li
Posted: Fri Sep 04, 2009 6:31 pm Post subject: micro-turbojet engine |
We can supply the micro-turbojet engine HN-40-20 ; HN-40-65 ; HN-40-45 . Our products are superior in quality and moderate in price and are sure to be sellable in your market. If who are interested in it,pls feel free to contact us.My e-mail address is fishahah(at)hotmail.com
li
Posted: Thu Sep 10, 2009 6:41 pm Post subject: Re: micro-turbojet engine |
The engine HN-40-65:
A. General
The micro-turbojet engine HN-40-65(hereafter referred to as the turbojet) is a highly reliable, low-cost, single-shaft turbine jet engine. It consists of centrifugal compressor, bearing lubricating system, annular firebox, radial turbine, simple convergent nozzle and electron fuel controller.
The thrust of HN-40-65 is 650N . The engine is developed and whole owned by our company.
B. Description
The engine HN-40-65 consists of the following six parts:
a) Inlet assembly: The S/A consists of an inlet duct which is taken the shape of hyperbola and a center body located at the rear of the inlet duct. The inlet duct conducts the air into the compressor with less pressure drop. The center body is supported by three rods, apart from each other by 120°. The center body contained a starting motor.
b) Compressor: The S/A consists of centrifugal rotor, radial diffuser and axial diffuser. The clip bush of the bearings and the bearing lubricating system are fixed at the rear of the diffuser.
c) Firebox: The S/A consists of main fuel supply system, starting fuel supply system, igniting device, flame canister and the housing.
d) Turbine: The S/A consists of a guided ring and a radial turbine.
e) Nozzle: It is a simple convergent nozzle.
f) Fuel control system: The S/A consists of Digital Fuel Electronic Control Unit (ECU) and fuel pump.
li
Posted: Thu Sep 10, 2009 6:43 pm Post subject: Re: micro-turbojet engine |
Better to do well than to say well.welcome your any inquiry or idea.
Xi'an Lichuang Electronic Technology Co.,Ltd
Add: B-2308 Zhongtian International Mession,Taibai Road,Xi'an ,China
Tel:86-29-88259015 ext.601
Fax:86-29-88227919
EMail : fishahah(at)hotmail.com
SKYP:fishahah
ICQ:579991829
li
Posted: Thu Sep 10, 2009 6:46 pm Post subject: Re: micro-turbojet engine |
we export all "Aircraft Parts" over 8 years,based in China cooperating with national institute of aeronautics.
the Spark Plugs,Brake Pads,Brake Drum,Propeller Blade,Brake Ring,Aircraft Tires,TUrbojet Engine,NanChang CJ6/PT6...are our best sellers.
