Posted: Sat Aug 29, 2009 6:10 pm Post subject: turnbuckles and aircraft hardware |
Tony C
When I was working on my plane last year C I needed some turnbuckles C too. I found an outfit that sells "brand new surplus" turnbuckles for about $7.50 each C for the complete assembly C instead of $30 from Aircraft Spruce.
I order plenty of stuff from Aircraft Spruce C but these turnbuckles are the exact same items at 1/4th the cost. They are genuine aircraft hardware C identical to the ones that came with my MkIII kit.
I also ordered some other items from these folks C like pulleys C and AN nuts & bolts. I tried finding them online C and I THINK this is them.
http://www.preferredairparts.com/hardware.htm
Mike Welch
MkIII
Windows Live: Keep your friends up to date with what you do online. Find out more. [quote][b]
planecrazzzy Guest
Posted: Tue Sep 01, 2009 3:17 pm Post subject: Re: turnbuckles and aircraft hardware |
Somebody got a quote from this place today...
I paid $160 for 8 Turnbarrels... at ACS
The place your saying that's cheaper , wanted $207 for the same thing
Gotta Fly...
Mike & "Jaz" in MN
Alternative Kolb List - http://groups.yahoo.com/group/kolbaircraft/
1.15 MB |
13825 Time(s) |
Posted: Tue Sep 01, 2009 3:34 pm Post subject: turnbuckles and aircraft hardware |
I said "I think that's them"
[quote]>I also ordered some other items from these folks C like pulleys C and AN nuts & bolts. I tried >>finding them online C and I THINK this is them
planecrazzzy Guest
Posted: Tue Sep 01, 2009 4:02 pm Post subject: Re: turnbuckles and aircraft hardware |
Ahhhh,
Well it still looks like a good "Link" to add to the
other Kolb site... We're looking for alternative "anything"
Gotta Fly...
Mike & "Jaz" in MN
Kolb site - http://groups.yahoo.com/group/kolbaircraft/
Possums
Posted: Wed Sep 02, 2009 7:06 pm Post subject: turnbuckles and aircraft hardware |
At 07:17 PM 9/1/2009, you wrote:
| Quote: | --> Kolb-List message posted by: "planecrazzzy" <planecrazzzy(at)yahoo.com>
Gotta Fly...
Mike & "Jaz" in MN |
I had all my cables swaged this way ( elevator, rudder and tail wires)
by a guy near Aircraft Spruce in Griffin Ga.
He supplies the cables and fittings.
done with a rotary swaging tool
Did not cost as much as you think and looks real clean.
He does need to know the length from "hole to hole" on the attachment
points and they are only adjustable about an inch before you'll have to
start twisting the cables again. There is only a turnbuckle "pressed on" on one end.
I'm sure there are people like him all over the country.
159 KB |
13801 Time(s) |
_________________ Possum |
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Thu Sep 03, 2009 3:25 am Post subject: Re:Re: turnbuckles and aircraft hardware |
Possums writes:
| Quote: | | I had all my cables swaged this way ( elevator, rudder and tail wires) by a guy near Aircraft Spruce in Griffin Ga. He supplies the cables and fittings. done with a rotary swaging tool |
Possums,
I like the added safety factor of your dual-bracing set up. Could you please take a close up pic of the cable ends on both the fork and turnbuckle sides and post it?
Thanks -
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
aslsa.rng(at)gmail.com Guest
Posted: Thu Sep 03, 2009 4:47 am Post subject: turnbuckles and aircraft hardware |
35 years of flying cable braced aircraft and I've never put a turnbuckle in a structural cable. Cheapest turnbuckle cost then, $0. No multi hole tangs, either. Those things went out with the standard Rogallo in '76. Make your cables per the Kolb plans and you'll be just fine. Extra cables are extra weight, not extra safety. My 2 cents, ya'll do what you choose, it's your experiment.
Rick Girard
On Thu, Sep 3, 2009 at 6:25 AM, Jimmy Young <jdy100(at)comcast.net (jdy100(at)comcast.net)> wrote:
[quote]--> Kolb-List message posted by: "Jimmy Young" <jdy100(at)comcast.net (jdy100(at)comcast.net)>
Possums writes:
Possums,
Thanks -
Jimmy Young
FS II, HKS 700
N7043P
http://forums.matronics.com/viewtopic.php?p=261172#261172
le, List Admin.
JetPilot
Posted: Thu Sep 03, 2009 8:12 am Post subject: Re: turnbuckles and aircraft hardware |
| aslsa.rng(at)gmail.com wrote: |
Rick Girard
Rick,
My cables were made per Kolb plans, and they came with multi hole tangs. You contradict yourself... Your claim about extra cables no providing extra safety is just plain wrong and dangerous advice. Almost every airplane in the world that uses wire braced tails uses two sets of wires, there is a good reason for this. Given Jimmy Youngs recent picture, I am surprised to see a statement like yours from anyone. Had that tang let go, an extra set of tail bracing wires would have prevented a crash and almost certain death.
You recently very wrongly posted that we could not tell if properly designed wingtips would improve the flying characteristics of a Kolb, and that it is not worth doing. Now you post advice that is downright dangerous and false. If people do not want to improve the safety of their Kolbs by adding an extra set of tail wires, that is their choice. But you should not be making dangerous and materially false statements that will prevent people that want to make their make their Kolbs as safe as possible from doing so. You recently complained about my posts not being " Nice " while you post false information here that could get someone killed...
Given the picture below, and many documented cases of tang, swage, and wire failures in aviation history, Possums extra set of tail wires are a great idea, and a great safety improvement to his Kolb at a very minimal weight.
Mike
153.55 KB |
13784 Time(s) |
Kolb MK-III Xtra, 912-S |
planecrazzzy Guest
Posted: Thu Sep 03, 2009 8:59 am Post subject: Re: turnbuckles and aircraft hardware |
The Turnbarrels I bought weren't for my Kolb, They were for the
cross bracing cables in the Wings of my Wittman Buttercup
Attached to the Compression strut in the Middle and crossing to the
root end and to the wing tips...
My cables on my Kolb are Swagged...
Only turnbuckles are on my Rudder cables and Elevator...
Gotta Fly...
Mike & "Jaz" in MN
Kolb list- http://groups.yahoo.com/group/kolbaircraft/
PS the reason the "tang" let loose... Has to be from over tightening the
turnbarrel.... If it's done to print... your not gonna get it THAT tight...
Sometimes... people only THINK they are improving something...
78.21 KB |
13771 Time(s) |
108.48 KB |
13771 Time(s) |
112.88 KB |
13771 Time(s) |
zeprep251(at)aol.com Guest
Posted: Thu Sep 03, 2009 3:14 pm Post subject: turnbuckles and aircraft hardware |
Mike,
You really need to take a course in "How to disagree with someone".Your usual openers,Only a moron,or only an idiot,keep you from being the most regarded person on the list.Personally attacking the intelligence,intentions,or opinions of others is another one.You'll never build yourself up by tearing everyone else down.Just a thought,no offense.....
G.Aman
russ(at)rkiphoto.com Guest
Posted: Thu Sep 03, 2009 4:19 pm Post subject: turnbuckles and aircraft hardware |
MikeIMHO, Gary's got it really right, in spades.
I agree completely.Why don't you lighten up? Quit insulting everyone? Try it.
Russ K
On Sep 3, 2009, at 6:45 PM, zeprep251(at)aol.com (zeprep251(at)aol.com) wrote:
[quote] Mike,
G.Aman
Possums
Posted: Thu Sep 03, 2009 5:06 pm Post subject: turnbuckles and aircraft hardware |
At 06:45 PM 9/3/2009, you wrote:
| Quote: | Mike,
G.Aman
--> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com) >
this. |
Yeah - you "moron's and idiots" would need to build the tail different from the start
to have the two sets of tail wires anyway.
It's really not something you could go back & change. Gotta have the "sleeves" inside the
tubes where the bolts go thru (that are attached to the tangs) before you rivet the ribs, etc.
Anyway, I was just suggesting a different way to build the wires on the tail, not so much the tail
itself. It's pretty much standard aircraft stuff. I think the 8 tail wires cost about $25 each.
Not cheap, but affordable & nice and clean. You couldn't break them in a Kolb ......or a Pitts.
70.03 KB |
13762 Time(s) |
92.89 KB |
13762 Time(s) |
JetPilot
Posted: Thu Sep 03, 2009 6:14 pm Post subject: Re: turnbuckles and aircraft hardware |
| Possums wrote: |
I thought about taking my tail apart to get the sleeves in, but decided that was going to take way to much work, might as well build a new tail. For those that don't like the idea of their tangs breaking as in the picture below, there is a solution. Given the importance of this subject, I will start a new thread on it.
Mike
Possums
Posted: Thu Sep 03, 2009 6:41 pm Post subject: turnbuckles and aircraft hardware |
At 10:14 PM 9/3/2009, you wrote:
a new tail.
Mike
I wouldn't do it. I wouldn't have done it - if I hadn't had to do a
total rebuild anyway.
The old Firestar was fine the way it was - but it's nice to add all
the little things
you would like to have after you've been in the old one for years. "4
inch wider
cockpit is nice, a 505 dual carb, a 3 blade warp, different wing
tips, VG's, custom wires,
...........but I still got my old nose cone & stick & same ribs
(just 8 instead of 5) per
wing. I still miss the good times in my old 447 sometimes. But the
new one is better.
http://www.youtube.com/watch?v=EXVPO53BHrc
Possums
Posted: Sun Sep 13, 2009 2:13 pm Post subject: turnbuckles and aircraft hardware |
>Possums,
>post it?
>Thanks -
>Jimmy Young
>FS II, HKS 700
I just use 1/2 turnbuckle on the tail wires, whole turnbuckle
on the elevator or rudder (if you want) or 1/2 on each end if
you want - they will make them for you. Got to give
them the measurements "hole to hole". And it's
nice an clean. Aircraftspruce isn't the cheapest, lot's of
aircraft fabricators have a swaging machine.
The pictures are a little big - sorry , but I assume you want
to inspect them close up?
http://www.aircraftspruce.com/pdf/2010Individual/Cat10137.pdf
64.57 KB |
13670 Time(s) |
264.03 KB |
13670 Time(s) |
131.43 KB |
13670 Time(s) |
86.61 KB |
13670 Time(s) |
