Posted: Wed Aug 26, 2009 12:09 pm Post subject: Question on Control Cables & FAB |
Most all (if not all) the hardware on a Lycosaur is coarse thread .....
and the AN bolts are fine thread. I'm thinking that may be the
difference???
Linn
jayb wrote:
Thanks for the reply.
Here's why I asked the question:
The table in Vans RV-10 General Info Section 5 calls out AN7... 450-500 in-lbs. The Lycoming Service Table of Limits SSP1776 doc Table I, "Bolts, Screws and Nuts", page 1-37 calls out 7/16...600 in-lbs. 150 in-lbs difference is quite a spread.
I may just split the difference and call it good.
Jay
johngoodman wrote:
> It's a 7/16th inch thread, so look up the torque numbers in the tables.
> John
http://forums.matronics.com/viewtopic.php?p 59752#259752
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Wed Aug 26, 2009 12:35 pm Post subject: Re: Question on Control Cables & FAB |
| pitts_pilot(at)bellsouth. wrote: | Most all (if not all) the hardware on a Lycosaur is coarse thread .....
difference???
Linn |
Also it should specify the metal it is for. Course, fine, and metal.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Kelly McMullen
Posted: Wed Aug 26, 2009 1:23 pm Post subject: Question on Control Cables & FAB |
Lycoming generally uses higher torque than standard values, especially
on the case halve bolts, and has little relevance to what torque you
would use on a control cable nut.
On Wed, Aug 26, 2009 at 11:20 AM, jayb<jaybrinkmeyer(at)yahoo.com> wrote:
Jay
> John
A&P/IA, EAA Tech Counselor
KCHD |
