Antennas
frank.hinde(at)hp.com
PostPosted: Thu Apr 06, 2006 1:17 pm    Post subject: Antennas Reply with quote
Hello Bob,
I must say the magic of antennas is a little lost on me so I was looking
at your COM and VOR antenna designs. I have a Bob Archer com antenna and
he talks about Vertial polarisation but your example shows both glued
down to a horizontal surface...Am I missing something?
I assume that one can't put both a VOR a COM antenna in the same
fiberglass wingtip?
Can one do the same with a much shorter (5"?) transponder antenna say on
the bottom of the rudder?
Us RV guys really don't like things hanging on the outside of fast
airplanes...Smile
Frank
brian
PostPosted: Thu Apr 06, 2006 1:51 pm    Post subject: Antennas Reply with quote
Hinde, Frank George (Corvallis) wrote:
Hello Bob,
The radiator part (the part of the antenna attached to the center
conductor of the coax feed line) should be as close to vertical as
possible. The VOR/LOC/GS antenna should be horizontal.
fiberglass wingtip?
It is not a good idea. You want as much isolation as possible between
the two.
The transponder antenna is actually 2.6" (6.5cm) long. That antenna you
do want to mount on the belly as it is prone to being shielded by other
things on the airplane. There should be nothing between the transponder
antenna and the RADAR site on the ground.
airplanes...Smile
The airflow on the belly is already turbulent from mixing outflow
cooling air with the undisturbed air so putting antennas on the belly is
not going to have any effect on maximum speed. You should definitely
mount your transponder antenna on the belly far enough away from the
gear legs and exhaust pipes so they do not constitute a shield for the
signal.
Brian Lloyd
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
