Converting Five Rib Wing To 10 Ribs?
WhiskeyVictor36(at)AOL.CO
PostPosted: Fri Apr 07, 2006 9:03 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
Alan Mancus is rebuilding his wind damaged FireStar. He would like to have
a seven rib wing. But previous discussions on the list pointed out the
difficulty of moving the ribs (cannot slide because of burrs creating scratches in
the main spar tube) and leaving empty holes, etc.
What do you think of this idea?
On the 5 rib wing, there is one lower false rib centered between each full
rib and there are 3 upper false ribs divided between each full rib. Remove
the center upper and centered lower false ribs. Get another set of full ribs
and cut them in half, right through the center of the main spar flange. With
the rib assembly now in two pieces, assemble them onto the wing spars were
the false ribs were removed. Form a sheet metal piece, similar to the flange
thickness, to splice the cut flanges back together. Fasten the new ribs to
the spars (main, leading and trailing) the same way as the existing ribs are.
This would make the wing much stronger and able to tolerate a higher Vne.
(five rib wings are redlined at 75 MPH). The penalty would be a heavier
structure.
Pass on your thoughts.
Bill Varnes
Original Kolb FireStar
Audubon NJ
slyck(at)frontiernet.net
PostPosted: Sat Apr 08, 2006 3:45 am    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
Bill, not a bad idea but here's another thought to add:
buy double the amount of flanges to be used and cut them
oversized to overlap the other piece by 1 1/2" or so.
Put the overlap joint at the top and bottom to reduce the
shear load on the rivet pattern..
-BB
to have
the
scratches in
full
Remove
full ribs
flange. With
were
the flange
ribs to
ribs are.
Vne.
heavier
structure.
Bill Varnes
Audubon NJ
Eugene Zimmerman
PostPosted: Sat Apr 08, 2006 12:01 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
Bill.
It could be possible.
I would want to keep the top and bottom tubes of the ribs all one piece.
You may be interested in seeing how the Kolb rip off guys make their
ribs.
Check these wing details.
http://n5.se/sK
http://n5.se/sQ
http://n5.se/sR
Please understand I'm not recommending this, just showing you some
ideas.
Gene
each full
rib. Remove
of full ribs
flange. With
spars were
the flange
new ribs to
existing ribs are.
higher Vne.
heavier
structure.
Eugene Zimmerman
PostPosted: Sat Apr 08, 2006 1:20 pm    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
Sorry about the dead links.
I'll attach the actual photos.
 Filesize:  106.53 KB
 Viewed:  658 Time(s)
 Filesize:  81.45 KB
 Viewed:  622 Time(s)
 Filesize:  47.79 KB
 Viewed:  627 Time(s)
 Filesize:  127.11 KB
 Viewed:  631 Time(s)
a58r(at)verizon.net
PostPosted: Sat Apr 08, 2006 1:23 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
re: http://n5.se/sK etc. "Document Not Found"
regards,
Bob N.
Eugene Zimmerman
PostPosted: Sat Apr 08, 2006 1:34 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
Sorry Bob,
I was trying to avoid using the "F" word but it didn't work as intended.
Trust you can open the attachments.
Gene
regards,
Bob N.
PostPosted: Sat Apr 08, 2006 2:10 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
That is a nice wing. The tip bow could use an anti-shrink support in
the
last half.
No flanges! they don't worry much about twisting moment.
-BB do not archive
On 8, Apr 2006, at 5:33 PM, Eugene Zimmerman wrote:
<etzim62(at)earthlink.net>
Sorry Bob,
intended.
Gene
> regards,
> Bob N.
> http://www.angelfire.com/rpg/ronoy/
> do not archive
planecrazzzy
PostPosted: Sat Apr 08, 2006 4:58 pm    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
OK,
In the Kolb plans....Your NOT suppose to rivet on the "TOP" or
the "BOTTOM" of the wing spar.....because it would weaken it.....where it
does it's flexing..... you have rivets all over that area.....why ?
Is that a Kolb wing ?
Gotta Fly...
Mike in MN
planecrazzzy
PostPosted: Sat Apr 08, 2006 5:04 pm    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
Oooops,
I see it's a Fergie.....Still , a bad place for those rivets...
PostPosted: Sat Apr 08, 2006 6:22 pm    Post subject: Converting Five Rib Wing To 10 Ribs? Reply with quote
In a message dated 4/8/2006 5:23:42 P.M. Eastern Standard Time,
etzim62(at)earthlink.net writes:
Thanks Gene,
I see that they have the ribs attached by a bracket or gusset riveted to the
very top of the main spar. This is one area that "Kolb" recommended no
holes be drilled.
Bill Varnes
Audubon NJ
In a message dated 4/8/2006 7:45:41 A.M. Eastern Standard Time,
slyck(at)frontiernet.net writes:
OK BB, Another good idea to consider.
Bill Varnes
Audubon NJ
Possum
PostPosted: Sat Apr 08, 2006 10:17 pm    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
Here are some better ones. Very Happy
 Filesize:  110.96 KB
 Viewed:  584 Time(s)
 Filesize:  191.18 KB
 Viewed:  639 Time(s)
John Jung
PostPosted: Sun Apr 09, 2006 7:34 am    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
Bill,
I like the idea, and I think that I might use it if I were recovering a 5 rib wing. I used to fly with an original Firestar, but after seeing pictures of a failed leading edge on a five rib firestar, I have a strong preference for 7 ribs. If I ever put new wings on my Firestar II, they will be of the 6" spar varity (i.e. Mark III, Kolbra, Slingshot). do not archive
John Jung
Firestar II N6163J
Surprise, AZ
JetPilot
PostPosted: Tue Apr 11, 2006 8:56 am    Post subject: Re: Converting Five Rib Wing To 10 Ribs? Reply with quote
I really like the idea of douling the number of ribs in the wing. That will only add a few pounds and will make it a lot stronger.
If more ribs becomes to daunting a task, streingthening the existing ribs is also a possibility. Attached are some pictures of my MK-III wing with rib streingthening.
I would also suggest streingthening the wingtips while you are at it. There have been a few reports of wingtip flutter at high speeds, and also that is just a fragile area that gets a lot of abuse and handling. Streingthening that area is just a good idea.
 Filesize:  96.09 KB
 Viewed:  574 Time(s)
 Filesize:  80.21 KB
 Viewed:  608 Time(s)
 Filesize:  160.79 KB
 Viewed:  610 Time(s)
Kolb MK-III Xtra, 912-S
