cazw(at)ihug.co.nz Guest
Posted: Fri Apr 07, 2006 12:54 am Post subject: RV6 Control column |
Listers
Trying to set up the control columns per the instructions and refering to DWG 41 I find that I cannot get the sticks parallel while maintaining the stated measurements. The 19 inch bolt centre measurement for the end bearings on the F-665 seems a little too long. With everything in place tops of the control sticks slope slightly inward ie the distance between the tops of the stick is about an inch less than down near the pivot points. I have wound the rod end bearings in as far as they can go, and have double checked all measurements making sure the weldments are correctly manufactured etc, and all seem to be correct. The easy fix would appear to simply shorten the F-655 to suit, but am reluctant to commit to that option without some advice first.
Has anyone else struck this or am I missing something?
Clive Whittfield
New Zealand
RV6 Fuselage
flyrv6(at)bryantechnology Guest
Posted: Fri Apr 07, 2006 7:10 am Post subject: RV6 Control column |
Clive,
I would make the sticks parallel to your liking by shortening the rod.
Cutting it shorter if needed also. Mine are parallel and I have no idea
what the length of the rod is.
IMHO
Posted: Fri Apr 07, 2006 7:31 am Post subject: RV6 Control column |
Check where the sticks attach to the brackets that mount to the spar. You can change washers inboard or outboard to modify the angle of the dangle. Actually, you should first check that the spar attach brackets are correctly mounted......
After setting mine up it came out parallel - but I don't have enough threads left to turn either heim joint a full turn inboard...that tells me that they're close right out of the box.
Ralph Capen
stevea(at)svpal.org Guest
Posted: Fri Apr 07, 2006 9:50 am Post subject: RV6 Control column |
Clive,
I had the same problem. My fix was to trim the F-655 ends and tap the
rod end holes deeper. Do what you need to make the control columns
parallel.
Steve
RV-6A
Clive Whittfield wrote:
| Quote: | Trying to set up the control columns per the instructions and refering to DWG 41 I find that I cannot get the sticks parallel while maintaining the stated measurements. The 19 inch bolt centre measurement for the end bearings on the F-665 seems a little too long. With everything in place tops of the control sticks slope slightly inward ie the distance between the tops of the stick is about an inch less than down near the pivot points. I have wound the rod end bearings in as far as they can go, and have double checked all measurements making sure the weldments are correctly manufactured etc, and all seem to be correct. The easy fix would appear to simply shorten the F-655 to suit, but am reluctant to commit to that option without some advice first.
HCRV6(at)comcast.net Guest
Posted: Fri Apr 07, 2006 10:11 am Post subject: RV6 Control column |
Clive,
I had the same issue and solved it the same way Steve did as described below. Do what you have to do to make it right.
Harry Crosby
RV-6 N16CX, 198 hours
-------------- Original message ----------------------
Clive,
parallel.
Steve
RV-6A
tcervin(at)valkyrie.net Guest
Posted: Fri Apr 07, 2006 3:28 pm Post subject: RV6 Control column |
Steve, I had to do the same thing on my RV6-A.
Tom in
Ohio
