don.curry(at)inbox.com Guest
Posted: Sat Aug 29, 2009 6:51 am Post subject: Transponder Re-Check? |
I just had my biennial transponder/encoder certification (IAW FAR 91.413)
done. The system passed and log book was signed off. On the very next
flight, the transponder acted up. I had it pulled and sent off for repairs
and it is due back Monday with a fresh 8130. Will I need another
transponder/encoder cert IAW 91.413? Don
____________________________________________________________
FREE 3D EARTH SCREENSAVER - Watch the Earth right on your desktop!
Check it out at http://www.inbox.com/earth
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
bakerocb
Posted: Sun Aug 30, 2009 4:38 am Post subject: Transponder Re-Check? |
8/30/2009
Don Wrote "Will I need another transponder/encoder cert IAW 91.413?"
Here is what 91.413 says:
"91.413 ATC transponder tests and inspections.
(a) No persons may use an ATC transponder that is specified in 91.215(a),
121.345(c), or §135.143(c) of this chapter unless, within the preceding 24
calendar months, the ATC transponder has been tested and inspected and found
to comply with appendix F of part 43 of this chapter; and
(b) Following any installation or maintenance on an ATC transponder where
data correspondence error could be introduced, the integrated system has
been tested, inspected, and found to comply with paragraph (c), appendix E,
of part 43 of this chapter."
It would appear that if you could satisfy yourself in some manner
(preferably documented) that "data correspondence error" could not be
introduced either by the repair or your subsequent reinstallation then no
Appendix E recheck would be required.
First flights after reinstallation should include some airborne check of the
system with ATC.
Why not ask the people who just did your check what their opinion is --
realizing that it may not be entirely unbiased.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 07:51:42 AM PST US
Subject: Transponder Re-Check?
