuggling drugs.
Seriously though, at the very least I would install a maintenance plate over the boarding step bolts. (I did do that)
Inspection plate for step
 Filesize:  1.48 MB
 Viewed:  12553 Time(s)
See you OSH '18
Q/B - sold.
johngoodman
PostPosted: Thu Sep 10, 2009 6:36 pm    Post subject: Re: QB Fuse Question Reply with quote
I did not pull them. Used a strong magnet to move any metal stuff where it can be removed, and vacuumed. For insulation, I used Abesco FP200 fire rated expansion foam. I like it so much I'm thinking about using it in other places.
John
 Filesize:  10.4 KB
 Viewed:  12545 Time(s)
MauleDriver(at)nc.rr.com
PostPosted: Thu Sep 10, 2009 7:16 pm    Post subject: QB Fuse Question Reply with quote
I started to do the same and decided to stop..."I felt as if I was
undoing work I had paid to have done". Even more important, the work I
could see looked as good or better than what I was doing. I moved on.
May have been a more critical issue for the earlier serials
Bill Watson 40605
$.02 worth
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p 62486#262486
dlm46007(at)cox.net
PostPosted: Thu Sep 10, 2009 8:22 pm    Post subject: QB Fuse Question Reply with quote
Aluminum is non magnetic; strong magnet only moves ferrous metals. A thin
nylon tube tape to the end of a shop vacuum line may get some.
dlm46007(at)cox.net
PostPosted: Thu Sep 10, 2009 8:25 pm    Post subject: QB Fuse Question Reply with quote
I had QB fuselage #8 dated 3/2005 and the work was excellent. Filipinos are
by far the best craftsman as a whole in the Asian sub continent.
