dlm46007(at)cox.net Guest
Posted: Sat Aug 22, 2009 7:54 pm Post subject: LOP |
Attached is a picture of the GRT Sport that backs up my Chelton displays; it has a LOP lean function where the boxes appear as each EGT peaks and then declines. The GRT EIS is feeding both the Chelton and the GRT Sport with serial data on engine performance. The two Chelton screens show comparable data from about the same time. Fortunately I did not have to balance my injectors as the spread of both EGTs and CHTs seemed adequate. My engine was a new certified IO540 from Vans.
123.92 KB |
1479 Time(s) |
127.55 KB |
1479 Time(s) |
99.46 KB |
1479 Time(s) |
