Need KT-70 pinout and instruction manual.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
galsys(at)bezeqint.net
PostPosted: Wed Sep 02, 2009 11:26 pm    Post subject: Need KT-70 pinout and instruction manual. Reply with quote
Hi
I am in need of the KT-70 mode S transponder pinout and operating manual.
Gabe
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Gaby_Levin.vcf
 Filename:  Gaby_Levin.vcf
 Filesize:  337 Bytes
 Downloaded:  2197 Time(s)
don.curry(at)inbox.com
PostPosted: Thu Sep 03, 2009 1:14 am    Post subject: Need KT-70 pinout and instruction manual. Reply with quote
Gabe
Here's an excerpt from a manual on King Silver Crown equipment. It is the
closest thing to an operating manual I have seen. Hope it helps.
Don
[quote] --
Pilot_Guides_-_King_Silver_Crown_PG,_KT-70.pdf
 Filename:  Pilot_Guides_-_King_Silver_Crown_PG,_KT-70.pdf
 Filesize:  164.05 KB
 Downloaded:  5593 Time(s)
PostPosted: Thu Sep 03, 2009 1:55 am    Post subject: Need KT-70 pinout and instruction manual. Reply with quote
Thanks Don,
It helped me a lot.
I will have to digg for pinout as well.
thanks again.
Gaby
Hi Don,
Do you know how to programm the unique aircraft 8 digit codes ?
Gaby
PostPosted: Thu Sep 03, 2009 2:08 am    Post subject: Need KT-70 pinout and instruction manual. Reply with quote
That information is in the install manual, which I sent directly to your
email address (it was too large for Matronics).
Don
[quote] --
PostPosted: Thu Sep 03, 2009 2:17 am    Post subject: Need KT-70 pinout and instruction manual. Reply with quote
Ok,
I'll await for the installation manual
n4291p
PostPosted: Mon Sep 14, 2009 2:56 am    Post subject: Re: Need KT-70 pinout and instruction manual. Reply with quote
Hello Don,
I to need a pin out and operating manual for the KT-70 mode S transponder and do you know how to program the aircraft 8 digit codes
Thanks for your help.
Jan Prikkel jr
pipercomp
PostPosted: Mon Dec 17, 2018 10:41 am    Post subject: Re: Need KT-70 pinout and instruction manual. Reply with quote
[quote="don.curry(at)inbox.com"]
Gabe
Don
Hi I'm not sure how to use this site and my request is a bit cheeky but I'm also looking for information on how to program a Kt 70 to take the aircraft code. I have looked everywhere and had no luck
Any help will be much appreciated
Steve Charters
pipercomp
PostPosted: Mon Dec 17, 2018 10:11 pm    Post subject: Re: Need KT-70 pinout and instruction manual. Reply with quote
I also have a CD with most of the Bendix King Kit pinouts if anyone needs anything
Jackeyb
PostPosted: Mon Mar 11, 2019 9:36 am    Post subject: Re: Need KT-70 pinout and instruction manual. Reply with quote
Hi I am also looking for the install manual for KT 70 transonder
and pin out for same
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
