Query re:- Jeppesen 1:500,000 VFR/GPS Chart.
ptag.dev(at)tiscali.co.uk
PostPosted: Tue Sep 08, 2009 1:45 am    Post subject: Query re:- Jeppesen 1:500,000 VFR/GPS Chart. Reply with quote
Hi! ALL in the UK.
At the expense of looking a "bo bo"
What does the note no. 27 mean off Clacton VFR Prohibited? Or how is it
explained by their references...Clacton CTA 1,3-5,8,9,11-14.?
Prompt assistance would be appreciated. Approach route needed for return to
Elstree from Texel Saturday.
Bob Harrison G-PTAG
Rowland_Carson
PostPosted: Tue Sep 08, 2009 2:12 am    Post subject: Query re:- Jeppesen 1:500,000 VFR/GPS Chart. Reply with quote
Bob - it means what it says on the can - VFR prohibited in that
airspace. However, if you're below FL55 (or FL65 further out to sea)
you will be underneath the controlled airspace and so OK for VFR.
The UK CAA half-million chart makes this a bit easier to see & understand.
regards
Rowland
| Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
PostPosted: Tue Sep 08, 2009 4:43 am    Post subject: Query re:- Jeppesen 1:500,000 VFR/GPS Chart. Reply with quote
Thanks Rowland,
I was aware that Amsterdam is Flight Level 55 but didn't notice the same
implication for the Clacton factor for some reason probably, senility !
I'll think of you when under it (or the sea!) on Saturday !
Bob H
