601XL Cowling
vk3eka(at)bigpond.net.au
PostPosted: Fri Aug 28, 2009 10:38 pm    Post subject: 601XL Cowling Reply with quote
Hi Guys,
I received my camlocs for the cowling from ASSC the other day.
Attached is a photo. The photo shows:-
40S5-3S SS CAMLOC STUD
4002-NS CAMLOC GROMMET 214-16ND CAMLOC 4002 Receptacle
How do I get the stud into the grommet. Do I have to remove the pin? If so, how?
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
 Filesize:  504.63 KB
 Viewed:  4803 Time(s)
craig(at)craigandjean.com
PostPosted: Fri Aug 28, 2009 11:12 pm    Post subject: 601XL Cowling Reply with quote
I haven’t used the grommets on mine but this is how I get the camloc studs through the holes I drill. Compress the camloc and its spring with the special camloc pliers. Then you should be able to “hook” the shaft with the pin through the grommet. Try this document:
www.afscamloc.net/xua/downloads/Camloc%20Quick%20Release%20Fasteners.pdf
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Peter W Johnson
Sent: Saturday, August 29, 2009 12:38 AM
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: 601XL Cowling
Hi Guys,
Cheers
Peter
Wonthaggi Australia
PostPosted: Fri Aug 28, 2009 11:22 pm    Post subject: 601XL Cowling Reply with quote
Craig,
Thanks for that.
A pair of needle nose pliers did the same thing. I was looking for a complicated solution to what is a simple problem.
Peter
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Craig Payne
Sent: Saturday, 29 August 2009 5:08 PM
Subject: RE: 601XL Cowling
-- Craig
Hi Guys,
Cheers
Peter
Wonthaggi Australia
5
6
7
8
9
NYTerminat(at)aol.com
PostPosted: Sat Aug 29, 2009 5:55 am    Post subject: 601XL Cowling Reply with quote
Peter,
There is a tool that is used to install these. Look in the catalogue that you purchased them from. If I remember you can modify a pair of pliers to match the tool.
Bob Spudis
