larywil(at)comcast.net Guest
Posted: Tue Sep 01, 2009 5:07 pm Post subject: Aerobatics in a 140 and the recipe for sausage |
Boy, I was ready to quit Matt's list because of the onset of boredom.
Thanks for saving me RV6ator Bill.
So, I think DICKWEED and ASSHOLE is actually part of the recipe for
the sausage that we sometimes get at the local air show. I'm sure
Bill had too many of them at 'Kosh, and he accidently regurgitated
them in his post.
OK, back to the subject. I do NOT believe that the FAA defines an
aerobatic aircraft. They do define aerobatics ( or aerobatic
maneuvers ). They do this because there are restrictions on when and
where you may perform aerobatics.
As Mike pointed out, the FAA does make it clear that you may not
exceed the limitations stated in the manual, makings and placard. So,
if an aircraft is approved for, say +3 and -1.5 G's, and the manual,
markings, and placards do not specifically prohibit a loop, then I
suppose you may legally perform loops the aircraft ( if you are in an
FAA permitted area).
That being said, you would still be considered a moron if you tried
to loop the aforementioned aircraft. You might get away with it a few
times, but.....
Mike, would you care to comment.
Louis I Willig
1640 Oakwood Dr.
Penn Valley, PA 19072
610 668-4964
RV-4, N180PF
190HP IO-360, C/S prop
mrobert569(at)hotmail.com Guest
Posted: Wed Sep 02, 2009 4:25 pm Post subject: Aerobatics in a 140 and the recipe for sausage |
No comment needed at this point. You pretty much said it all.
But just because it may be legal does not make it smart. I highly encourage getting training in ANY manuver of any type of aircraft that you have not done before. I C too C have lost friends doing stupid things and don't want to lose any more. But please remember C as in this discussion C there can be a difference between what is leagl and what is smart and safe.
Mike Robertson
[quote] Date: Tue C 1 Sep 2009 20:59:21 -0400
To: rv-list(at)matronics.com
Subject: Aerobatics in a 140 and the recipe for sausage
--> RV-List message posted by: Louis Willig <larywil(at)comcast.net>
Boy C I was ready to quit Matt's list because of the onset of boredom.
So C I think DICKWEED and ASSHOLE is actually part of the recipe for
Bill had too many of them at 'Kosh C and he accidently regurgitated
them in his post.
OK C back to the subject. I do NOT believe that the FAA defines an
As Mike pointed out C the FAA does make it clear that you may not
exceed the limitations stated in the manual C makings and placard. So C
if an aircraft is approved for C say +3 and -1.5 G's C and the manual C
markings C and placards do not specifically prohibit a loop C then I
That being said C you would still be considered a moron if you tried
times C but.....
Mike C would you care to comment.
Louis I Willig
1640 Oakwood Dr.
Penn Valley C PA 19072
610 668-4964
RV-4 C N180PF
190HP IO-36=======================
With Windows Live C you can organize C edit C and share your photos. Click here.
RV6ator(at)AOL.COM Guest
Posted: Wed Sep 02, 2009 4:46 pm Post subject: Aerobatics in a 140 and the recipe for sausage |
hey guys, aircraft are CERTIFIED in a variety of CATEGORIES, normal, utility, aerobatic, experimental, experimental exhibition, and restricted. Most Cessna/Piper/Beech and other production aircraft are certified normal category and can be flown in the utility category at reduced gross weights, to allow for higher G-loading. An Aerobatic category aircraft has to meet certain requirments, including a quick egress system. For example Cessna built a 152 Aerobat for several years, it included larger C-172 struts, a beefier tail, and quick release doors. get the idea.
bill mahoney
In a message dated 9/2/2009 8:26:59 P.M. Eastern Daylight Time, mrobert569(at)hotmail.com writes:
| Quote: | No comment needed at this point. You pretty much said it all.
But just because it may be legal does not make it smart. I highly encourage getting training in ANY maneuver of any type of aircraft that you have not done before. I, too, have lost friends doing stupid things and don't want to lose any more. But please remember, as in this discussion, there can be a difference between what is legal and what is smart and safe.
Mike Robertson
| Quote: | Date: Tues, 1 Sep 2009 20:59:21 -0400
--> RV-List message posted by: Louis Willing <larywil(at)comcast.net>
Bill had too many of them at 'Kosh, and he accidentally regurgitated
them in his post.
times, but.....
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
With Windows Live, you can organize, edit, and share your photos. Click here. |
jsflyrv(at)verizon.net Guest
Posted: Wed Sep 02, 2009 7:37 pm Post subject: Aerobatics in a 140 and the recipe for sausage |
The fact that Mr Mahoney is still posting here makes me think that the
list has finally "jumped the shark"
RV6ator(at)aol.com wrote:
| Quote: | hey guys, aircraft are CERTIFIED in a variety of CATEGORIES, normal,
bill mahoney
Mike Robertson
> From: larywil(at)comcast.net
boredom.
regurgitated
> them in his post.
and
placard. So,
manual,
in an
a few
> times, but.....
> Louis I Willig
> 1640 Oakwood Dr.
> 610 668-4964
> RV-4, N180PF
Click here. <http://www.windowslive.com/Desktop/PhotoGallery>
="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
